KenW
Everything posted by KenW
  1. Thanks Lou and Mike. "Plagiarize! Let no one else's work evade your eyes!" Cheers.
  2. Back to the Providence. I added the shrouds to the port and starboard sides.They have not been tied off yet. I’m thinking I may want to undo them when trying to rig lines in the future.I’m thinking that I won’t add the ratlines before securing the shrouds.
  3. And now for something completely different. I made the Winchelsea stove from Chuck Passaro’s kit. The stove will be a great knick-knack for my oldest son’s desk or shelf. Like all Syren kits,the parts are precision cut and fairly easy to assemble. Some parts are very small and will break so care is needed. Fortunately, extra pieces for those tricky parts are supplied. Now, of course, I’m going to have to make another one for my youngest son.
  4. I made the main mast trestle trees and hounds/bibbs. Before I glued them to the mast, I made the spreader yard (similar to the mizzen cross jack) because I want to make the truss, which ties the yard to the mast, while the yard is off the model. A sling block and two quarter blocks are also stropped to the center of the yard which will be used later. Then the yard is lowered over the mast head and the trestle trees and hounds are glued in place. The mast itself and the yard are still not glued - in fact, I don’t plan on gluing either, but rather let the rigging keep everything properly lined up. I also rigged the gaff throat and peak hallards.
  5. Mike: I made the stove as well. It's a great, well made kit. Only problem I had are with those very small, and breakable, parts to hold the pulley system. Your effort looks great. Cheers.
  6. I spent a great deal of the summer in the country without my model. But I survived and am happy to get back to work on the Providence. The first thing I noticed is that the main sail is a bit too short. So I took the sail down and made a new one. I like the longer sail and I think the furling produced a better look this time. After redoing the rigging, I added a tack line which is described in Lee’s and Antscherl. Now it’s time to move on to something new.
  7. Bob: I totally forgot that I followed this topic. I have a furled gaff topsail on my Independence. If you find my log, go to page 4, entry #107 - # 110 and you will see my discussion. For the actual rigging I used the source and diagram shown in your first entry. You need a halyard, a sheet and tack (which extends below the gaff). The sail is bent to the mast with a loose line. Once I accepted the fact that the bundle wasn’t the best looking, I no problems. Cheers.
  8. Thanks Thucydides. Furled sails aren’t that difficult. But, I didn’t attempt it until my third model. I was worried about other things. However, your model looks like it’s coming along great. Give it a try. Cheers.
  9. The main sail is furled. I was worried about this, but it came out alright. It doesn’t look too much different than a photo I have of the replica’s furled sail. I also rigged the mainsail outhaul and the main sheet. I used the rigging plan shown in the Petersson book mentioned above; even though I know that rigging practices changed in around 1800 and all of Petersson’s examples are of ships after 1805. But, nothing is glued in place yet.
  10. Next is to make the mainsail. I’m following the advice of someone that you should always do as much as possible OFF the boat. I noticed while doing my research that the holes I drilled in the boom and gaff jaws are wrong. They should not be vertical, but horizontal. So I used plastic wood to fill in the holes and drilled new ones. I had to make a “channel” on the inside of the jaws in order to add the parrals. I also added a block to the down-side for the mainsail outhaul rigging. This follows pages 99 and 111 of Petersson’s “Period Fore-And-Aft Craft. The block will be painted black as soon as the glue dries. I made the mainsail from the Wittholz plans; however, while I kept the length, I shortened the height. The sail was made from three layers of silk span. The middle layer had the ‘laces’ drawn with a pencil. The layers were glued together using white glue diluted with 10 parts water to 1 part glue. I ordered the wooden hoops from the Syren Cheerful model and they fit just fine. They were sown to the sail using a square lashing. I learned lashing from my days as a boy scout many, many, many years ago. I’m surprised I still remember how to do it. This photo shows the sail sowed to the gaff and the hoops slid down onto a piece of dowel the same diameter as the bottom of the mast. Next up is to furl that sail!
  11. Thanks Lou. Still thinking. Cheers.
  12. Thanks Mike. Thanks to all the 'Likes'. Cheers.
  13. Thanks Tom. The Providence models from the 1920s/1930s have various color patterns. No clear consensus. “See” you at the meeting tomorrow.
  14. The boat is starting to look like a sailing ship. I made the mast, boom and gaff. I want to have furled sails on this model, as I’ve done on past models. This means that the main sail will be furled with the gaff lowered. For that reason, I have to work on the mast from the bottom up. First, the boom rest was added to the mast and the boom and gaff made. Next I’ll make the main sail and its mast hoops. Then the sail will be bent to the gaff. The gaff will then be lowered and the sail furled on the boom. Because that involves sliding the mast hoops down the mast, I can’t make the mast top since the hoops won’t fit over it. I also encountered a problem with the gaff. Usually the gaff is in its hoisted position. But now it will be lowered and the gaff jaw must be as wide as the mast at its widest part. The resulting jaw looks a little weird. (The gaff is on the right.) Now I want to consider whether I should paint the mast, boom and gaff black; as well as the jib boom. I’m trying to visualize the effect of all the masts and yards in black. I haven’t decided. I was even thinking of adding a little more black to the hull. It is supposed to be a black boat. Please comment.
  15. Mike: You are doing a really good job on this model. Very precise workmanship. I like all the devices you create to assist in your project. Excellent.
  16. Quick update: I added the bob sprint shrouds. I followed the usual connections - a thimble and hook to an eye bolt in the hull, to a dead eye up at the end of the bob sprint. Pretty straight forward.
  17. All of the deadeyes, blocks and the open heart have been lashed to the bob sprint. Then the bob sprint was glued into place and the two bobstays rigged. Don’t worry, I corrected the placement of that pair of deadeyes for the bobstays. I’m basing my rigging on the standing rigging plan done by Charles Wittholz for the 1976 replica. He doesn’t have a dolphin striker, but has two bobstays instead. That seemed like a good solution to me.
  18. So now that I have made some adequate line; it’s time to use it. The first use will be the various collars on the bow sprint. I’m attaching a photo of the bob sprint and jib boom. Also there is one collar for the bob sprint shroud, two collars for the two bob stays, one for the top mast and spreader braces, and one for the main mast stay.
  19. Yesterday I made a real .035 line using 4 threads. It makes the line I made before with 3 threads look maybe like a .030. Today I made two lines of .025 using the Gutermann Mara 70 with 4 strands. It looks fine, although the second was tighter (and better) than the first. There is a difference working with the finer mara 70 thread, but I got used to it eventually. I’m now able to make an 11 foot line in about 30 minutes. The line today is using the proper color thread for running tarred line.
  20. Thanks Chuck. The 'kinks' occur when I cut the tail stock loose. I just rubbed them down with my fingers and they went away. My latest was better. I think I'm getting the hang of it. Thanks Lou and Mike: I use Gutermann Mara all purpose thread. My first efforts were using Mara 30, three strands only. Chuck's list has four strands to get a proper .035. Tonight I tried making a four strand rope and it looks like the 'old' .035 thread. I do think I need more practice, however. Cheers.
