Jond
Everything posted by Jond
  1. Post 15 Continue with decking as start other furniture The binnacle. What I have is a dimensional outline and many images from other builds of other period pieces. We know the top is rounded and we assume there is a compass in the upper section. It is a bit wide so perhaps it is open for a lantern or other item the helmsman would like to set down. The side view also shows it is raised on corner legs a little. Similarly, we have only an outline for the companionway to the tine cuddy cabin forward 115 here we begin the binnacle with the sides that will hold the roof and the center with doors aft that houses a compass. 116 here I cheat a bit by making a block to clad. I like maple for these inside blocks. Since there is no way to have it open on this model I am just moving ahead 117 now my first attempt for a compass. Surely it had a cover. Here is step one 118 now I cut off the front and file down the remaining cuts to make orange peels. I will bend them over and fit them onto a dowel with the end painted white with a few black lines. We’ll have to wait and see 119 now for the deck pads. I mentioned before I want livelier wood. Here I cross cut some maple and get the little spots. This is in bright light with no finishes 120 here using aperture we see the aliveness of the maple vs. the basswood decking. I like it for the feature. I fear to have ripped the whole deck in maple this way would have been too busy. I am not sure how to finish any of this yet and am beginning experiments 121 for the binnacle roof I use an under deck of 1/64" birch plywood. Here I glue one side 122 here I glue the second side. That by itself did not work. I had to cut loose and glue both sides at the same time using the claps to control the curve 123 I love sharing oops. In the blocking exercise for the raised deck, I forgot the hole for what is effectively a Samson post. 124 an experiment went well. I needed to recreate the square holes for the stanchions on the raised for deck shear plank. The sequence from left to right is hand twisting 1/16" the 5/64" the 3/32" drills followed by tiny and small square files 125 finally some visual progress as we added forward planking. Here we needed to screw clamp the hind end as there is a slight double twist in the plank. Cheers
  2. Post 14 Main deck part 1 I start this blog off sharing another oops 105 here I was going too fast forming the raised fore deck. I was laminating two 1/16” planks around blocking. You can see about an inch behind the forward clamp that both the plank rides inside the shear plank and forward rises up on the stem 106 so take her apart and do it again. I have added bands to hold down the double bend down at the stem and a clamp to hold the outer edge of the plank flush with the original shear plank. Now onto the decking. I thought about ripping some maple as the mottled look is a nice variant that might look more like the local pine, that I assume they used. I acquiesced and used some fir for the hatches to give some variation. We’ll see how it goes. Basswood is so easy to use, and just enough came in the box. 107 here we have the hatches and foot well all in, the laminated step for the foredeck done and the kit shear plank in place read to go 108 I have used these copper pipe caps full of nuts and bolts for harmless hold downs on decking before and they work well. until i hit one and it spills all over the floor. 109 here we add a few clamps and extra weight for the deep “swoop” of the deck 110 here as I complete the center planks forward of the hatch, I am also gluing down an upper shear plank on the fore deck. 111 here I am placing he first band of three planks on the main deck and you can see the roughed in upper shear plank. 112 some of these long planks needed a second go to be held down and make the slight outward curve. I also focused an making the nibs into the shear plank line up port and starboard. 113 It is time to look on the slipway as the main deck is in place and sanded. I need to complete the forward cabin/ gangway before doing the foredeck. 114 It is almost time to solve the mystery of how to finish and reasonable replicate the look of 1816. As I move into the need to solve finishing, I realize I need to make up some sacrificial parts and experiment. I have heard many suggestions. Do I use shellac and sand it to remove shine? If I used linseed oil what do I get. Do I try tung oil and other finishes. Each time I buy a new stain I need about a teaspoon and have half a pint to store. Anyway, it is a fun part to any build. I am used to using hand rub poly. I did here just for the floor of the foot well, so it does not get too dirty. I believe as i look at this view that the nicely finished mast has to go. I think a few more trips to the wood to get some small tree tops to trim down and see what we get. Much to ponder Regards
  3. Post 13 Diorama update I need to continue with planning before I get to the final coating of plaster and painting. In this planning, I am trying to visualize what it might have been like in 1816, the year after the war of 1812 in Maine. People were just coming back fiscally. I assume that a few miles south on an island that the ship yard was pretty primitive. Perhaps this was the first boat built there. The owner builder did not stay there for many years. 98 the ways in this view are trimmed only as much as necessary. The “stringers" rails are cut roughly square but not milled. I think I am not steep enough going into the water but with the scale so big [ 1:24} I have to give on something. I have cut the ties and stringers to show the slipway headed down into the rising tide. It is nearly high tide in the moment. 99 here at the upper end the roughly squared up beams are stacked. I think the small sticks can represent the stumps of trees that would not all have been removed. If I keep the wagon, I do not plan to do much to it as I do not want it to become a feature. perhaps gray stain like weathered unfinished wood 100 here we can see better that the water comes up about two more feet at the new moon highest tides, when the launch would be planned. All these ties would be under water. So I need dried seaweed on them . wow how do I do that? maybe string or cut up elastic bands painted black? 101 back up here I brought in my first attempt of a fore mast under way. The main mast is fully shaped, on a lathes and I have to figure what shade to stain it to be a natural fir plus oil. There would be lots of knots and things. 102 this view shows with the stick I brought in from the woods is much closer to what real wood would be. The dowel in the kit is too smooth to look real. 103 I am still experimenting. Here is the top of a dead spruce that I brough in and is drying a bit before I cut it down to see if it is better looking for spars I need to think more about how the slip way would have been built. Did they spike the ties to the rails [ stringers]? Chapelle said that iron monger was easily available. perhaps they got trunnels and drove them home. Hackmatack trees were common in a few areas up the tidal rivers, and for modeling that could be done with toothpicks. Either way I believe I need to square the whole top of the ties and do many more so I can better gauge their more consistent size. As soon as I figure that out, I will go with another layer of joint compound. I then need to think about embedding pebbles and stones. Unfortunately, they are frozen in under snow and it is only 16 degrees today. I need to get some different sponges to see what works for seaweed too. Cheers
  4. Post 12 Raise the foredeck frame the hatches I love experimenting. Sometimes it works. Here I need to raise the foredeck and extend the bow stem to follow the original design. Before moving on two points that were in the camera and not posted 91 this shot just shows the back and forth methods I used to get those lines transferred from one plank up to the other. Here I used tape holding the back with my finger against pressure of the compass as it extended above the bulkheads. This view shows that for a scratch build, one might run the frames or bulk heads up beyond their true height to give something to hold the tape or card stock being used to transfer those lines. also in the lower left I think the repair of the short plank came out ok. i will need to cut in the joint 4 planks below that, where I ran the plank through to avoid the same problem. The bits of fill are where the clamps did their damage during glue up....so much more to learn. 92 here I had an old devise intended to transfer lines to the side of frames to use for the waterline marking. I will do it again later so for now just a light pencil line so I can consider what and how to finish the outside. 93 here I used my iPhone to photo the bows of the 1821 schooner above and the 1939 Glad Tidings below. The two obvious differences are the raised foredeck and built out stem to support the bowsprit. 94 so here we go. I learned the hard way to add on much more than you need in the end. Much of this piece will be sanded off to get back to the right line, and I think we need about half of what I added. 95 Here I am doing four things in an effort to make the bow more line 1816. 1. First I soaked some 1/16 planks and am bending them to dry to the shape of the curved shear plank. 2. I am installing blocking to build up the fore deck. About ¼” at the step to 5/16” at the bow. 3. I am laminating 4 each 1/16 planks to form the step. 4. I have inserted a horizontal piece for the stem. I did this as it will be stronger. If I had planned for this stem from the start, I might have altered the kit stem to extend upwards. Perhaps another lesson learned. We’ll see how this looks. If the horizontal joint looks funny, we can solve by painting the stem. 96 here we are gluing two laminated 1/16" planks around the edge to make the raised foredeck. This is an experimental process as I will need to sand this in the horizontal plane to make a bed for the raised plank shear. 97 here working aft I have redone the framing for the revised deck plan and put in the standing well sole. I used black marker on one edge and applied rub on poly, so it looks like new pine that was used as it is harder than cedar to stand on. You can see the added framing to reduce the size of the well, hold the binnacle just forward and the added fish hatch before the binnacle Cheers
  5. Post 11 More planning for diorama and deciding the deck design It is time for our first guild meeting for 2010. This also marks a count down of sorts. I need to use these 5 monthly meetings as milestones to get this all figured out and done in time for a Memorial Day weekend opening at the museum store. So lets put things on the table and see where we are for the overall diorama. 82 here we are looking straight on. I am thinking to have the supplies and wagon over on the left side. I must get another figure or two and then decide what will be the action. Options include mounting the rudder, adding copper, perhaps working on deck. 83 from this angle I think there should be on going work on the spars 84 I am not sure what to do with the wagon. I may have coils of cordage and stuff that came from town 85 here is my current wood pile form the woods. I have started using the material for the “ties” -ways. I need more bigger ones for the “stringer”. I need to learn the vocabulary for the works in the ship yard 86 here need the post I am thinking of the scaffold / ramp to get on deck The deck design 87 what you see here is the deck preparations I made following the plan for the kit. There are two cabins. This all needs t be adjusted. The laid-out planks are for the decking. My guess is the prolific eastern cedar would have been used on such a local boat. 88 here we are at the Downeast Shipmodelers Guild monthly meeting. I went through the plan showing the three designs and got some ti[s. a general consensus was not to worry too much about exactness. Since the bow is tight I will be forcing the foredeck [ reducing the windless to fit] and there was a nodding of heads. One comedian suggested I bondo on in globs to bring the bow out to the correct shape. 89 here next to me is a beautiful Bluejacket friendship sloop. All of us applauded the work our new member has done completing this model. 90 finally we are back from a weekend to the kids [ to avoid xmas travel dates] and sitting back in the chair with a resolution for the deck design. The printout is same scale 1821 Essex Pinky that reflects most of what I am doing. The yellow tracing shows the combined work to locate the deck furniture. I think I am going to reverse my previous decision on placing the pumps aft for two reasons. The large binnacle takes up critical space just forward of the steering position. The pump in the 1821 version is close to the main mast. This is common on ships of the era too. It was the 1840 and onward schooners that show the pumps further aft. The deepest part of the hold is also right aft of the main mast. There is a raised wooden double decking around the main mast through which these pumps would go. So, using this section as my justification, I will place the pumps in the forward position. Next up, I am cutting up the tops of the bulkhead and added supports for the hatch work, and building the bowsprit
  6. Post 10 Deck planning Like many tough decisions a few days is sometimes needed. During this time I got the shop floor painted , moved more boxes and stuff around and went to see the real boat where we are having the bottom taken down through 22 years of bottom paint to the gel coat. She was beautiful. Now to superb or the first pinky in Maine or as we are about to decide the place holder for the first Pinky in Maine 81 here is compilation of three schooner deck designs. Through the wonders of CAD I have · on top or the starboard side the 1840 half model from Adams yard in East Boothbay · on the bottom or the port side, the 1821 Essex built pinky. · the yellow tracing is the Howard Chapelle 1939 deck plan that is the basis of the Glad Tidings kit. There are a few subjects to review and then the rationalization of how to move forward with this build. 1. It is obvious to anyone that the hull shape of 1821-1840 is almost identical but different from the 1939 cruising version. It is indeed quite pronounced. I can not try to tell anyone that the hull I have built accurately reflects an 1816 built schooner. I will need to find some explanation to include in the display to downplay this distinction but for the record the difference is there. 2. Cuddy and masts: Chapelle history included the Pinkies sailed further and further as years passed. The crew after 1840 reached seven. Thus, it seems obvious the 1840 plan has a larger cuddy cabin with a fixed chimney. There was apparently a large water barrel kept on the opposite to the chimney. The 1816 version I suggest would be more like the 1821 Essex with a smaller cabin. crews we often three. the chimney was removable and wood. That also means both the deck rise drifts aft a bit as does the mast from the 1840 version. In both versions the foremast is forward of 1939 Glad Tidings. So the main mast seams fine but the fore mast must go forward about ½ inch. looks like a drill job. 3. Hatches I am less emotional here and for no other reason that consistency will follow the 1821 design or port side. 4. The foot well. I will keep it inside the black marks, which indicate where I am with the Glad Tidings model. I will respect the smaller sizes and square it up too 5. Now to the pumps. 1821 Essex showed them near the main mast. In both examples for 1840 they are further aft. If one takes the cross sections provided on the plates, one sees that the lowest area of the hold is all along the aft fish hatch. I measured the drop from the Glad Tidings deck and found the line where the hatch will go is the deepest. A question I can not answer is do the two fish hatches lead to the same hold or are they separated. Thinking 1820 I can believe it was one big hold and the pump was located just aft of the bulkhead. The fish hold included the main mast. I looked at 4 other plates of similar boats in the Chapelle text and the pumps were more often aft. I will look a little more but for now they go aft. I need to think some more for a final decisions. I’ll let the floor paint cure and resort the shop. In the meantime, I will get the shear planks on and think about sealing the planks. I am still debating if the hull is all painted out at the time of the scene. I was in the woods this morning collecting small branches to see about making a more realistic slipway and scaffolds. I doubt they had perfectly milled 8-inch beams and planks to build the slipway 5 miles down the coast on and island. Sawmills were around for the schooner parts but the slipway had a short lifespan. All for now
  7. Post 9 Our whiskey plank, the crew starts to arrive and the deck study I am writing this to see if by doing so I can decide a few key items regarding both the diorama and the deck. Planking finish….I did not make 17 days. The results i feel are better than before and that is all I can ask for. Each model gets better and better. Regardless there are no more planks so a wee dram is due this evening. 75 here we are doing the top port side plank. 76 and here we finally got there, it is our glue up of the last plank on Starboard. diorama So what is going on with the diorama planning? 77 today both the first of the crew showed up. Thank goodness for ebay! They also brought along a farm wagon kit. Considering the actual site of the first build was not in town so to speak , I presume some type of wagon would likely have been needed, we’ll see if it works. 78 it’s late in the afternoon, sanding the hull is mostly done, so let’s see what it looks like on the ways. Also the first paint to show water. Deck planning This is a first pass. In early posts I commented that I am using this hull to get there. It is not in itself a copy of 1820 but a compilation developed by Howard Chapelle after his many years of study. Thus, the length of this hull needs to be used in reviewing alternate lay outs. To do that I have taken the three plates provided by Howard Chapelle, scanned them and put them into Turbo Cad…..my retiree budgeted $150 program as auto cad is too $$$ and Turbo cad does everything I want to do at this time. I scaled each plate, so the length of deck was a similar, 19.5 inches to Glad Tidings, and added dimensions to all the pertinent deck features. First I traced the shear plank on yellow tracing paper the Chapelle Glad Tidings plan as that is what to have built. 79 here, on a tracing overlay, I have taken the first plate, scaled it to the same length and printed it out a ½ scale so it would fit on one large sheet. I tok the pertinent dimensions of masts, bits, fore cabin and hatches etc. and marked them on upper tracing sheet and color tagged it. 80 here we have the results of all three plans color coded, so we can study and figure out what we are going build. Before we go forward, we need to decide a few more things. 1. All three plates of the 1820-40 pinkies have rounder bows than the 1939 hull that I built. I can't do anything about that, we just need to record it. i will make a drawing showing the difference, it is not significant but visible in the plan view. 2. All three plates have the foremast moved forward between ½ to 7/8 inches from Glad Tidings location. 3. Two plates agree and one moved the main mast forward. 4. Hatches are different and the foot well is different for each plate. I have not decided a final layout, but the 54 foot Trenton scaled down just does not line up with the others and I will throw it out. The 1821 fits nicely with The Glad Tidings dimensions with a little adjustment. The main mast is right, the foremast needs to go 1/2 inch= 1’ forward and the foot well just gets smaller. so today is to celebrate the last plank, the crew arrival and I hope a plan to design the deck layout cheers
  8. Post 8 Time for some history I have been rereading The American Fishing Schooners- 1825-1925 by Howard I Chapelle. I would say this is a needed read for any schooner modelers, and it must be in just about any library. I am proud to say Pinkies fill up chapter 1. I will not try to repeat much of what Howard shares but focus on the parts that link to my project. The process of pulling together my notes and writing them here actually helps me in the process of deciding what to build and what story to prepare for the talks and story boards to accompany the model next summer. We have a college student who is willingly going to plow into the Hodgdon family story and tell about developing the mill and adjacent boat yard. Our project last year shared the build of third generation Hodgdon who built the Bowdoin in the same yard one hundred years later. I mentioned earlier that the base design for the build is use of Howard Chapelle’s 1939 plans for Glad Tidings. Here we need to determine what was different one hundred years earlier when Pinkies were for fishing and not carrying tourist on harbor sails our distinctive owners on brief cruises. The obvious distinction will be on deck. One of the interesting subjects was that pinkies were used for both fishing and freight. Their key characteristic was their good sailing into the wind. As those of us lucky enough to sail here in Maine we know well what that means. In summer the prevailing Southwest wind makes traveling southwest along the coast very difficult. We fair weather sailors pull our boats in October as the temperature goes down, sundown comes early, and the winds pick up more speed. The early Pinky sailors continued well into winter. Thus, the high stern to protect the helmsman as they run down wind. 67 Here I share a few images of recent rebuilt tourist Pinkies. There are many online. This one I believe is Ardelle built in Essex. Many articles about her..a great story 68 Her is Fame . Note the bright colors, the swoop of the aft ‘pinked’ stern and simple sail plan. With all fairness to the rebuilders we need to look back before selecting our finishes. As I posted earlier, think simple black, some green and yes copper bottoms. Today they all have higher tech paint. In some reading I did last year about the 1850 era, I found paint in those days were linseed based and offered no antI-fowling help. Coppering I have read was very common and for a successful landowner and owner builder like Caleb Hodgdon he would have understood that value. He kept Superb for many years, so I am making an assumption that he had a copper bottom and he did it himself. We know Red Jacket was built about 50 miles northeast of here, and she as well as other bigger ships got their copper overseas. I may be crazy but I feel a 42 foot Schooner could easily have been done in Maine. This assumption is just that, and I would love to learn more about these finishing processes as we go forward. 69 Here on a few of the many visuals of pinkie plans on the net we see the introduction of cabins. Let’s face it, fish did not need a cabin. We need to look further. Glad Tidings looks like this one. 70 here is an unnamed model I found. It might be Fame looking at the coloring. Anyway the point is that there is a main hatch, a small forward hatch and a forward cabin. Chapelle talks about the variations in the forward cabin. The variation were based on cost and timing. The earliest had wooded chimney and it was years or perhaps money that brought the cast iron stoves aboard. As we got later in the century, I have read many stories of the Pinkies leaving here and neighboring Southport Island and sailing to PEI by going around Nova Scotia to fish for mackerel. The Pinky for that trip would need the forward cabin to accommodate over night and cooking and staying warm. Chappelle plans from his book. The American Fishing Schooners I include here scans of four of Chapelle’s plates. These with the accompanying text will help me solve the deck plan. 71 first is presented as a 1821 Pinky from Essex at 48 feet. That is about 6 feet longer than us. What I like most is the two fish hatches and small forward cabin. It may be the extra 6 feet that gets two hatches 72 this is 1840 and 54 feet. Clearly there are tow hatches and the forward cabin is clearly longer. I assume for a bigger crew 73 here we have the most interesting. The story is it represents an earlier than 1840 Pinky model owned by Boothbays Frank Adams in 1937. frank said it had a wood chimney that was removable . What I know as a Boothbay resident is that the Adams yard is literally next door to the Hodgdon yard. Today it is shipbuilders park. It is where two four masted schooners were build in 1890 and 1903. The length is 39’7” That is very close to what we are doing. Caleb Hodgdon, our subject builder brought Superb to East Boothbay, bought the tide mill, stared sawing lumber, invested in near by land and built his first pinky there next door. He build Pinkies in 1823 maybe there and definitely there in 1824 . There are most likely many similarities in these old schooners. My take is to follow it; there are two hatches and a small cabin. I think the two hatches is realistic because the boat was kept by Caleb Hodgdon for many years. He was not a fisherman. It surely did go for mackerel as the schooling was a big deal here in Gulf of Maine. But it was seasonal. So…. take a load of fish to Portland and bring back trade goods. 74 is interesting as it supports some good explanations in the text. The 40 foot Pinkies were three sail schooners that three men would take out for several days all year long. Our winds and seas are rough outside of the July august warm months when they slow down a bit as the water warms up. They did reef etc.as they sailed all year long. the need for top sails was limited to summer light air. He shows the main top staysail, called fisherman staysail on a Bluenose. the success and popularity of this rig was apparently great ability to beat up wind against the prevailing winds. One does not need topsails for that purpose unless very light air. One need to keep the boat flat as they did not have very deep keels as a racing hull does. Anyway this rambling is getting me ready to lay out a deck plan. The text in the book talks about the ease of getting iron works and the various designs of horses. They were a combination of wood with iron reinforcement to straight iron on the foresail of forestaysail. I need to study that more to decide. Also, I find it curious that only one dead eye is shown for each mast. The new rebuilds sailing today have more, but that could be all about coast guard requirements and cannot be a test. Even the great Bluenose II has an extra Main top shroud to satisfy the coasties. All for now
  9. Post 7 Planking part 4 getting near the end Now that we are getting near the end, and now that needed daily shop building work has drifted into the background a bit, I thought I would end this year with a flurry. As in the past, I need to be doing a few different things at the same time. Below I have started thinking about the diorama, started the spars, continued research into a 1816 version of a pinky and continued planking. Diorama The size of the diorama needs to remain the two-foot arena. I have a left-over piece of Birch plywood and several sheets of ½ inch chip board that are perfect one-foot lifts in scale. The actual site of the actual build is a cove area on the Westport Island, which is not far from here. The selected area would have had a gentle approach to the tide and land side as one must assume wagon access at least and ease of launch as most important. 53 here is an overview of the three-foot lifts cut out to receive a runway that fits the schooner. The kit conveniently provides a supply of extra wood to build ways. After completing the lifts, I placed the model just to look. At the idea. I think I can make this work 56 back to build up the ways and “runway”. The dark pencil line is the tide at the moment of the scene. It is near high tide as with 9-10-foot tides we need to consider the edge. I am guessing a bit as to what was done in 1816, but I assume the wood runway would have been placed at a lower tide far enough to get the schooner in three plus feet of water at high time. 57 We must also decide where is the schooner is being built with respect to the tide. They also would not want the water under foot twice a day as they were building. Also as to selecting the site, it is most convenient if the pitch of the ways makes the deck level….. Something to study when we go to East Boothbay for the second build where more focus will be on the land side. 58 how to build rocks and seaweed?? I am not sure, and this is truly an experiment. I like the ease of working joint compound instead of plaster as it is much more workable. I used up joint tape as a media over the hard lifts and applied a rough coat. 59 here I am doing the same to the remainder of the land side....I’ve nothing to lose except left over materials, so let’s just do it. Spars 54 now for our spars. I have a midi lather [ long story as to why] to build longer spars I need to rig something to hold the spar. Here a simple temporary bracket clamped to the bench 55 I wrap the end of the spar with electrical tape to loosely spin in the hole and focus the tapering at the business end of the lathe. Buying a set of chucks to fit dowels was a great aid in spar making as the ends of the dowels are not damaged as they would be with say three or even four pronged chucks Research I don’t have visuals yet, but I am re reading Chappelle…The American Fishing Schooners 1825 to 1935 and he had lots to say about Pinkies. I can say for a start that my following the kit design for deck house supports was a waste of time because all of his presented plans show a very different deck plan. This is going to be fun…… fortunately, the recessed cockpit did occur in the earliest designs and was needed as a foot well. Anyway much more to come on that review of the deck plan Back to planking I said a few things so far that turned out to be wrong….not surprising . It does matter which sequence one takes on filling the bands. I assumed that bending and holding planks on the center band after the outer two were complete would be very difficult. Well by working steadily down as I am, one runs out of bulkhead long before finishing, so accurately measuring the planks become difficult. Thus, the right comment would have been. One needs to choose which difficulty is easier and go that way 60 here I am with not enough bulkhead to run the masking tape to measure offsets. I took my last piece of kit planking, a large piece of ¾ bass and clamped it in place and did the direct marking 61 yippee it fit 62 this time was a struggle. I had to use strong tape to try to hold the piece while marking. I had to go into my supply of wood as this method used up all the wood before finishing. 63 cutting it out, one sees it was quite the bend. 64 wow it fit!!! 65 for the next strake I used a 1/32 bass wood that is very flexible and easy to handle. I have read many folks use cardboard for this approach. Regardless I then transferred directly to large sheet of basswood I have 66 Now I got clever…for me at least. There is only one more strake. So after fine tuning the plank, I check out the other side and mark it for cutting the other plank. Then I used the top of that piece as a guide to directly mark what would be the bottom of the last strake… thus I get two measurements out of one….not bad if it works. We’ll have to wait until next year to find out Happy new year
  10. Hi all Christmas is still going on but I am trying to keep going here too. i appreciate all your comments Keith..always a pleasure to have you aboard, your planking remains an inspiration to guys like me....maybe someday I'll catch up Chuck an honor...I will surely be visiting your web store for some line, as this scale really benefits from the array of colors and textures you offer. it will be fun as some will be coiled up I think as the topside will be under construction Joe welcome to you and thanks for sympathy on the struggle to build a shop. Models or home projects do not always mix well. We all keep learning and it is wonderful to start all over. I can not wait till next summer to get rid of the garage door and have a nice glass door to look outside and get rid of the generator. The bigger projects can head for the garage. I also think restricting my shop size for models to a single garage is good discipline. GL this build for me is a great opportunity to study and improve some basic skills. I marvel at the beautiful planking we see on many of these building logs and appreciated learning this easy technique at the conference. FYI the complete version is on the MSW site as a build log. I hope the next and last band leaves me with the ability to have some un painted. I then need to figure how to make it look like cedar. perhaps I will rip down some cedar for the last three strakes????? 51 here i am sneaking in the first strake of third band. 52 these ends are getting tricky. the bow clamp is a reglue to get the plank into the rabbit. happy new year to all
  11. Post 6 planking part 3 complete band 2 I am continuing along in the run up to Christmas with a hope to be able to get the majority of planking on by the end of the year so I can invent the diorama and have a full three months for that part of the first build for the early Pinkies of Boothbay. I find as I work my way down the planks get harder as the process gets more familiar. I keep waiting for the easy piece. 41 we continue to find the need to work out different clamping on each row. 42 here I have added blocking to avoid the damage to the soft bass wood from the clamps 43 this strake is the last one I can get to with the array of clamps 44 here I brought out again the screw in clamps that damage the bulkheads ahead of the game so to speak 45 here we have had to go back to soaking the planks and then to clamp them to dry before gluing up. This strake is the end of band two 46 here is my planned repair for the worse of two sides where I put in the short piece and should have run through the longer piece and after gluing cut the joint. The next time, 4 strakes down I did it right. We need to wait to see how this repair comes out. 47 here we are low in band two and have our most drastic curve. I had to lay it out on ¾ “piece. 48 see it after the band saw cut out. In scale this would have been a 15-inch plank. I don’t know, but I do not imagine this process is an exact replica of the real thing. In my Bowdoin log you can see we went to the local yard where they were installing all new planks on the real Bowdoin. Their step by step measurement was similar but the one hour of steam per inch thickness of plank made the bend both ways. I did not see them wasting so much wood. ….anyway just a thought 49 here we are measuring the last strake in band 2…note it will go four bulkheads 50 here we are with strake 1 in band three, only 2 bulkheads. I am going to try to do this short piece but am ready to abandon if the joint does not stay true Cheers it is Christmas eve and much to do
  12. Post 5 planking part 2 Remember the silly goal of 17 days for 17 strakes? Not likely to happen as we are still building a new shop, Christmas is coming etc. We’ll do what we can. Two bands to go with 6 strakes each. 31 completing Band 1 I have decided to keep going down. Others jump up to the top, I think with the preplanning that comes with this method, it makes no difference. Here the clamping is getting harder so why not keep on going. 32 up forward we are having double bends. I tried soaking planks in plane water for a while. They were easier to work but the clamps squished them. Notice the third plank. Since these are so thick, 1/16” I do have the sanding option. Since I want to have some copper on the hull, I think I just found where it is going. This plank also completed the first band of 5 strakes and one steeler. Thanks to the kit design for making that decision, as it does what I needed and helps my schedule that needs to make this a possible 4-5-month build. 33 another oops. I followed the provided layout with the very short piece at the end of strake 5. Lesson learned is to run the plank all the way through in this case and cut in the joint after. I see after a few more strakes the best fix. I am thinking to laminate two pieces over and to feather them out. Alternately I could remove the planks, so the joint is one or two bulkheads away. Also, if I show partial copper, paint and things, I could simply hide this oops. The other purpose of this photo is to record the final measure and fix step. The planks we cut out on the band saw and sanded. Then fine tuning and rechecking of the dimensions. The light pencil line comes from the tick marks on the bulkhead. The piece is next to be sanded true. 34 Here I took the piece we just sanded true on one side, and placed it over on the other side to check it out. It fits yippee….now we trace it on a blank and head for the band saw. Tracing, cutting, sanding rough and in less than five minutes, we are fine tuning it to this second side. this side has a worse defect at the joint of the short piece... a fix is on the way. 35 off to the assembly desk for glue up and clamping. I learned by now the hard way to dry clamp, so all is figured out before glue. 36 here we have a delicate piece and I am proud to have squeezed it onto a ½” blank. Oops our foreman must be sleeping. 37 In several recent discussions many of us complain that power disk sanders and even spindle sanders go too fast. Some slow down but in doing so loose power. One enthusiast in our guild built a hand crank disk and he loves it. I took a 150-grit sanding disk and stuck it to a small rounded piece of plywood with two sides wrapped. The wrap is good for corners and more importantly to give me a good grip. I used this to fair the deck too. The curved block to the right is just that. With 150 grit glued it allows inside edge of planks and certain aspect of other curved sanding. 38 even more fun fitting the clamps. I think I am going to need to start grabbing the bulkheads and hold some small blanks to hold the plans during glue up. 39 here we have two end planks on both sides in glue up. Later today maybe we get the middle one done….then it is almost Christmas tree set up time. Update on the shop build. 40 I got the power tool bench and bookshelf in. I also got my modeling library back up and emptied ten boxes today. Everything is still a mess but working is easier. I lowered this new bench to 34 inches and that works for the tools and is more comfortable than the old set up with three different heights. All for now
  13. Andrew just caught up with you and love the work you are doing. the deck looks great. I love the rigging solution for small blocks. cheers Jon
  14. POST 4 Finish the first planking band part 1 I am so excited to have learned this new method of planking, I am logging much of the progress. Probably too much for all you skilled builders. It is a real learning process for me so here we go. Oops and all. 22 Time to complete the first garboard plank. One comment is the instructions from New Bedford was to use a soft pencil compass, so a continuous line can be drawn. I could not do that as my old drafting equipment has hard pencil lead. 23 here you might see I took the compass and placed dots at the bulkheads and mid points and then with a thin sharpie connected the lines. That is the top line. I then took a divider and on this first attempt went to every station, where in this kit, and not normally available, someone has already laid out the planks. I took each point and transferred it to the tape. 24 I simply take the tape and apply it to a blank plank. here i am conservative and use a large blank. 25 when possible I work both ends at the same time. The purpose is to place either two or the three planks that make up a strake on both sides per day. That would mean 17 days to plank this hull. 26 here we are forward adding the last garboard section. these clamps worked on the mid section but not here as the plank twisted 27 clamping is an adventure. Some oops here are coming as the clamps grabbed this soft wood. 28 here our foreman is checking the work on the center third plank. 29 here we think we are doing great. But those two clamps crushed the edge of the planks. My solution was to use an emory board to file the edge smooth 30 here I brought out the screw clamps that some experts advise not to use. There are always a few areas that clamps just cannot get to hold. more on the way Cheers
  15. Great job! It is fun to see her grow so fast before our eyes. I am using this same model to try to depict an original built in 1816. thanks for sharing jon
  16. Post 3 the first planks My excitement is that I am working again, not the little progress. Each time I want to do something I have to try to go find the tools. Example: I learned to go to scalpels last year or so. The issue is I have no idea where they are. You can see on the table and old exacto kit. 17 Before planking I chose to complete the under-deck work. I was not too careful with alignment of the stiffening blocks and two of them had to move to get in the cabin supports…oh well that is not all bad. 18 I used a small plywood sheet with a 5" sanding disk glued to have a faring tool for the deck. After cleaning it up, I had several low points. I added in 1/32 strips, and after gluing I resanded the deck. 19 another oops. I love recording oops… I prefer to notch and counter sink the deck support beams instead of cutting each one and gluing it fore and aft of each bulkhead. I must have gotten interrupted because the starboard side aft I cut the slots on the wrong side of my tick mark. Fortunately, I simply added an outer beam, and all is well. 20 pop the cork we have our fist plank in place. No whiskey until the last one. 21 that first one went OK on both sides, so here we go with number two. I found i need to leave a little extra when cutting as there was trimming needed to get them aligned. i look forward to using the technique learned in New Bedford after completing the straight bottomed garboard Cheers
  17. Keith happy to hear from you here. I love to drop in and see your work too.. as soon as i get the 1st Pinky [ Superb ] planked I will be back here rigging away, since that Pinky will be on the hard with a crew trying to rig it too. I will need more figures to do that. cheers
  18. post 16 a new shop and sitting on the side for a awhile In another build of 1st Pinky Schoonerin Boothbay I share both eh house move and deadline for that build. As we are heading toward the end of the year I want to update what we are doing on this build. Call the ship build vs the schooner build. Ap 100 I decided to completely build the main mast in place. So here I started with the forestays. Ap 101 Here I went ahead and put on several of the top shrouds. I learned a few tricks while in new Bedford to help speed up ratlines and I look forward to trying it here. Ap 102 here is the siding story. As recorded in my other log, I have moved and am in the process of building a new shop. Aphrodite had a nice car ride and is now happily resting on the shelf of the new rigging desk. Once we get through the holiday rush and the shop is mostly up and running, she will get some more action. I also have a new side mission as a version of Cutty Sark just showed up and I need to do a bowsprit repairs. I will share that here this winter too Cheers
  19. Post 2 second start in new shop. The impact of building a new shop is overwhelming to one’s schedule. I spent the month of November trying to get enough done so that by now, early December, I could begin to focus more time on this build or perhaps these builds. These old bones don’t get as much done as they used to. And I am sure the drywall sheets of today are much heavier than they were just a few years ago. The next ten photos are to record this month building the shop in the early stages. O4 this is the starting point. The home we bought is built into a hill overlooking an active water way. The inner half of the lower level is all basement carved into a ledge. One end has a garage door that I hope next summer to change into a glass door. The first job is to skin the concrete with insulation and drywall. That also gives us the back supports for both benches and shelves. and lets the heating system work a little less. 05 the water side is a finished wall running the length of the house. Guest rooms and family room are on the other side, so dust and smells will be under approval of the rear admiral, I fear. I plan to do fiberglass and any other stinky stuff in the garage, which is fortunately heated. A shop dog is great part of the arrangement. 06 the lower wall is out a few inches to allow electrical work and a long shelf. The bench frames are simply screwed to the wall framing. 07 call me old school I just love varnished pine for the benches. You can see the insulation on the walls that continue north of the shop and will form a long hallway and gallery. The black can that’s hanging on the wall is a whole house vacuum. I am thinking of maybe using it for dust control but need to study it. 08 the bench is in and will fill up with all the power tools on the inland side. 09 the water side has jogs and will allow a bench nearly 10 feet long. This is where most of the work will get done. 10 and here is the restart of the first schooner. The upper shelve framing is on the layout table so one can see the splitting of time will continue for some time. 11 finally we have the planning and rigging desk. Here one has a comfortable chair, needed to tying all those knots. The old bureau holds clamps and all kinds of things. 12 the first shelves are now up and I am finding a need to get things out of boxes even if this is temporary. 13 here we are finally getting to work on Superb. I have been working on the rabbiting and am now ready to get the keel stem etc.. in place. Each time I start something I have a panic to try to find a tool, glue or something that is hidden away in a box. 14 Having just been to the New Bedford conference and enjoying all the experts, one thing of focus was how to do better planking. A recommendation I took away, and am using here, is to glue dark thread to identify the planking bands. It was fun to do, I have never done it before, so I am optimistic looking forward. 15 finally we can get out the plans, sort through some materials and think Also, as a note the ship model on the shelf is one of my builds [ Aphrodite] that is still active and will get going but does not have the deadline of next summer showing. I will continue to post there as and when I can get to it. 16 in this detail shot the red marks are the layout of butt joints, the pencil ticks for the lower band of planks and rabbit grove looks deep enough for the first time[ we are still learning]. I am going to use this model as a learning tools to improve my hull planking. So this concludes a month of work. Not much schooner progress and heading into the holidays we all know what that means for the next month. I hope to plod along and make progress. Cheers
  20. Dear Highlander welcome aboard . Maine nautical history, especially centering on ten mid coast are where I live, adds much joy to the builds I am trying to do. regards
  21. Post 1 early November, the process begins Superb log a 1:24 kit bash This project is intended to celebrate the building of the first Schooner by the Hodgdon family, now in its fifth generation of ship building on the Boothbay Peninsula. There are several firsts that could have been chosen as the builder started in 1816 and then migrated east across the peninsula and then south to the East Boothbay Mill area over these first ten years. Before we make any decisions, we must first thank and give credit to Barbara Rumsey who tirelessly researched, and fortunately for us published her work tracing this history around Boothbay. In the Book Hodgdon Shipbuilding and Mills, A documentary History of the first hundred years, 1816-1916, published in 1995, Barbara tells us the story. To help with this upcoming exhibit, my first thought is to build a diorama depicting the final stages of building this schooner in the late spring of 1816. To do this work I have expanded research into re reading sections from some favorite authors. There are no surviving half hulls and many of the Hodgdon firm’s records were burned in a fire many years ago. I felt that it would be safe to take the plans created by Howard Chapelle. Even better I found that there is a recent kit using Howard’s design for the 1939 version of the pinky that was built and he apparently sailed before WWII. As I begin this project, I am in the process of moving to a new home and needing to rebuild a shop from scratch. That means lots of good news in the opportunity to improve the working environment. but an obvious crunch in time for me to have this done by next May. I bought the Glad Tidings kit with its great set of his plans. At the 1:24 scale it represents 39 feet long deck and 40 +/- top of rails and if I go back to the peak of the stern I can get to 42ft.?. This is one of those rationalization conversations. The first decision is what convention to use for hull length. I will quickly take a leap of faith that these history books and lists use the length of deck from inside the taff rail to the forward most point of deck. That was pretty well confirmed in the schooner books I read while researching earlier builds. But what records did they keep confirming what they meant for the tax records, used in Ms. Rumsey’s research, to determine lengths of vessels. If I want 42 feet, I have some choices: Do I build it as is? If I am wrong, it is only a few percent…so it should be ok. But then a diorama with a schooner roughly 29 inches long including all rigging is tough to do. On the other hand, I do not have time to recreate too much. This is not a build to go to frames unless I want to show something under construction. Do I scan the mold plans and adjust the scale to replicate a 42-foot schooner? I could drop to 3/8 scale = 16 inches +/- on deck or even ¼ scale = 10 inches deck to roughly 15 inches +/- overall which I think in the end is easier to do in a diorama if I want to show the launch. · The second decision is …am I building the first schooner built in Boothbay or by the first builder of Boothbay. Superb was not built in Boothbay but next door by a Boothbay builder… the first schooner he built in Boothbay was Ruby in 1823 maybe or Betsy 1824 surely. Both were pinky shaped and of similar size. So, we have the boat, we just need to settle on the name and town. Diorama option 1: build at 1:24 To build the kit hull through the deck. Then to show construction activities around the schooner. Perhaps rigging a mast and or the rudder. This would use up the kit material and get to a timely delivery. The problem is with the large size there will be little room to have things around. Think of the huge figures etc. Diorama option 2: build the above in 1:48 There are other considerations. If I simply use the plans for this build, what do I do with the kit. I find that Hodgdon built a 59-footer just 13 years later after they had arrived in east Boothbay. The largest Pinkies were built around 1831 at 69 feet. I would say looking at the list however that was an odd ball and not the norm. Also one does not just up the scale, one needs to research what was stretched to add 20-25 feet to a 40 foot schooner. After that large build, the “pinky’ classification stayed around the 39-42-foot version. That all makes sense to me because Howard Chapelle was a lot smarted than me, and he chose this size for his developed plan. Even so to build bigger would extend middle sections of the hull in some way that cannot be my design, so do I use kit parts for my material inventory and trash the molds or go ahead with one at 1:24. Diorama Option 3 only use the plans and raw material. I am considering to build at 1:48 or 1:64 Superb was believed to have been built on Westport Island. That is about three miles west of us. At the time it was part of the town of Edgecomb, which is the northern third of the Boothbay peninsula. Since after the move to East Boothbay in about 1823, the Hodgdon boat works remained there until today. 01 Here we have a modern google image of the east Boothbay harbor with the active Hodgdon boat works. This property was purchased much later than the period we are discussing. It was infact sold again last year to Washburn and Doughty. In the 19th century the Hodgdon boat works included all the land where the marina is now located. That was sold in 1970. Not long after that ventrue it became ocean Point Marina. The adjacent ship builders park is the once owned by the Reeds but changed hands a few times. The famous Adams yard where two four masted schooners were built in 1893 and 1890. was located where today Washburn and Doughty builds large sea going tugs and fire boats for offshore oil rigs. Caleb Hodgdon both the builder of Superb and its owner relocated to start the Hodgdon Mills in what is East Boothbay today. He also maintained ownership of the 42-foot Superb for many years. So perhaps I scale down and scratch build a 1:48 or 1:64 inch water line model resting on a mooring to be Superb and then a partially framed hull in the yard being build and I change the year to 1824 and call it Betsey or Ruby that were built there. I would use the rigging on the moored vessel and have the deck and a few things completed on the model. I might just bread and butter water line up the build up everything I am not building on the new one. If the new one is under construction, I can have incomplete planking and not worry about copper and all the other niceties that I see in the painting I have been studying done by Lane As to the look, I am going to depend on artists views of the mid 19th century and not the new reconstructions of brightly colored Pinkies that sail today. 02 Here we see one of many internet photos of models and that closely follow the paintings on coloring. 03 Here is an internet image of the proper coloring of the era. I say that because there are several contemporary paintings by lane also posted that clearly show the conservative coloring [black] with the copper bottoms and dark green under the wales. It is interesting to see all the bright colors of the later versions. Action for November I am entering a month of moving from one house to another and building a shop. I need to put together the frame from the kit and get going. No mater what option this build ends up with, the kit needs to be built up through the hull basically as intended, so here we go. RC follow up options. This is my overall plan to have scaled details static models at sensible scale and the simple built up RC versions. No more Bluenoses too detailed to sail at 7 feet long Since I may also build a 1:12 radio sail pinky after this diorama, I even suggest three possible builds all on one log. 1 build out the kit to have something to show next spring likely to be built through the deck and men working above deck 2 build the diorama at 1:48 or 1:64 with two boats. With enough time I could draw the fill in frames and have some areas without deck and planking as a better view of the building of a schooner. 3 build the rc. At 1:12 I plan a similar rebuild of Bowdoin as RC but that is another story. Much to think about I think time will be the ultimate factor in this decision. I have no tools now, so thinking and sketching is what I have. This writing as usual helps, me focus and draw conclusions. The plans are even packed in a box, and I have no idea in which one, so I have nothing to scan to play with in cad. I have no idea if this is a kit bash or a scratch diorama within which I use some of the kit. I am not building Glad Tidings as advertised, but will surely give them credit. I spoke about this posting question to colleagues at the New Bedford NRG Conference, and they agreed it is sometimes perplexing but not too important. My conclusion is I am kit bashing of Superb into a diorama as per option 1......we'll see Cheers
  22. Pete In my beginning stages of learning to build scaled sailing models, I read somewhere that the rigging needs to be down sized roughly 3/4. considering the difficulty of managing sails, that are not self tacking, this is partially solved by leaving off some of the sails. for the keel I prefer the added keel for two reasons. typically one needs 10-15 pounds of weight and also with a 50 plus inch boat needs the depth of 18 inches. that means adding some embeded bolts but being able to display the hull out of water in a realistic way. similarly I add to the rudder a removable piece, because at scale the rudder will not work well. the size for me is to double it. I sailed boats in the 50 inch size and they work well. they have relationships that are easy to find in the class specifications. I would suggest AMYA website and the US vintage website for the serious racing folks. Through those sites one can find a class of boat in a similar size and see the area of sails vs length of boat etc. I would then reduce sail, not shorten mast and boom. in my Boothbay Harbor One Design build log I shortened the jib for self tacking and then main to balance the jib. I fully intended to sail Bluenose but once I got into the detail, I feared seeing here go blub blub and she has stayed dry. my next venture is a double build of a schooner so I can have fun with detail on one at a smaller scale and build the sailing version more simply. sorry she is scrapped. maybe someday another go best if luck
  23. I logged on to catch up and continue to enjoy your progress. you make the ratlines seem effortless. Now with the fore and aft stays she really looks great. thanks for sharing jon
  24. ps on above simple masking tape on the outside of the molded frames and using drilled toothpicks with glue through planking into the molds allows separation in the removal of the molds.
  25. Pete I just found you again as I wanted to see how you have done. I have been away from modeling about two months as I have moved to a new house and am in the rebuilding of the shop. Considering your recent "stop work order", I want to say a few things about my bluenose build 1:24 if you run through the first few pages of my log you can see that the frame stage, where you are now, was hung on the ceiling for roughly ten years[ 2002 to 2012 before I picked it up and did the hull. then it was a few more years before I continued topside. These pauses where due to work mostly, but the time between phases also gave me time to sort things out and by working on other projects be more prepared to continue. one thing you might consider when you pick her up again is to use the bulkhead frame as molds as I did and as I was taught at the Wooden Boat School [ same as the magazine in Brooklin Maine]. in my early pages you can see all the drilled holes in the plywood bulkheads to promote the Dremel saw to cut them out of the complete and fiberglass reinforced hull. then one adds light deck beams and very light deck and top side structures. the plywood keels section would also be cut down to maybe one inch inboard of the hull to remove more weight. the coat of fiberglass over the light planking makers he rock solid and removing all the molding makes her light. as you do it you add cross beams for the deck. the deepest screws that go in sideways to the keel /keelson should be removed and only glue any where you can not get to them from above after planking no mater what you do, the frame at the current stage is great nautical ceiling art so please keep her around for a while. best of luck on whatever you decide jon
