Everything posted by AON
Brig Eagle 1814 by bdgiantman2 - 1/48
AON replied to bdgiantman2's topic in - Build logs for subjects built 1801 - 1850
I think salt water ocean shallow and fresh water lake shallow might be two different things. Also, isnt gravity involved when cannon shots fly.... they drop. Not all shots were balls. Sometimes they might even be two balls if close enough. Chains and grenade style balls were also used. But more importantly, shots to the rigging and mast do damage to the gun deck (weather deck of the Niagara) when it all collapses. There would be quite the mess for the cleanup crew. 😉 -
Bruce Ray (MSON) had built the GJØA. You can email and ask him. I would have thought it was gear driven... but that is from someone that has absolutely no idea! 😉 Alan
Good morning Bruce I am going to send you 3 PNG photos from A Ship Modelmaker's Manual by John Bowen that might have the answer. The images are too large to post. Cable Stoppers pg 41 fig 64, pg 141, fig 252 and pg 166 fig 311. Alan
Thanks for the video... I learned something from it about loading bullets! My only thoughts were for the use of the train tackle. Yes the gun would recoil on firing so the train tackle was mostly used to retract manually. I cannot envision that one getting used and wonder if I might experience the same thing on my ship, and if so what might be the resolution to the issue. I will reflect on it for a bit more... quietly in the corner! 🤔
- 1,076 replies
Kevin. While watching your video and seeing the train tackle that could not be used as it was already hauled in as much as possible... I wonder if they would have used the port deck eye with the starboard gun and the starboard deck eye with the port gun? This would allow them to pull the gun back all the way to the eye and possibly expose the muzzle inboard for loading. I know it will be covered and hidden from view... but I am left wondering if this was the solution? Alan
- 1,076 replies
I suppose that is another reason not to rig stuff no one will see! I'm taking notes.
- 1,076 replies
I may be seeing things wrong but it seems the eyebolt in the deck is too close as the gun doesn't look like it can be haul back.
- 1,076 replies
What an interesting use of electrical wiring heat shrink tubing! Now that is thinking outside the box.
- 288 replies
- Santos Dumont No. 18
- hydroplane
I had bought my pin vises (2) and number drill bits from McMaster-Carr. I bought two pin vices because they came with a reversible chuck (larger shaft/small shaft) so I could have one set for each. That ended up being a waste of money as they are easily reversed. I bought a few bits that came in multiple quantities in envelops. The smallest of which are quite delicate and snap with the slightest side pressure (flex) if you do not choke up on them with the pin vise chuck.
THE CABINS LOOK GREAT! I just watch a two short videos of the cori robotic knee replacement surgery... got my GDD (Google Doctor's degree!). I'm guessing it will be a quicker recovery with this procedure. Hoping all goes well and your back jogging in no time.
Sometimes I find the small restricted area fiddles with my mind to make it more difficult than it should be. I also find carving on end grain to be difficult. I find that if I take a slightly larger piece of thin stock and rubber glue that to a base piece of wood that is clamped, then pencil mark the shape, then start carving it is somewhat easier. Then I remove it from the base and take it to the table top disk sander and sand the edges to their margin lines.... but still the first one can take three attempts! But it gets easier.
- 1,076 replies
I get to 9:51 in the above video and it kicks me back to the beginning! I can pick just ahead of that and it loads and plays... not sure what I missed, assuming not much
- 1,076 replies
HMS ANSON 1781 by albert - 1/48 - 64 guns
AON replied to albert's topic in - Build logs for subjects built 1751 - 1800
There is nothing more satisfying than getting the last of those seemingly never ending frames done! BZ
