giampieroricci
Everything posted by giampieroricci
  1. I decided to change the system for opening doors by mounting the external hinges. Now the door opens fully: I started the construction of the hanging cabinets. Everything is still temporarily resting, I have not glued nothing:
  2. The drawings do not notice the hinges outside the doors, I presume, are recessed, so I've thought of an alternative system; I do not know if it can be appropriate, but it sure is effective: the pictures explain better than words: The desk:
  3. Some progress; walls and doors of the cabin of the Captain and the closet
  4. I went a bit 'forward in the construction of the Capitain's cabin, but first I had to prepare the bulkhead separating the boardroom by the bridge battery The interior of the Capitain's cabin: this is the small wall of the bunk where will placed the mattress, with the drawer on the bottom Macro
  5. Thank you, friends!! I started working at the Captain's cabin; I also wanted to try out the mattress. For the body of the mattress I used a small piece of sponge for dishes coated with the thin cloth and sewing the edge. This is just an attempt, I'll probably have to do it a few millimeters bigger
  6. Preparation of the ropes backward supporting the beams of the formwork
  7. I started work at the stern to prepare the boardroom and beams of the formwork.
  8. You are right! I give a coat of clear lacquer matte finish to fix all the small scratches that inevitably are created while working on the model! Thank you for your suggestion!
  9. For the coating of the smaller circular scuppers, after having pierced with much trepidation and caution, to avoid spoiling the model, I used a thin lead foil beaten anvil wrapped around a rod of the right size that I used as a guide 'insertion into the hole:
  10. Hallo Gary! I will follow with great interest your work: my next site will be just the Naiad of which I'm already studying the excellent monograph of EdT!
  11. Hatch of the kitchen: Preparation of the stairway to the deck of the kitchen great bell:
  12. Your method for constructing the steering wheel is really brilliant!!!!
  13. Your work on the gears of the winch is simply wonderful!!!
  14. Hello Ed! I like very much your little saw! I'd like to know how you have built it! Your work is fantastric, as usual!
