I have seen this stuff even says it can be sanded to make contours and gradients - https://www.ebay.co.uk/itm/266556642528?_trkparms=amclksrc%3DITM%26aid%3D777008%26algo%3DPERSONAL.TOPIC%26ao%3D1%26asc%3D20240131095853%26meid%3D49c2093ed2da43b9b9b6ed903ca8c204%26pid%3D101949%26rk%3D1%26rkt%3D1%26itm%3D266556642528%26pmt%3D1%26noa%3D1%26pg%3D4375194%26algv%3DRecentlyViewedItemsV2Mobile%26brand%3DUnbranded&_trksid=p4375194.c101949.m162918&_trkparms=parentrq%3A5a061b6e18f0a0dc76e9ce35fffe4c82|pageci%3Aa22ccd1e-0d7e-11ef-919e-32f7db286d20|iid%3A1|vlpname%3Avlp_homepage OC.
Thank you kindly for explaining all that, my thinking for using ordinary copy paper is because I already have a ream of it to hand, I will be landscaping directly down onto my plastic base (Green in my photos) and the dimensions of the slope gradients are from 3mm at the end where it joins the paving section near the porch sloping up gradually towards the edge of the barn where it needs to be between 15 and 20mm, then sloping away to my Right where it needs to be about 25mm, so I was thinking starting off with my 3mm thick over the whole area, then page by page adding them graduating them to get the gradual slope or even a slight ridge where the slope might not be a perfect line but lightly rounded, also where it meets the log store extension I want the ground to slightly fall back abit with a nice rounded taper, not forgetting it will have the grass mat over the top of it so it should be plenty tough enough - and the weight does not matter as its weighty all over to be fair. But I have never done any scenery landscaping before - so its all a learning curve. I do appreciate your input and ideas brother as every little helps. OC.
To be honest I never got round to starting it - I passed it on to an other. OC.
- 13 replies
Morning all, I have decided to attempt my scenery profiling using sheets of typing paper (as I have these to hand) has any body tried this formula for model scenery as I can not find any links on the net, its sounds straight forward in my head - just a case of having enough paper for the height I want - then just sloping the A4 sheets in the directions I want using PVA to keep them in place and build it up as I go, don't foregut on top of this I have my grass sheet that will be glued over the top of the contours. OC.
Looking good Alan, so hard to pull these sea scapes off, and we thought land scenery is tough, looking forward to seeing how this finishes. OC.
- 97 replies
