How about conventional household wall filler mixed with a bit of PVA glue, would that not work in areas like covering up port holes etc? OC
Hi Joe, I have just ordered a white Vallejo primer in Acrylic and also the authentic WW11 western approaches range from a company called LifeColor, again in Acrylic, i have also ordered from Vallejo their sand colored Acrylic that i will add some light grey to - to simulate bleached salt worn wooden planking. I already have a bottle of Acrylic red ocre that i am hoping to use for the bottom RN anti fouling red hull paint, my plan is to assemble both sides of the hull minus the deck and prime this after a thorough wash with detergent and water, then i was going to mark of the Boot topping line and paint the Red hull first, then after a few days allowing to dry, i was going to mask the top of the Boot line then paint it black. Then afterwards move on to masking the patterning and painting sowly each section. OC
Superb work Glenn, i am following this with Special interest due to my own build on here OC
- 33 replies
- warspite
- battleships
I started work shaping the rear armour difference from the position of the veranda forwards towards the main armour belt, i started by measuring and scribing a line, i then used a scalpel knife and starting at the line i gently scarped away from the line until i had reduced the thickness slightly, i took a picture before i had cleaned up the dust. OC.
Here are a few pictures from my archives showing how i am going to display here(the year and configuration i mean) as i will be building her as a full hull stand mounted and when i can build one - in a case... OC.
A bit more work was done today by sanding the filled in lower stern port holes and the frame of the veranda water tight door, as it was standing prowed of the hull, i also scribed a line along the section of hull from the first 6inch gun is and forwards, i was able to use a template scribbing tool that i held in place with a few crock-clips then gently ran a scalpal blade along its edge. I then turned my attention to the openeings for the anchor chains in the hull and where they are just slits within circular rims, i opened these up but tried to get a tube affect pointing up and rearwards by using a round needle file, i will see how this mates up with the deck openings nad adjust or add some filler or tube if i need to, i finished off both sides by using a soapy sponge and washing the plastic down to remove - greese/dust etc. That was todays bits done... OC
I am also considering doing a bit of sanding around the stern to simulate the different hull thicknesess due to the armour belt, and from the bow flowing back to the first 6 pounder gun, i will scribe a slight line to also show am armour plate join line. OC
After studying some pictures of her in her late 43/44 look i noticed that she has had her black boot line extended further up towards the deck, and nearly touching the bottom of the stern veranda, this has made me decide to cover up the stern bottom row of portholes as they would be so close to the water. I can only assume in her later years around DDay she must have been more heavy possibly from the additional smaller gun emplacements, and the extended boot line was to illustrate how she sat lower in the water, i might be wrong with my conclusion but it does look this way though OC
On the preserved Victory they do walk around tours, but nothing compared to this even if it is in minature, on the real thing it would take a very large cast of renactors to get across something like this,,,again Superb OC
Many thanks or your advice - the more the merry-er, i have a good selection of brushes and i am use to painting by brush most smaller sized models, and with acrylics i only started using them with my admiralty range on my wood build. As i am now building a 1/350 scale plastic a ship build in plastic will be the largest i have built/painted, so this is why i was wondering about the best way to paint the expense area of the hull? i can break the painting up into sub-sections i think? by masking off sections of armour, and try to get a smaller area to fill with paint easier from the brush, i just dont like the idea of having to fill an area from bow to stern about 20" in one sweep, i think that will be asking for an un smooth finish by anyones standards? OC
A bit more work was completed today outside in the sunshine i drilled out the other section of port holes and scribed a bit more of the edge details, but i also decided to open up the doorway to the stern veranda, this will have a door fabricated as well and display it in the open position, here is a picture.. OC.
I am building a 1/350 scale plastic HMS Warspite Battleship and i am looking for advice on hand painting with brushes my build please, the first area i will tackle will be the hull - this are i think i can break up into smaller areas and mask off around different bulged sections and armour plated sections, this would cut down on the area needed to be covered in one swoop etc. I will be painting the bottom hull section first upto the masked off boot line, but wondered if anyone has any advice/tips regarding this please. OC
I will repeat the same on the other hul side then install the hull supports before joining both hull sections together, i will then work on the constructed hull and clean up the seam at the bottom where the two halves join, i am also considering opening up the anchor chain openings as i am sure these should be tube like and not just slits like they are at the moment. OC
I have started on the one hull side using a fine drill on the many openings, while i was at it i also scribed along the inside edges of some of the details. OC
Before i start my build just a bit of background information on my desisition to build the Old Lady, my late farther was in the Fleet Air Arm and was an airframe fitter, he worked on many types but his main knowledge was on Sea Fires and a few sea planes, this nearly led to a placement on HMS Warspite but unforetunatly he was to late gaining his grades and by then i believe the airwing on warspite had de commisioned so he stayed land locked and went to Oz instead prep-ing Sea Fires to come back to the Uk. OC
Many thanks for that, it is for my 1/350 scale plastic HMS Warspite BB ship i have just brought, she had teak decks that were regularly holystoned so i guess they would be very similar to HMS Victory's decks esp. when dry and faded, as they are plastic and of very good detail i am looking for a scale paint that is the right light shade for her. OC
Hiya some really great workmanship and with so much entertainment - Brilliant, can i ask your oppinion please - can you recommend a deck paint for plastic that would replicate and show a good example of holystoned teak, i have seen weathered teak in real life A.K.A - my outside garden bench, and it is a deffinate light grey in color. Any tips as to what color paint i should get for this i would be delighted. OC
I collected my new kit and after opening the sturdy box, i was amazed at the fine moldings inside - the hull sides look superb and i will want to preserve as much of that fine detail as possible, i am not sure what stages of build i will seperate and do, but i will construct the hull and paint it before adding the deck etc, any ideas for painting the black hull line folks? OC
I pick her up today folks cant wait to open the box let alone start to build her, i have had my general orders from Mrs Collingwood, and me old Warspite is to be fully dressed and museum quality, and of a display standard that Mrs Bucket would be proud of OC
Thanks for the replies folks I am still not sure how to build her, i am not old enough to have seen her in her glory years coming in and out of Plymouth, and as i explained i have walked across the beach at Penzance to St Michaels Mount on the stone path, from where you can just make out the corel remains of her. If i display her as she was at Prussia Cove i assume i would have to a diaramma, as she was just a slightly dismantled state minus gun barrals etc, but to construct her as she was at a later stage in Penzance Bay would be just a feature less hull. Desisitions desisitions OC
Right then folks ......Change of plan i have changed my mind about building HMS Illustrious and have now orderd HMS Warspite in 1/350 scale, she arrives by next weekend. Anyway after seeing her wreck via a wet path (whats left of her - just bits of her bottom area and keel under water) i am pondering over building her as a full display stand model but weathered, a part wreck as she was when she was wrecked against the rocks near Prussia Cove, to display her even more dissmantled as she was when she was towed into Penzance bay and taken down section by section(this woulkd meen just displaying a hulk with very little details. It would be a shame me thinks not to show her in her glory. OC
Just to say I'm back and will be posting again soon folks..... Collingwood
- 455 replies
- slightly modified
- greyhound
