Everything posted by Jond
There is not enough to write up a post yet, but i just want to log that I almost made it through the spanker saga. I tried a different low profile sky light and think I need to change all three to a lower profile. I have no way yet to tie off about twelve lines at the base of the mizzen mast. Maybe a new fife rail forward and sides with an open back. Now it is June and we are sailing in a real boat and doing other summer things. As I have time to peck away i still hope to get on with this first attempt of a ship. I think the general design corrections are in place for the spanner on a the extended cabin poop deck configuration. 198 this view is just to show the boom and gaff are made and in place and tied to all their lines. the sheets are a bit tight and i will adjust the boom up enough to squeeze a low profile skylight underneath. cheers
- 57 replies
Post 6 Completed 2015 rigging exercise This posting completes the look back into the work done on the RC version of this build through 2015. Following the build, I went on the Bluenose Journey and built and sailed the BHOD sloops. As I went through each stage of those builds, I came to the conclusion that it will be a challenge to fit this schooner out for RC. We will talk about the specific issues later, as I try to figure out what to do to get her wet. Now back to the build 41 here we see the foot of the sails laced onto the boom and the birch plywood hoops. This is pretty normal although many RCs like to to use wire jack stays to hank the sails close to the boom. 42 looking down the deck we must figure how we will use a single servo to let out and pull in both the large main and the small fore sail. Also I is apparte3nt I need to solve how to control the rudder. The rudder shaft comes up on deck near the mainsail horce on the transom 43 I added scale figure cut outs and a helm for looks. This is my first home made wheel. I have learned a lot since then. 44 here we are preparing the foresail. Topsails and jibs are on the table too. 45 as on my other builds I frequent our local supplier Bluejacket for most of my loose fittings. Working in this large scale I like the metal fittings. 46 here the foresail is sewn onto the mast hoops 47 we see the value of the stronger fittings. This process is where I got into trying hemp craft line for bolt roping. It is ok at this scale but I had to redo it on the 1:24 scale bluenose as it was just too big 48 here goes the foresail 49 here is the attempt I made then to control the rudder. The brass square tube penetrates the housing to an elevated servo. Who knows, it might even work. the sail servo is set up too run lines on deck. that is not normally done but access below decks at this stage did not allow for a simple solutions to be hidden. 50 up on the foredeck, I made some anchors, trail boards and the windlass / winch. 51 here she is as she sat for several years in the middle of the sail loft in my old shop. She is still over there today as part of the “staging” one needs to do for the hopeful sale of my past home. Here is a summary of the long sage followed by a look forward I bought this plan and kit in 2001. I started the hull for the larger boat in the winter of 2005. I restarted the build in 2007, as covered in this catch up log. As of today, I could say I have 15 years into this project. That is nuts and why I have taken it off the shelf so to speak. My plans for this upcoming build are to peck away at the small 3/16-inch version with a focus on setting up the sails and rigging design before getting back tot he large version. Next winter, though I will get into a few other projects as well, I have intent that one project is to complete the sails and rigging, so next summer we might try to sail her. All for this catch up. Next will be a some progress on the rigging design model
- 23 replies
- dancing feather
- pilot schooner
Post 28 Second attempt to figure out that spanker As usual we need to go back to the basics. We must also accept that what we have already built might just not be right. First up is to ask our expert Mr. Crothers how he rigged a typical ship 195 is just that, the running rigging for a typical ship. I have cropped enough to make a comparison with the picture 191 above 196 here I pasted the two photos side by side and scaled so they can be compared. A few observations The mizzen in the typical ship is further aft from the main mast. The distance from the mizzen to the stern is much less on the typical ship The potential luff on the typical ship is much taller, making what the eye says is a reasonable spanker sail. Aphrodite has, by Alna’s design, a cabin and sky light, and my interpreted fife rail forcing the boom way high. Something has to give. My current thought is to take off the boom [ already done] and remove or at least lower the sky lights and remove the fife rails. At this scale it will be very difficult to put cleats on the mast for the 8 lines and actually tie them off. I will have to have some liberty there. Perhaps eight eyes with simple hitches buried under coils of line. 197 this is my next direction. Reconfigure the boom and lower it as much as possible. Just a note... the port shrouds on the mizzen got shredded and broke, so I am going even further backwards. oh and the wheel fell off too. Cheers
- 57 replies
Post 27 Getting organized. seeking a path to do the rigging and how to do a mizzen One of the joys of doing this build without complete plans is the need to regularly search and discover a plausible solution. Unfortunately, it has again happened after the first attempt. First up is look over the “mess” as I called it and figure out a sequence. Then stick to it. If I glue something or paint something I must not jump to another extraneous part and work out of sequence. That is one reason I started up the other build. As to the sequence I feel a little better about starting in the middle and working out and working from the deck up. The little example of what had to be done to get the pumps installed was a great learning tool. So off we go. Last time we took a hair cut and went back a few steps 186 here is a milestone. All fore and aft standing rigging is in place and there is a clear list of items missing on the port and starboard shrouds. I will now work from the deck up. 187 first up the boats are now going in and are lashed down 188 looking aft we have a definite problem. How are we going to tie down all those yard lifts and other lines? The extended poop deck and house remove deck area around the mizzen mast. 189 looking at the rigging diagram they agree we need fife rails. But again, we have a skylight in the way. These are not indicated on the plan. 190 so being creative I reduced the skylight [ love those band saws] and built up another fife rail. I am used to trimming down some maple and using the mill to drill straight holes. My new problem is the acrylic craft paints I use are drying out and get lumpy. Just another pain to deal with. A most important sight in this photo is where I followed the masting instructions of our friend Mr Crowthers and came out with a lovely spanker boom with yokes and a table for the mizzen mast. I felt I was back in schooner land where I am much more comfortable. Looking at it though I just cannot believe it to be right 191 I look at the proportions and cringe. A yoke on the gaff would be ridiculous. Also starting above the cabin, we are a few feet shorted in the luff. Would it really have been so long? 192 back to the books. Here we have an image of a more plausible solutions. There is no full explanation, but a small mast is set aft of the huge mizzen to take the small spanker sail 193 here I am with my interpretation. I have a band over mast band forming a goose neck for the spanker boom that simultaneously houses the “{?????} “small mast for the spanker. 194 so as this week ends, I had to make other decisions. The spanker sheet is intended to go to both port or starboard rails over the steering gear. The bitts I added to ho;d the bumkins will allow tying off the sheet. That means I kept the boom at the length given in the table for Alna our prototype. Looking at the shallow slope of the topping lift and then imagining the block of the gaff peak halyards this will be a strange looking sail. I need to do more study on this part of the build. perhaps I shorten the spanker boom and have the sheets on the end of the cabin roof. All for now
- 57 replies
Keith thanks for you fortitude to continue to drop in. I must say that just because i have become more comfortable in the world of Schooners, that a ship build is the place to go. it is amazing how much more there is to learn about how all parts of a ship work and what they are called etc. The sequence too wow ..... this rebuild started as a throw away. A pigs ear was an over statement. if I get it back to a pigs ear that will still be a worthy journey for me cheers
- 57 replies
Post 5 Rebuilding rigging second time and starting sails In the fall of 2015, I spent some time re-rigging the schooner using much newly acquired skills. They are truly basic bit to me they were new. 31 to make strong hoops for sailing I took 1/64 plywood strips, soaked them to make them more pliable and bent them around a plastic electrical conduit that was the right size. After drying they are glued and wrapped again. Then sanding and varnishing and they look almost real. 32 I learned to cut out the big hole in plywood or bass sheets before sanding to the outside diameter of a ring. 33 here we see the Sitka spruce mast with the ring table for the boom yokes. The ring on the mast in the photo are the first generation of electric conduit cut in slices. The replacement wood rings are on the bench. 34 the first-generation mast head broke. Here again I drill the inside holes first and the cut and sand to shape the outside. I am obviously cheating as there is a slot and not a proper square hole. 35 here we are replacing the mast head. The crude attempt of seizing the shrouds looked good to me at the time, but now I need to think more about the right scale. 36 I needed to make up cabin and hatches for the deck housings. Here the hatch too big [ the pencil shows where it should be]and needed surgery. 37 here I am gluing up outer coverings. They must be removable Now to the sails I spent some time and consideration to reduce the sail area so the sailing of the scale model would be more realistic. From my reading there are many opinions out there, but a 15% reduction seemed to make sense 38 I laid out the sails on a template and the traced the marks to a plain muslin . 39 here is the first one made and sewn onto the loops 40 and here we set up the main and see the deck cabins More to come
- 23 replies
- dancing feather
- pilot schooner
Keith i use the would skill loosely. i love it when i think I am rolling and then oops cheers
- 23 replies
- dancing feather
- pilot schooner
Post 26 Big oops again….top mast rigging One good thing about all the other activities that come into our lives this time of year is the time to reflect. Walking by the work bench I kept thinking something is wrong. I needed to take the time for a fresh look into the rigging plans and be sure I have the big picture right. Well I did not 181 look here without reading ahead and see if the obvious issues hit home. The issue is the relationship of the lay out of the top gallant and royal mast, or “pole” as they call it in the book. I went back through the tables and then realized what I did wrong. I then redid the clac’s to see how best to fix it. Over simplified, the main and fore “pole” was made up with 24 feet of top gallant, 16 feet of royal and the top post roughly 5 feet. That means the shoulder for the stays at the top of the topgallant are just over halfway up the pole 182 uses a simple method to point out the errors. Basically, the shoulder is correct on the main and mizzen and way off on the foremast. The compounding error was to carry the shrouds and ratlines above that line. As I understand it now the crew apparently did not climb up to the high position of the royal sails but must have lowered the royal yards using the lifts so the yard came down. How else could they have gotten there to furl the sail. Anyway, it is all wrong and I need to start that phase again. 183 Some good news though… I got the last fife rails and little pumps installed. More importantly I successfully tied off the first few lifts. 184 I also decided to add some glue to the base of the mizzen and pull it a bit aft. All the tension from added stays was pulling it forward. I normally do not glue masts. Perhaps at this small scale where the consistency of tension is less consistent, it would be a good idea 185 here we are having taken a haircut. The foretopgallant mast is being replaced and all the shrouds are gone. I hope to get it right next time Cheers
- 57 replies
Post 4 2014-2015 first rigging of sails The pace of this build continued on a spotty basis. In the spring of 2014, I spent a little time as I got going after retirement to roughly rig the spars. It was not a great result, but I was cutting my teeth so to speak. First, I needed to decide what were the sails going to look like. I had two images to work with 22 this is a cropped view of the kit design giving intended dimensions. I knew I needed to reduce the size of sails to about 85% and simplify them a bit for RC 23 this image I took from the book on Pilot Schooners and is what I tried to make. Obviously, there would be too much sail but off I went thinking I could cut them down later 24 here we are at the entrance of the shop in the spring of 2014 with standing rigging 25 the view on deck shows the roughness of the work. The full focus was learning process and the results were not great Several months passed and I decided I needed to rough out paper patterns for the sails. 26 here we have the paper templates all cut out and this is how Dancing Feather sat for another several months as I worked on the BHOD racing sloops 27 part of the learning exercise was for a standard easy to use stand for RC sailing. This strapped box goes with us to the shore and carries loose parts below and is steady to support the fully sailed model outside 28 here we are on the new stand and as a few more months went by 29 now in the fall of 2015 it got to decision time. I removed everything as I knew it was no longer up to snuff. The little red wagon is to carry the schooner to the shore. Other photos showed Charles Notman in the same wagon. 30 next up was to finalize the design of the added rudder and keel for sailing. This built was to achieve 50 inches on deck as that is a class of schooners in the Vintage Model yacht group. I had visions of travelling south to Maryland and joining a regatta if I ever finished the build. The wood shaped bulb form is the 5-pound lead form from the same 50 inch Marblehead I built at wooden boat school. They would give me 10 Lb of lead to hopefully keep us upright. In late 2015, after having built both Charles Notman and BHOD racing sloops I realized the need to redo everything. Next up is the rebuilding of the rigging the first time Cheers
- 23 replies
- dancing feather
- pilot schooner
Keith as the story unfolds it is like a confession of a lost soldier. I always have about three projects going and I am always reading about three different books at a time. Some get done in a reasonable time and some don't. If one drops in to my Bluenose log one will note I still have three sails to complete and I am committed to rebuild the mainsail. There was a pre covid 19 rumor that Bluenose II will visit here in honor of Maine's 200th birthday. If she comes here, I should drop everything and go back to that build.. My long answer is a clue by itself...i have no real time table. I hope they get done. However the long hiatus means I learn more and get better skills or tools. what was good enough in 2014 is rejected today/ so maybe i never get done. cheers
- 23 replies
- dancing feather
- pilot schooner
Post 25 Some more rigging….set the masts??? I remember in one of my earliest posts I was talking about trying to save this old hull and maybe the masts and see if we can turn it into a fun project. The first struggle was the shape of the hull, specifically the round stern. I got a response that asked why I was trying so hard to save this old log of a hull with a too round stern etc. Looking at some of the photos showing the dinged-up spruce log hull with me suffering to get dead eyes level, all I can do is chuckle. This ship will never make anyone’s mantle. Heck it may never leave the shop, but I have learned so much that I really look forward to a future build. I want to build some Brigs and I feel I will be ready. I might take it up a notch to 3/16 scale though. The current scale is becoming less daunting as I work through it and it might be better for a diorama where I have two boats …..Part 2 of my planned Pinky builds by example….next winter perhaps The three weeks have been terribly busy on other things, but I try each day to do something. The tiny little ratlines are finally easy, and I try to do 12 a day. First up is to log progress on the shop rebuild that started with he house move mid-way through this build. The end of the shop was a garage door, as I understand the first oner stored antique cars. 173 I finally got my new glass door in, so the daylight, especially in the morning is great. The dog loves the new exit to the side yard. Back to Aphrodite… First up we need to take a step back. When I glued the little brass yoke that holds the main topsail yard lifts, it dribbled and grabbed the topgallant mast. Top topgallant mast had slipped loosening the top shrouds, so I had to break it out and rebuild the connection. Murphy lives. I learned to wrap the upper mast with a styrene piece [ see earlier post] and glue it to the lower mast. This arrangement allows the mast to slip in and out and from the side looks just like a proper mast cap. To get a ¾ inch long piece of the right size styrene, the cupboard was empty. It cost more to ship than to buy. 174 while we wait a few days for a new mast cap, the top gallant mast remains temporarily clamped. You can see the daily progression of ratlines. 175 I wanted to install the fife rail and pumps around the main mast but needed to get the mizzen set, so the mizzen forestay could be installed first. 176 here is the result of my first attempt to getting the main mast set. The top mast shrouds are still loose waiting for the reset of the top gallant. I have been using soft annealed black coated copper wire gauge 24 from Joann’s to make the chain plates . they are quite flimsy. 177 I commented in the last post of my revelation to use annealed steel wire for this assembly. Here the top mast dead eyes are all done in steel and I am much happier with the result. These two photos are the reference I made above of needing to remember this is an old spruce board carved as a hull. There is no nice planking. 178 another item to go back on is to replace these large topsail yard lift lines that are too big. 179 here we are with smaller lift lines that actually feed through the little holes in the lower mast tops to get to be tied off below, once the shrouds plumb up the mast 180 well here we are. Everything is a mess and we are working in all areas. My next milestone is to get enough done to complete all deck connections. One example is I need to research to see where to attach the Foremast forestay. Also I need to figure how to attach a spanker boom before I get too much done on the mizzen. All for now cheers
- 57 replies
Post 3 build as of 2007 this post is a catch up on the work done in 2007. 11 starting off we see the complete hull planking with rough sanding done. In the background one can see the frame for what became my 1:24 Bluenose build. I built that frame and found myself a little over my head. I switched to this build using what I learned experience wise on the other frame, this one came together Ok and includes a slot for the dagger board. Bluenose will require some other means to bolt on a sailing keel. 12 here is a lesson learned. Someone suggested I use the water base filler for all the seams and things. What I learned is that the cured white plaster is harder than the cedar. It was the wrong material for modeling. 13 material did not mater in the end as here I have 4 oz glass with three coats of west system epoxy resin. The bottom as was shared in the literature was green. I chose this moss green as it represents patina on copper. It is not the darker green of Fitz Huge lane, 1850 painter of note. As this is the simple sailing version, I see, some thirteen years later, no reason to change this color. I will need to add the gold trim line, and the forward embellishment of the bow to some extent. 14 inside we clearly see the construction technique taught at Wooden Boat school. The little 1/32 plywood strip ribs stand out nicely against the rich color of the resin covered cedar. The dagger board truck will hopefully be watertight. There is no way to go back and to check. If it turns out to leak, I will need to permanently install either the full dagger board or a stub. Either would take away from the display aspects of the model. 15 here we see the error of way ways happening on screen. The bowsprit is clearly too big 16 now to start the deck. The cabin is the access for the RC stuff. 17 in the early days of my modeling there were several missed steps. Since this scale is quite large, I might have nibbed the planks. The deck house will sit on beams as it needs to be watertight. The visible deck house will sit over this inside “neck”, and be removable for access to RC gear. 18 Mast stubs are in and the oversized bowsprit is starring at us. 19 clear resin goes on the deck for water proof. simple varnish goes over for UV protection 20 The spars are roughed out. They are made of Sitka Spruce 21 and here is how we sat from 2007 until 2015 All for now
- 23 replies
- dancing feather
- pilot schooner
Post 02 A little history There are several references in some of our favorite books to Pilot schooners in general and Boston Pilot schooners specifically. The most exciting book came out coincidentally in 2001 as I started this build. In that period the European arm of Wooden Boat started to publish a magazine called le Chasse – Maritime. It lasted a few years with beautiful images and stories of European maritime history, ship building etc. As part of the effort they also published Pilots, Vol 1 Pilot Schooners. is was produced by a team and edited by Tom Cunliffe. A full chapter is dedicated to Boston. Many pilot schooners built in the USA, including Boston, were sent to China to work the Shanghai-Yangtze/ Canton-Pearl and other treaty ports. They were fast and rugged and popular racers too. most of the images below are from the book. Back to the pilot schooners. They evolved starting in the mid to late 18th century. There are several stories of their demise, capture and recapture during the revolution, especially in the Chesapeake where credit for most early schooner development resides. The book’s pages are filled with stories of the competition among competing pilots and variation of the schooner rig that seems persistent throughout. Each chapter moves up the coast, region by region with similar histories of mostly locally built schooners competing for market share. The New York schooners seem to get bigger than the others, and their names seem more familiar. They also have the distinction to have progressed from the Schooner Mary Taylor to the yacht America built by George Steers. In this book she is classified in the same class. The replica came to Boothbay Harbor, Maine a few years back and we had a great sail. Now as we get to Boston, one might start looking at the artwork of Fitz Hugh Lane. Many paintings include interesting companionship to the subject major ship. O6 The painting Northern Light in Boston Harbor gave us images of Pinky schooners, that I used in my last build, and here the cropped pilot schooner Coquette of 1846 in the same painting. Again and early version with Clipper bow. Moving to the builders we quickly learn of Dennison J. Lawlor. The write up tells of his career, the several Pilot schooners he designed and built, followed by fast bigger fishing schooners, small steamers and his brigantine News Boy . Several pilot schooners were built by Lawlor including, Florence, Dancing Feather, Phantom, Lillie, Edwin Forest and Hesper. Looking at artwork one finds the more famous schooner was the Hesper. Hesper built in 1884 was Lawlor’s final and crowning achievement in the pilot Schooner class [ as per the writers in the book}. She was sleek and long and long living. There are several incredible images by Don Demer and other maritime artists that include her are easy to see online, so she was quite well thought of as a fine specimen. The well-known Erik Ronnberg redrew her lines from the builder’s half model and it is all in the book. The full-page image of her in Dry dock also helps my decision of having copper on the bottom of the small-scale build depicting Dancing Feather’s real look. Hesper was much bigger at 102 feet on deck. Dancing feather was one of the first pilot schooners of 1853. She carried from experience a clipper bow that died away over the next 30 years of design evolution. She was 67’6” on deck .The image of her half model, which resides at the Smithsonian, and her lines are all there in the book. Most interesting to me is the sail plan. 07 this sail plan is set up with three foresails [ note the club boom for self-tacking] . We have much to think about about but basically, as also referenced elsewhere, this would have been only the summer light air rig, or perhaps limited to racing. I read elsewhere that top masts were often removed in winter. Also, of note. the main topmast was used for large flags. also of interest is the exaggerated clipper bow. 08 looking here at Danial Webster, another Boston pilot schooner with a clipper bow destined for Shanghai,China, We see the common view of just three sails and a large flag on the main topmast. 09 here is Edwin Forrest another Lawlor schooner in the book with four sails in a brisk breeze. 10 Here we have the famous Hesper cropped from a painting by Davis from the net. I note the large flag is on its own spar and not a normal topmast. Not the square bow, These pilot crews worked all year tacking and maneuvering within harbors and then racing out or back to pick up or deliver a pilot. If one sees 20 images of pilot schooners, the full sail rig might be on two. The flag is interesting but an important part of the look. There is much more to review and learn. I would assume all these schooners built for speed had copper bottoms. Looking online at three models they all have copper so that decision for the small hull is made. The RC hull is already painted green to represent tarnished copper. The A J Fisher model photo is also a green bottom. All for now
- 23 replies
- dancing feather
- pilot schooner
Thanks Chris and Keith I'll really plan to enjoy this one as I get to do both a 1::64 model and a big hull @1:16 that shows of the lines well. I wonder if she will sail cheers
- 23 replies
- dancing feather
- pilot schooner
great choice for a schooner build. I built Charles Notman in 1:48 scale and RC sailed her twice. I got quite a few fittings from Bluejacket. They can be quite helpful too. A friend was building the kit at the same time. He loved it and did a great job. She is a real beauty. I recommend you find a copy of A Shipyard in Maine. It tells the whole story of Percy and Small where Charles Notman was their first 4 master. I will definitely follow along cheers jon
- 144 replies
- charles p notman
- finished
posting 01 the beginning The beginning of this story started in 2001. I was off to Newburyport, MA to buy plans for Bluenose and Gertrude Thebaud . While in the store I saw and bought a small kit of a beautiful little schooner named Dancing Feather. I was still working for many more years but got some good quality time in Maine in between foreign assignments and on weekends while working in Boston. I tell the story in my Bluenose building log where the first build of this schooner took place. It was never completed. I used the kit plans and fortunately scanned them, as they have disappeared. I built the RC hull in the winter of 2007-2008. We all know what happened in 2008 and it I went traveling for the next 5 years. It was January 2014 when I finally retired. That year was filled with other projects ending with the start of Charles Notman, a seven foot sailing Schooner. In 2015 I built the 42 inch long pair of RC sailing sloops and restarted Dancing feather at the very end of the year. Again, I never completed it, but I made progress in the direction of an under detailed potential sailing model. Everything I did was an experiment. I am glad I did that as I made many mistakes. In 2016 I drifted into Bluenose, another 7 foot sailable schooner. She was a great learning exercise. In that exercise I drifted into trying to do too much detail. My son visited and said to me that when I build a model I need to decide. Am I going to sail it or tell a history story about it. After two dioramas, I agree there is a lot of difference. Now that the Little Pinky from Boothbay [ phase one] is done I am working on the first ship of Boothbay, Aphrodite. It is very tedious at 1:96 scale and I love working on it , but I need something else to begin too. A week ago, I took out the old Dancing Feather kit. It is by A J Fisher and extremely basic. The only real piece to use is the carved hull. What I am now doing for this project is the following. I will build the Kit out as a study for what I want to do on the big ¾ scale model. I will then rework much of the rigging on the big version. Keep it simple and see if I can get it to sail. One of the issues will be how to cut down the sizing of the sails so at 1:16 it works. Full size sails at scale do not work too well as they will over power the schooner. I did it on the two racing sloops and learned that cut down of the main sail to match the cut down of the jib was bad. The main needs more power and in light air the sailing was touchy. I have a few photos of the original 2007 building of the hull and spars and will share them in a few posts to get us up to date with what was built. And then we will look at what I must undo or fix so she can sail as i go through building the small 3/16 scale version. Post 01 Early build 2007 In my Bluenose log we find the bluenose hull was planked and then hung from the ceiling of the shop. In 2007 to 2008 I was able to follow the same process and build this hull. 01 here is the same method I learned at Wooden Boat school. Bulkheads were 4 mm lauan plywood, planks were stripped cedar roughly 1/8 x 5/16. There are thin strips of 1/31 soaked and then fit as ribs over the forms. Then blue tape separates the rib from the form and the planks are glued to the ribs and toothpicks driven home into the lauan form. 02 the dagger board is a carryover from the Neskaeg Marblehead 50 design. I am experimenting on making it removable to allow display without the extended fitting 03 how about the strength of that keelson. I would never do it that thick again. 04 since we are fiber glassing the hull there is no spiling required 05 here we see the hull is planked. Behind us we see a Marblehead 50 naskeag that i built at Wooden Boat school in 2001. Note the permanent danger board keel with lead bulb. up next some history on who dancing Feather was and building the deck Cheers
- 23 replies
- dancing feather
- pilot schooner
Post 24 A little bit of rigging An early spring pulls us away from the shop a lot, so things tend to slow down. I built the acrylic box for my other pinky Schooner build, and working on that also takes some time. Regardless we continue in our internship here of trying both to build a ship for the first time and to work at 1:96 scale. I have fallen into the sequence squeeze. I can not put in the pumps until I put in the Mizzen fore stay. I cannot do that until I rig off boat much of the mizzen and set it with yards in place. When do I install the main lower yard? Is it better before or after all the upper yards? Since the mast is already stepped what must be done before ratlines? I built and lost the helm in the house move last November. I found the rudder and now rebuilt the helm. Looking at it in place, I need a binnacle. The dimensions are again tight, so what to do. On and on we go. After reading professor Tosti volume 2, I decided I need to solve soldering. I leave his incredible machining and basic high quality to an upper class of builder. many of us just remain in awe. However we must learn so.....I had seen advertisements for the solid base with strong arms holding little pieces that Ed used in his book. After reading, I finally made the plunge…all of $100 plus investment was made. wow was it worth every penny. My first try was to make something that needed to hold a pin hard against another brass bar to make a tee handle. It is a handle for the windlass traveler see saw / wild cat or whatever it is called. 164 in this photo I am making a lower yard yoke. 165 here it is after solder and ready for final filing. 166 here we are on the main lower yard along with the dental bands and other hardware ready for black paint 167 and finally here we are with our first yard in place. That is sort of in place. Lots of lines need to be added. the chain yard sling is rigged and drops toward the deck. I don't know I if need to add block and tackle or where to make it off. The Crowther's book identifies 192 pins on deck and every line that makes off. No slings are listed there , just the port and starboard lifts. My confusion is that his line diagram clearly identifies the slings and shows them with a down arrow. many models just have a little chain going from the yard to an eye on the mast. i could do that , but I can not imagine how that is correct. 168 as a reminder, here are the yards from the existing model. I will throw away the wire connections, plug the holes and go from there. Hopefully I can reuse them . if not a simple dowel is all I will do for this build. I am not ready for the 7 stages of trimming a log. 169 Here I updated the main topsail yard and got her in place and continue to work away at ratlines. Now back to the overall question of sequences. I am just going for it. Working on everything at once. Tie a few ratlines, work on a yard to fix, another yard to rig etc. I am learning with each item, so I guess by the time I finish this thing I hope to be ready to start a ship. Some simple things I have learned. I was online at Bluejacket for some things and decided to buy some fine annealed steel to try to use for stropping these tiny wood blocks. The thread I have been using is just a pain. any load it breaks or comes loose. Wow the annealed steel wire is so much better than the soft copper stuff I have also been using that comes from Joann’s. The soft copper wire has no strength to hold shape. 170 here is a look at where I am today on sequence. One thing I find is the upper masts slipped and the shrouds are loose. As soon as I get all those ratlines on, I will somehow push up the mast to make the shrouds taught and pin it to the lower mast. It was easy to do on the mizzen off boat, I think it is going to be hard on the main being built in place. i have a pin acting as a fid onto the cross trees, but it is not holding. Finally, back to the deck work that was not completed aft. 171 I rebuilt a helm , put the copper treatment on the rudder and mounted it. I am nuts I know, but I need a binnacle and a bell 172 here is my first attempt at a binnacle. Surely, they would have had iron balls to adjust. I have no info as to what it might have looked like in 1853, so this try is at least a place holder. I suppose the bell could go on top of the helm. I have seen that on another model. But if it goes there, who could ever hear it. Doesn’t it belong amid ship, so the crew can hear watch changes? On most schooners it is on the foremast facing the companion way to the focs'le. I have all the dead eyes strung for the mizzen, so coming soon I hope to step it. Cheers
- 57 replies
Post 23 Complete forward deck This is always the fun part. As we read others logs and learn how to do things a new way it is always fun to try things out. There will be several things here that I tried and as long as I get the idea right, I am happy. First a few assembly items 150 first up is make boat skids. I learned the are shaped to fit parallel to the cabin roof. Here we are shaping them 151 There are many small parts to make and paint. I decided to use real 3/16” belaying pins on the fife rails as they are so visible. I had some of the right scale in pear but two of eight broke while trying to install them. I assume any attempt to tie off to them would be a disaster, so I opted for brass. The boats are simple sand and file carved and solid. I added keels, bow stems and gunnels. The painted screen in the skylights is not perfect but represent windows well enough. I wish I had a source of a bigger size mesh. I should I suppose add bars and would have if working at a bigger scale 152 here I drilled in pins and installed the boat skids. This is where I decided I need to show the required 3 boats that a merchant ship was required to carry if over 400 tons. [ so I read] Now a review of the bow area 153 A general overview shot. Aphrodite is now sitting in a rigging stand. We all have our own approach. I started these stands for my former schooners that were 4 to 7 feet long. This is an experiment for now at this small size, but I am thinking to use this for models with copper tape bottoms too. These strapped stands let me rotate the hull and don’t hurt the bottom. I did add the main topmast forestays 154 The bow sprit and jib boom and lashed bob stays. I laugh at this picture as I see the cap twisted on me. oh well. 155 Here is the some of the work. I made little handles for the windless see-saw lever. I was proud of my soldering. I bought a real solder stand and found it much easier to hold a pin to a bar and get a simple solder joint without too much pain. 156 The port anchor is secured for sailing on the rail. I am still concerned as to all the anchor lifting and holding operations. I learned the schooner method which is a bit different. The 6-part block in the cat head did not work out for me at this scale, so in the rebuild cat head there are two sheaves. I chose to rig one block and with a hook that I assume grabs the chain. I also assume the fishing tackle from the top of the foremast would be hoisting the anchor. I would love to learn the right way for these ships vs Schooners. In the meantime, I lashed the block to a pin on the rail. 157 the starboard anchor is ready to drop. I have the short chain from under the cat head to an open hook on the forward side of the cat head. The L shape bar, its handle up, has a holding bar bent over the aft side of the cat head holding the handle upright. I took this idea from the well-known master in his volume II on Young America. 158 Looking aft things seem to be where they need to be. Note the added space between the head, bosun locker and center structures. I trimmed them up and squeezed them back into the sides a bit and lowered their roofs. I also replaced the forward pin rail with a new one drilled in the mill and with real belaying pins 159 Boats I will not lash them down yet as they may interfere with rigging the main mast. This is also a good shot to see the change I made to the standard plan that had a big skylight in the middle of the cabin. I literally cut it in half and lowered it to make it proportional for the space available with the added boats. 160 this to me is an important view. Please refer to picture 146 where I discuss the tightness of al this area. It was just wrong. I took it all apart, shrunk things a bit and now there is a corridor to the two little ladders and maybe 2 full feet between the bitts and the companionway. One possible change still needed that jumps out in this picture is to slide the capstan aft to center it within the area between the bitts and the samson post , I will not move it enough to expose the hole now in its center but there should be more room all around it I believe. 161 I think the general look is a reasonable representation of what a ship of 1853 would have had on deck before gobs of rigging lines. Here also is a good view of the whisker booms I added to correctly hold the head stays as they return to the side of the hull. They connect right near the head and need to give the anchor room to be rigged. 162 a fun wide angel shot coming at you Looking forward 163 I need to work aft. I am making my attempt of pumps and need to get the aft deck done. I had a wheel and small helm but lost it. Cheers
- 57 replies
thank you G L I know some one who makes complete figures with wire and sculpy or other similar materials. My attempt was a disaster, so I have bought figures. I am working now at very small scale and may try..wee'll see cheers and thanks for dropping in
- 69 replies
- diorama
- Glad Tidings
Post 22 Bow sprit and deck work part 2 I like to work on several different things at a time. That is why these posts are so partial. Deck work. It is time to build fife rails, pumps, skylights and think about boats. Also to add any more critical deck eyes for standing rigging. 138 I start this midpoint review by reminding myself of the Crothers design of Alma that we are using. There are few differences that will help us understand at least where a few things don't work out just right. As per our text, Aphrodite was 680 tons at 147 feet long and 31+ wide. Alma was 826 tons at 153 feet long and 34+ wide. The 6 feet in extra length could be very help full and I will show where. The width is less significant. This Alna plan is basically what I am building. Does it all fit? 139 Reading other people’s logs can significantly improve our work. Here I am following where many went before me. This is the first time I started to use by my big brothers hand me down Sherline set up as a mill to drill little holes all in a row. Wow what a difference. 140 reading another log I learned to use screening for windows and the like. Why not sky lights at this tiny scale? We’ll see 141 I am trying to build fife rails. Wow are they small. I cannot yet imaging tying off lines to these, but I am going on adding lined to the rigging. I need to rethink line sizes, that is for sure. 142 boats. This can be a long story. Boats on ships. After more reading I learned that ships over 400 tones should have had three boats. The question is where they go. This is the typical location and we are good with two. We need to omit or significantly reduce the sky light, or maybe place the boats lie out nearer the edge if we want three. More study is needed. In the meantime, I think I am staying with two. Also these boats are small at 22 and 24 feet. I plotted out a long boat and there was no way to bring it aboard. So for this midpoint review to see what we are going to try to show 143 this overall view shows fife rails, boats and skylights partially done and sitting in place 144 the main fife rail is extended to pick up pumps. I am taking this from other common designs but have no specific information. 145 this view shows an issue. The hole in the deck is for the capstan located as per the plan. Once we extend the fife rail and will put in something to represent the pumps, it is obvious we need to move the capstan to the center of the open space. I will probably add a pad to cover up the oops and it may be properly located under the pumps. 146 here the rail is in at the foremast. The tightness of the whole area is a problem if one considers the lack of clearances. This are would benefit with each of those 6 feet of difference in the two ships designs. Bowsprit update 147 here I am able to use a dental band for the ring on the bowsprit 148 the bowsprit on the original model is almost ¼" too short. I compensate by making the cap proud of the bowsprit. I add both the band and bees as I prepare to rig this out. 149 here we see the overall rigging plan with the extended bowsprit. Now I have some idea of what is in front of me. Up next is to clean up and complete what is here. Nail down the cabins, build a boat frame and rig the bowsprit. Cheers
- 57 replies
Post 33 Get ready for the cover. I paid a lot for the glass box that covers Bowdoin. I wanted to try to make my own box this time. I made a silly mistake on day one of this project. I had a perfect 24” by 24” piece of plywood for the base. I should had cut it down to 23.5” by 23.5” but was not thinking about a cover at that time. If you go to Lowes/H depot everything is for 24 inches. I needed four sides at or just under 24.5 and a square top at 24.5 both ways. While at Lowes, a nice guy helped me out. He had a left-over piece of acrylic at 44 by 28 that we cut into two-piece 24.5 square and 16 by 28. He then said only Lexan comes 36 by 48. We cut it into three strips of 16 inch so I could make the other three sides No if you think about this there is a problem if you want to connect parts by solvent welding. How do you connect Lexan to acrylic? We talked about it, and I read some about it and settled on a tube of Loctite super glue. Before we get there, we have few more steps to follow 276 I needed a seat to receive the box, so another trim piece is added to the bottom 277 that new section needs to be painted out to black for underground or blue green for water. Fix the crew 278 one of our guys lost his hand. I drilled and put in a wire frame 279 I shaped a new hand in sculpy. I did not think it wise to put this guy in the oven, so I coated it with very thin AC 280 after a little peach paint we are all good 281 our painter needs a bucket. I chose to machine out a dowel, like I made gas barrels before. 282 here the little bucket of black paint and a paint brush complete the scene. 283 finally we need an adze for the spar maker. I put a thin brass rod into his hands, stuck on a flat end for the tool. I then wrapped the brass with tape to get the right thickness. What is fun is making all this up as we go. also I see in this photo I need top be sure I painted the blue tape. Now the box 284 here we are gluing it up. After using a concrete block to hold the sides vertical with the first application of super glue, I came back and ran a fillet on the inside of each joint. This stuff is only about 1/8” thick and a bit flexible. We’ll see how it goes. At least it won’t hurt anyone if they hit it. 285 here we are…amazing it fits 286 I should have asked for help as things fell over . now it is shaky to take if off. I will wait till be are closer to the showing before removing all the protection. cheers
- 69 replies
- diorama
- Glad Tidings
I had to laugh at myself again. I was reading Mr. Crothers again this morning as I am making up the list of what I need to build on deck. i got to his table that takes one through the detailed rigging of a ship line by line. the fore topsail does not get a chain. the three lowers do and the the main topsail does. i will tr=y again when i get there to solder chain to wire. i really need to get the hang of it. anyway I am in the middle of skylights and rails cheers
- 57 replies
Post 21 Bow sprit and capstan part 1 I am off on a detour and that is always good. I need to do some deck work to get that phase completed about the same time I complete masts. First off is to figure out the bowsprit and jib booms 127 we start off looking at what we have. the top jib boom is rather short, and I am afraid needs to go. The sprit itself is fine but a little big. 128 I don’t have enough hands to hold out the projected distance but by roughing in what I get from study will be a little less than the image here. The jib boom is woefully too short and must go. 129 back to the books, Mr. Crothers that is. I spent some time and concluded with the following reconstruction. Alma our Maine built sister ship is rig 51. That means three jibs. All of the standard drawings in his book are for two jib configurations, so I need a little poetic justice here. What I concluded is to take the details of the separate flying jib boom and apply it to the end of the normal jib boom and then use the three dimensions form his appendix. The blue annotations are what I will be using. I will show what I mean in the next post 130 here we have roughed out the blank. Using advise from a few logs I will drill all the sheave holes and things before rounding. Deck work It is time to build a capstan. I had fun building winches for my 1:12 scale Boothbay Harbor One design sailing sloop, so I decided to work in that way here. I hope it works 131 the smaller dowel is reduced and glued into the larger dowel. The smaller is the shaft and d it almost true to scale at 12 inches. 132 here I cut off the larger dowel [ see plug giving added strength. I used a razor saw to cut in the 8 slots. 133 here after cutting notches I slid a second washer up and glued it. The first whelp is being glued in. I will sand the curve after the glue has dried. The lower washer and wood stand are loose at the moment 134 I had to figure out how to fix the top. Here I took another dowel and sanded, filed and sawed a top. The leg to sit inside the top washer…. I hope 135 I have dry set the capstan in place. In the same period, I build the forward pin rail, forward bitts and extended knight heads. I took all these details right out of Mr Crowther’s forward standar4d deck plan 136 a closer look at the capstan. I need to think about how to finish it. I am thinking stain and black metal like the windless 137 I also tried to do the topsail lift in chain. I tried six times to solder copper chain to bent copper wire loop. I finally gave up and used lock tight glue. The chain is too fine for thread to go through the links. Up next is get most of these things done and then figure out what else is needed on deck.
- 57 replies
post 20 foremast yards part 2….I thought I already shared my redo of the lower yard lift and new issue of not liking the shine of tung oil on the upper yards. My plan here was to bull through this first mast and then set a plan to do better on the mizzen before determining how much to redo. Another Oops is coming 124 I added the top gallant yard and there is no shine…much better. The foot ropes are still terrible, but at least the ratlines are getting better... for me at least. I am now tying each one, no more loops. We’ll look closer after another day when I get to the top 125 when I went to add the royal yard I realized the need to get the two more forestays in place on the upper mast shoulder to hold up the lashed blocks that will in turn hold up the yard. I sliced the first one on, and then realized as I set the mast in place to measure the first of two head stays, that I have done nothing to the old bow sprit. oops.....Oh well another detour 126 I must say photos like this one are fun. Yes lots of rework is coming, but at least some steps forward Next up the bowsprit detour. Cheers
- 57 replies
