Old Collingwood
  1. Evening all, more work has been done on my odds and ends - painted and weathered Pelisse, will have a flat top coat over the top when fully dry, the muskets are getting some colour, and the knapsacks are getting their straps painted, still more work to do. With the Pelisse - I first layed down a Black primer, then Dark Green followed with a bit of White mixed with the Green to make a slightly lighter shade - ths was painted on the high light areas leaving the sunken shadow areas Dark Green, I then went over with a wash, then finished with a light dry brush dusting of my dust paint, its made to look dusty as it will be sitting on the dirty dusty road. OC.
  2. Congratulations - what you did was to convert a very poor old kit that out of the box just looked poor in quality and detail, and you have given it some life - and now placed in a well deserved place in its case. OC.
  3. Youa re certainly being tested there Alan - keep going mate it will work out in the end. OC.
  4. Evening all, bit of an update - the seller has issued a refund in Full, and says no need to return the broken base, so turned out ok in the end. OC.
  5. Thank you kindly Alan, will look at doing that after my sanding shaping is done, I will have Alot of cutting - sanding away of the top where it will go from about 3mm thick on the one edge to anout 10mm and the other opposing edges it will go from about 20mm to around 25mm. OC.
  6. That looks so nice - what a nice tidy fit mate. OC.
  7. Ah yes of course aka Flyhawks hulls (I should have remembered that) OC.
  8. What I shall do is - await the reply back from the seller, if he is refunding me with me keeping this, I will still have enough material to work with as I ordered larger than I needed, so I will be able to cut and sand the pieces I want and glue them down on to the plastic base (using PVA Glue I have to hand) then just shape the rest of the pieces as I go, and light hairline cracks wont matter as I have a roll of the modellers grass mat to go over the top so the cracks or seems where the pieces join will not be seen. OC.
  9. What an excellent idea, so I guess you slide the tub assembly in from rear of the assembly? Wish more kits would adapt this idea. OC.
  10. Indeed mate some times its a hit or miss affair ordering from over there. OC.
  11. Thank you kindly brother, I will see what they say when they are open again (China Time) They initially responded straight away when I messaged them - full of apologies saying they would send a replacement but knowing that would also arrive damaged - I told them in no uncertain terms that I did not want a replacement but I wanted a Full Refund as I completely blamed them for not packaging it in bubble wrap or similar, they went quiet on me after that. OC.
  12. Craig Packaging - what packaging, it was just put inside a thin plastic bag with no protection at all - it had no chance at all in not getting damaged travelling half way across the world. I am pushing them to refund my money while I see what I can rescue with this one as there is lots of trimming and thinning work to do to get the profile I need. OC.
  13. Afternoon all, my styrene base has turned up from China - I will let the photos speak for them selves - to say I am not amused is putting it mildly - OC.
  14. Looking good Alan, I do washes over my 28mm figures but how well I would get on doing that at this scale - I dont know, you could try a very slightly darker shade of Yellow and paint the shadows, then a slightly lighter shade of Yellow and dry brush the highlights and raised areas, I haven't actually successfully painted any larger scale figures. OC.
