You could try some heat (haiirdryer) while gently twisting it in the right direction, I would try to do this before you start first planking as I am not sure if planking will pull it in to shape - and might lock the twist in. OC.
Excellent work Alan, sea scapes terrify me - but you look to be having a hold on it - keep up the great work mate. OC.
- 97 replies
After doing some research it looks like I need to do a bit of scratchbuilding, from some of the photos it looks like there should have been a porch building on the outside of the farm house around the door leading to the garden, I will try to male one using the photos like this one, with the bits of board I have to hand. Photo off the net. OC.
Stupid question I know - did you peel the decking off the plastic backing before placing it? OC.
Just as a little teaser - I have placed my Two British Cavalry figures on the roadway just in front of the Two 95th rifles, I will take pics of them later....... So this side of my dio is getting close to being finished - I will also add some loose left items like - muskets - backpacks - hats perhaps even a shoe or Two, then I will be turning the dio around and starting to work on the scenery on the other side. OC.
Morning all, more pondering s - I decided to play around with my water gel product that I made my pond with, the idea was that the wheel ruts in the road way would probably still had small pools of water sitting in them, - so (not thinking about colour) I brushed in a bit into a few of the wheel ruts, its thick and White at first but after about Ten hours it hardens clear. The problem is it just looks like a clear line not a slightly coloured water like it should have been. Its got me thinking if I could do a very thinned dark wash all over the base - roadway etc (Yep includes trying to get in with a brush around all the figures) - then if I could go over the top later when the wash has dried thoroughly with my dry brushed sand dust colour as a high light. Yep would certainly be a job and a half - but it might work to blend it all in together. What do you think? OC.
Hi there all, a bit more progress, I have re done the wall extension (well turned it over and added a small piece at the bottom) its been painted White and waiting to dry. I also added some of my resin water in puddles in the ruts on the road way and against the wall (waiting for these to harden and go transparent) I have also placed a few more figures in the shape of Four 2nd KGL casualties in the orchard. OC.
