Old Collingwood
  1. Thank you for that, it is rather well moulded, I will have to add a bit of scratch work on the side walls in the cockpit as they are a bit bare. OC.
  2. The say "Once you dip your fingers in plastic modeling - your fingers turn to plastic, or if you come from wood - you get plastic splinters"😄 OC.
  3. Excellent work Kevin - each post showing more and more fine workmanship by you - you will be able to "splice the mainbrace" soon OC.
  4. Thank you mate - welcome aboard this little trip down the Falklands way. OC.
  5. Talking of James Bond films - I would love one day to build a model of a Lotus Esprit mk2/3 (not the one that converted into a sub) reason being I once nearly owned one (got close to a moment of excitement and madness) OC.
  6. I put the tub aside and going by the structions - next area is the front wheel bay and front fan blade assembly/surround, the blade assembly trunking is one piece and needed a tiny bit of clean up - then it received severa..............l coats of dull white acrylic with a brush (as I mentioned above) I was aware of getting tiny specs of dust and hairs on the paintwork so I needed to keep checking for this, It will need a bit of a polish as its supposed to be a smooth almost satin finish, next was the wheel bay - this comes in two sections to aid detailing, so agian it was a case of putting down several coats of dull white, then when dry I ran a dirty wash of watery dark grey/black and heated it with a hairdryer (they were renowed for catching all the dirt and grime in there - same as the main wheel bay). Oh, and the fan blade received some flat alum. Here is a pic of the above on my mat after painting. OC.
  7. Evening all, got some more good progress today - despite it taking what seemed like ages to put thin paint layers on with hairdryer between each coat, so I put the HUD on the pe frame (fiddly is not the word) as you can imagine not getting glue on the clear part was mission inpossible, after it had set I tried to sand the glue out on the one side I could get to - then I tried the old method of polishing the plastic with tooth past (as you do with canopies, it did a fairly good job but still left behind some marks (not a problem as the front screen will mostly hide this). So - the tub is finished with the seat glued down. OC.
  8. Evening all - so glad to see our refreshments have turned up - building is so much more fun on popcorn, so work continues with the cockpit tub - I gave the bang seat a bit more weathering really starting to bring the details out now, next off was the tub its self - I painted the side walls in flat alum then gave the rest of it a mid sea grey wash in watery coats, then I used a mixture of Black and alum high lighting to bring the details out, same principle with the instrument panel and the rear plate, I then glued them together and dry fitted the seat to check it out. Still needs the HUD, and a few other fittings. OC.
  9. Have you ran out - "never" right i'm going on strike - "no popcorn no buildy" have to draw a line somewere. OC.
  10. That is looking So Good Craig - miles a head of other kits the quality of moulding and your skills making it pop, fantastic build. OC.
  11. Thanks Ken, yep I will do that, I was going to put the white/yellow bands on the jet handle - but even under my magnifier - "no chance" OC.
  12. Loverly work going on there - those fitting really add to her. OC.
  13. Good to see you back Mark, those are some nice fittings there looking forward to more progress my friend. OC.
  14. This was the first time I saw a Sea Harrier in fact Four of them all Falklands vets. Not my pics off the net.
  15. I think you can potentially build almost every SHAR mk1 built by juggling the numbers around. Glad to have you on board Mike. OC.
  16. Trying to get a better view I guess,😁 Of the popcorn - not the build. OC.
  17. Thanks Carl, thats certainly something to consider when I come back to her. OC.
  18. Welcome Jack, we are awaiting the goodies delivery - Mark should be here soon, watch out for Lou though, he does love his popcorn. OC.
  19. Thank you Craig, thought it would make a change to come a bit more modern - easier to paint also. OC.
