KenW
Everything posted by KenW
  1. Thanks for the encouragement. I'll continue with the model and my postings. It'll be interesting to see how it all turns out. Cheers.
  2. It has been awhile, but I completed the planking of the hull. I had several problems. When I switched to the 1/16 inch planks, I still had trouble bending the planks to the necessary shape of the bow. This problem shows where the planks join the stem. So my choice was to either redo the planking, port and starboard, or try to fix it. I chose the second. The results are obvious below. I now think that this whole project was poorly conceived. Trying to make a model from a picture without plans was a bad idea. I’ve planked a boat’s hull with a ‘bowl bow’ before (the Independence). I think that if I had a proper plan the shape of the bow would be different. I am going to continue the build because I feel there are still lessons to be learned. I just may not show the model anywhere or to anyone.
  3. Your blog is also a great course in model building. Your work is top drawer. Excellent. Cheers.
  4. I find that although I probably won't build this model, your log IS an excellent instruction source. Thanks for your efforts. Cheers.
  5. Your design is innovative and revolutionary. Plank-on-Frame modeling will never be the same. Truly unbelievable!
  6. Thanks Gary. That's a good idea. I'll see what happens. Cheers.
  7. Happy New Year! I finally completed planking the port side of the model. It came out better, but far from perfect. If you look closely you’ll see a plank near the bow that is WAY too wide. I just have to learn to be more careful! There is no reason why if I have my paper strips, measure them properly, mark the hull accurately, and follow the marks when shaping the strips, I need a wide strake. I’m going to start on the starboard side and if it comes out way better I’ll have to decide whether to do the port side over. Probably I won’t. I’ll just put the port side towards the wall..
  8. Excellent work on the furniture. The entire project looks fantastic. Cheers.
  9. Thanks Gary. Planking the bowl bow requires a lot of patience. I hope for the best. Cheers.
  10. I measured a new set of paper strips for a planking plan for the port side. The plan is for 19 one eighth width strakes; divided into 3 belts of six planks. I’ve completed the first belt of planking and I think I’m on the right track. One thing I learned about planking is that you can bend a plank more than once. At the bow, I first do an edge bend at the mid point of the plank, and then bend again about one half inch forward and another bend a half inch aft. This created an overall bend of the plank that fits the adjoining strake. If it’s still not right, I bend again. Then I bend the standard way for the curve of this odd shaped bow. Attached is a photo of the first belt and you can see how nicely the forward planks lie.
  11. Thanks. I've finished the zone of 6 strakes next to the wales. I came out pretty good. The problem is always, for me, how close am I to the plan. I will get out the paper strips and re-measure the next zone. If I am pleased with this side, I plan to remove the old planking on the other side and start over with it. Cheers.
  12. Planking of the starboard hull continues. However, I’m not pleased with how it’s going. You can see from the photo that the forward section and the aft section don’t ‘match’. It looks like a drop plank will be needed in the middle of the hull - a very unusual location for one. I went back and studied my planking process; from creating the paper strips at each bulkhead to the final installation of the wooden planks. I see problems throughout the entire process. So I’m going to start on the port side from the beginning. I’ll create new paper strips and try to more closely follow these strips and see the results. If, as I suspect, the port side comes out better, I’ll remove all the strakes from the starboard side and, again, start from the beginning. This is taking a whole lot longer than I originally planned. But there is no rush - I don’t have a boss with a due date standing over me. I think it was Augie that said, “It ain’t a hobby if you hurry.”
  13. Thanks David, Gary and Allan. As a member of the Ship Model Society of NJ, I've read and printed all the tutorials by Chuck. I should return to his monthly workshops. (I hear he has started them up again.) Every time I take some planks off and replace them, I see an improvement.
  14. Thanks for the photos Gary. They will be a help. The problem with my boat is that the bow has this "bowl" shape. But I like the idea of planking in sections. Hope your modeling is going well. Cheers.
  15. Your workmanship is very impressive. I hope you continue this build. Cheers.
  16. I'd like to see your photo. Someone told me this would be an interesting planking exercise, and he was right on. The stem is giving me the most problems; although I can't wait to see how it all looks when the two rows come together. Cheers.
  17. Thanks Gary. I am still having trouble with the planks starting at the keel going "up" or down since the boat is upside-downside. Your belts may be just what I need. Cheers.
  18. Well, I made my decision. I pulled the planks off the hull and will replace them with 1/16 thick strips. As I was advised, the thicker strips will bend, without breaking, to the extent I need. So far, I’ve installed 9 strakes and the results look much better. I’m going to start from the keel for the next strakes and, looking at the planking so far, it will be interesting when the two sets of strakes meet.
  19. I’ve spent a lot of time trying to plank the hull. (Three attempts have been removed and replaced.) I’ve now got 7 strakes installed on the starboard side and I see problems with the overall look of the bow. The planks look OK (1st photo), but they are rising way too fast (second photo). I’ll need to use at least two drop planks in order to finish. The real solution is to use edge bent planks. However, I can't get the 1/32 inch thick, ⅛ inch wide cedar planks to bend enough; and the planks don’t hold to whatever bend I do achieve. I think my only solution is to order some sheets and cut strips out in the shape I need. If anyone has any advice, I’d appreciate it.
