I did a little bit more work in the same area today, by applying a little bit of white dry brushing to bring out the edges a bit, and applied dark grey to the slopes over the catapult cover, I then applied a couple of coats of matt varnish to kill off any shine where it should be flat. Next step will be to fix the boat stand near to the catapult then I will start on my first bit of superstructure in the same area. OC.
I carried on with the mid ship section again today working on the catapult runway fitting the two slopes at each end from the etch sheet parts, after shaping and fitting a couple of coats of light grey was applied, here are a couple of pictures showing where I am at. OC.
More work was carried out yesterday by tidying up some of the decking-pushing it down with a flat blade and cutting around a few tiny obstructions, next I turned my attention to the float plane runway - this is being covered and not in use as I a making a late edition Warspite, as she was on D Day, I cut the cover from the fret and bent the two edges 90 deg, then I did some shaping and thinning of the track guards that would be seen over hanging the deck, also under this section was fitted on each side under the track a small brass plate, representing the bottom of the track, I painted the track light grey than fitted the cover with a few small touches of super glue, the gave the cover a coat of light grey, then put aside to dry and harden. Next will be the ramps that were fitted so crew could walk over the track, these again are brass and I will add some small frame work underneath to give them a bit more realism. The next stage of decking I have been working on the plan drawing them up in Paint, I have decided to split the next stage in Port and Starboard with two nice sharp/strait edges to join at the 2nd gun turret at a Diagonal. Here is a pic of my Paint drawing. OC
I was under the impression that the White Ensign was still carried but moved to the boom as Nelson wanted to make a clear indicator for the British and also a little bit of making a point at the opposition. OC.
Wasn't the flag carried between the Gaff and the Boom on the Mizzen mast, I have seen it like this on Turners Trafalger painting. OC.
More progress to day folks - as I posted above I continued with the mid ship section on the other side of the runway strip, this was cut away quite easy with a nice sharp fine blade but the pointed ends that part wrap around the turret were very very fragile, to the extent that they broke off when I tried to fix the deck down B)i was able to fix them back down after the carpet munster gave them back . Anyway in the end after a bit of adjustment and gentle knife work around a few of the fittings, it settled down and I am quite pleased with it so far. OC.
We need away to make them ourselves possibly by bending some plastic strip to shape :o OC.
Hi there, After doing a bit of net bashing I came across this - its a well established company here in the UK, they are called Cornwall Model Boats, and the individual maker in that site is called Amati Ship Fittings, they have several Fairleads in different sizes. OC.
I got round today to laying the dark grey painted areas I had made from paper sheet, I test fitted them a few more times before painting on some white glue then fixing them down, they settled quite well, next I turned my attention to the wood decking strip - as I have decided to tackle small areas at a time, I cut the relevant section and then I cut around the details till I had two nice small areas to work with, as they were so small I placed them and pushed them strait down into place without wetting the surface. I am quite impressed so far and the wood deck really looks the part. Here is two pictures I shot after fitting the above. OC.
What I will have to try to source is the Fairlead's as a few of mine have broken due to heavy handling when I was working on the hull OC.
Thanks for that Frank great looking pictures my friend, I am basing a lot of my work on the excellent Very Large scale Warspite that a fellow builder on here was building, a lot of his pics show some excellent detail and what I would consider reference material as the build is an engineering model built by the Ship builders. OC.
This will be my first section of decking, the shaded area each side is for the dark grey painted areas. OC.
More work today on the mid ship section I applied a few thin coats of Admiralty light grey to the inside of the armour bulwarks around the 4inch mounts, and while these were drying I changed colour and applied a few more dark grey coats to the paper floor sections I made to fit around the the 4 inch mounts. When these are dry I will be able to glue down with some PVA the paper flooring, then the next stage will be study the wood decking sheets as I intend to do them in smaller sections and possibly apply some appropriate weathering to them? OC.
That sail in the last pic looks really good, it looks about right with the slightly off white colour as I believe obtaining pure white cotton was very hard, someone told me they used to try to bleach them in salt water to keep them as white as possible? Great work there. OC.
Really nice work there with so much attention to detail not to mention steady hands and great eyesight, you are creating a masterpiece Regards OC
Thank you Ken, I am hoping to improve things by doing controlled areas - say the bow to the breakwater as one section, the breakwater to the obstructions either side of turret no2, from there to the break between the main superstructure block and the A/c Hanger block, from there (allowing for my 4inch cut outs) to the runway cover, then from there to the V section around turret 3, and finally the aft section towards the stern. I had read and also had a bit of feed back from Pontos that you can spray a light film of water before placing the decking, as it slows the tacking process a bit, not sure how accurate that is but it did come from the horses mouth so to speak. OC
More work on the mid section today by tidying up the plate sections then a coat od grey primer, next will be the light grey inside paint to be applied, then I will be able to lay down my first section of wood decking, I will aim to do this in smaller sections than on the sheets to aid positioning. Here is a pic of the wood decking to go down, its shows the sections to be cut out around the 4inch mountings that will be metal deck with a dark grey finish. OC
I was again at the table yesterday doing a bit more work on the mid ship section, concentrating on the other armour plate sections where the 4inch mounts go, I also fitted another Spurnwater that was with my brass update set - this was tricky as it had to sit in a very narrow section and required just a thin layer of super glue applied with a fine ended brush handle. The plan is to sand the inside edges of the plate down and the deck area ready for a light grey paint, then I will lay down the semtex coloured sheets that I have made out of paper and painted, these were in the general area around the 4inch guns, but with the planking running behind and in front of this section, it will then be ready for the wood decking sheet I have - I would have liked to have worked fitting this on each separate piece of the plastic kits deck, but the join with the wooden sheet would look a bit false in a strait line, and I can not leave anything overhanging as the wood decking sheets are way too delicate, otherwise I would have staggered them like I have real deck planking. OC.
That sounds like a plan frank, the idea with placing the cloth on top of the plastic ones should work well as they should provide a good mask type thing, are you going to age the sail cloth with tea or vinegar etc? OC
I sure would follow that and offer any help I could from my previous De Ag Victory build and from the times I visited Victory at Portsmouth. OC
