Everything posted by AON
I practiced laying out and 3D modelling a few frames once again (re-learning what I decided I would do some time ago) and realized another mistake / misunderstanding of the contract description and so my final template will look slightly different than my earlier attempts. I will be working on these many, many profiles to make the 3d of the hull, slice it up into the frames, etc and then create the 2D template for each for cutting and building. I completed the Keel, Stem and Stern Post assembly drawing (see attached) and feel I can begin this part of my build. My drawing has four copies of the same detail. - One to remain untouched for reference - Two to be cut up for templates - and the last one as a spare copy PLAN_Keel + Posts layout.PDF I also made a visit to my son and liberated yet more lathe from his scrap pile as I read on the forum you should have twice as much wood as you calculated to cover cutting loss and scrap. It is presently laid out flat in the basement acclimatizing. I will be practicing my scarph joinery on scraps and will not attempt it on the good pieces until I get it right. I find I'm feeling a bit excited and very nervous at the moment... first cut jitters I suppose.
Ed I had visited your build earlier this week and made a note to come back and start at the beginning Came back at just before 10 am this morning and it is now approaching 4 pm Thank you I have learnt so much today love the pins love the copper wire love the mono filament love the blackening love the....... everything about your build. I want to be just like you when I grow up and that is saying a lot because until now I never wanted to grow up!
- 3,618 replies
- young america
- clipper
1:64 in my mind will not in any way be a small model but, for me, when I hear the name Bellerophon I cannot imagine the injustice of reproducing her image in any shape less than grand. My former crew and the alumni of #141 RCSCC Bellerophon would understand completely. I pray I am up to the task. Although I have been trying to rush through the modelling and drawing part (honestly I have, if it weren't for the side projects) the building will in no way be a race. Creating saw dust, wood chips, dull edges on knives and chisels..... I can barely wait to be in the middle of it! (I love building as much as demolition)
BUILD SCALE: it will not be 1:48 as this will be too large I will not be able to reach the top of the tallest mast even with my model table lowered completely I printed off three scales on two sheets ($4.25 Canadian per sheet at 36" x 60") Cut them out and set them on my table so I could best visualize the physical size Planted my measuring sticks to simulate height over the tallest mast and breadth over the longest yard 1:64 will fit nicely on the table and 1:72 is the smallest I dare go. I admit to being intimidated by the smallness of some tiny components at these scales Scratch building will be a real test of my abilities I'll need a bigger scrap box. I am going with 1:64 Decision made. I've said it before but it warrants mentioning again Thank you to everyone that has offered me help to this point, Lord knows I need it. I will be starting on creating my templates I imagine this will take some months with the amount of time I can put to this hobby every day. Alan
I believe I may have it now ... but I do not feel any smarter (Thank to my ancestors I've got my good looks to fall back on ) Druxey suggested running plank lines or wire frame My NRG mentor suggested buttock lines needed to be followed I drew in buttock lines on my frames and then drew in faux plank lines These showed my loft feature to be bumped out considerably on a couple places I created new 3D profile / guide lines for the pulled in shape and lofted to these It was still, somehow, not quite right. There were still bumps, albiet smaller ones. I needed to divide the features more and create additional lofts of smaller areas to get it to pull in better. The pink is the old shape and the green lines are the new shape before dividing it up more Even after having done this all lines needed manual adjustments to blend better Following is what I ended up with. There are still minor deformations but at model scale and with sanding I believe these blemishes will disappear.
Thank you very much for the link Lonelius. I've checked it out three times now I should live so long to make it look as easy as that! his post 4 image #2 really shows what I should be striving for I have a gut feeling that I am making this more difficult than it should be, that there is an easier way to complete this, if my skill levels could only miraculously multiply over night. I am using the loft command to see the outside surface of the timber /inside surface of the outer hull shape It seems this gentleman used the shell command and added thickness for the inner / outer hull.
I did run some simulation buttock lines (like planks?) tonight and can see issues much lower and exactly in the area you questioned. I made a separate copy and was playing with it but my eyes need a rest and my mind needs to clear. Calling it quits for tonight Try fresh tomorrow. I think I need to break up the profiles more to get them to follow the right curves. Many many many more guide lines required (resembling a wire frame) You are much smarter than I look, and I have a ways to go to catch up to my good looks
heard back from my NRG mentor and my stern is not quite right looking at Gils Victory at http://modelshipworld.com/index.php?/topic/485-hms-victory-by-gil-middleton-jotika-172/#entry8107) post #15 - images 7 + 8 They are another two very good references I believe these three lofted sections of my model are possibly wrong but before I jump into making things worse I'll be taking a break
Had a busy time the last couple days. Played with the upper transom outer corner some more and have 'flattened' it about as much as I dare. Seems every other adjustment from there makes things worse somewhere else. I managed to create a 5 second animation pan viewing the corner and also a PDF of incremental snaps shots automatically generated from the animation and sent it all to my NRG mentor to comment on. Unfortunately I cannot seem to attach the .avi file here for the forum to view so here is the PDF. lower transom shaping.pdf I also manged (after considerable time ... it ended up being easier than I made it out to be) created a 36" x 60" sheet for my drawings in Solidworks. I added 2D images from the 3D model at 1:48 and 1: 72 scale to be printed out to scale on Monday so I can better visualize. HMS Bellerophon scales 1_48+72.pdf That will be when I finally get off the fence and decide once and for all on a build scale. I am / was (?) wanting to build 1:48 but am suddenly coming to realize the massive size this would be. Possibly 1:72 might be more accommodating.
I looked at images of the Bellona transom which was better than most images in books I have Then I adjusted the radius as much as possible, I believe, to reduce the sharpness in the turn at the corner Following are two images, before adjustments and after Druxey, is this "more better?" (as the young'uns say) Alan
Thank you Druxey I'll have a look at some photos from forum builds and books and then play with it some more. Meanwhile I had extruded my keel and post sketch to the maximum thickness of 1-1/2 feet. You can see the hull shape at the stern disappears into it prematurely. This is because the stern post is not a constant thickness but notched away and tapered. Same thing at the stem post but not as dramatic. I included a couple snap shots with the keel and posts made a bit transparent so you can see where the hull disappeared to.
I created new planes at the different deck levels where the transom direction (shape) changes and drew my arc's in. These ended up being 50.5 ft radius. This was accomplished by inserting a "point" on the plane and then mating it via "pierce" to the earlier transom line from yesterday that passes through the plane. I drew a center line on the plane passing through this point and then offset it the distance to the hull as measured off the plan. Width measurements were: roundhouse deck level = 20 feet quarter deck level = 24 feet upper deck level = 26 feet The arc was trimmed back to the centre line on one side as I would only loft half the transom as the extending lines might confuse the loft feature. I then added yet one more plane at the highest most elevation of the centre stern frame under the rail at 52'-6" and added another arc. I then "connected the dots" of the extreme outer ends of the arcs using 3D sketch (I got this idea from Don's posting above) This required some 3D manual fine tuning to blend the line into the shape of the hull Once I had that where I thought I should stop I used the Loft Feature to fill in the shape. I then added a few extra lines to allow me to lofted in the shape of the missing upper port aft part of the hull. Now I need to complete the keel and posts.
The refit of the schooner Charlie is complete. I finished my workroom (installed the missing door trims) on Monday Planed down an extra door jamb and ripped to size to make the trims for my modelling table edges. They are installed (glued, pinned and clamped at the moment) but not complete. They will need sanding and the table requires painting in the next few days to be complete. So I finally find I am back on my Bellerophon. I am looking forward to beginning the actual scratch build of this ship but must finish my plans first.... completing my 3D model to create and print my cutting templates. After careful study and measurements off the ship's plans I have decided how I might complete this area. I created yet one more plane on the sheer plane to layout the transom outline as measured. The lower transom has an arc or radius to it. You can see in my layout I simply drew a line between the two outer points, offset the line 4" (as measured) and drew a three point arc. When looking down from above the upper transom has a 12" deep arc from sheer line (center line) to the outside (as measured). Next I will complete the profile of the upper transom and then attempt to create the lofted feature and add it to the rest of the 3D model. As the sun has risen well above the yard arm ... and this is the end of 2014... I will slowly make my way to the wardroom to commence celebrations and so I wish everyone a Happy New Year!
Friday, 26 December 2014 I am proud to announce that Charlie was successfully delivered to John, the owner, by his family on Christmas Day. He was reported to have been quite surprised and very happy. With that off my mind I can bid this build log farewell. A special thank you to all that followed on the journey.... time to get back to my Billy Ruffian! Hope to see you there in the near future. Alan
Tuesday 23 December 2014 I snuck through the side office door and set her on the table then had a co-worker call him to the room... all a surprise! Delivered in one piece... that is a weight off my mind. With his permission I've posted the image of his first sight of Charlie below I hope to receive a photo of the father-in-law's expression at Christmas. Alan
Thank you "O"! It was more than I planned to do but I found I almost couldn't stop myself. As I said earlier I am sure I got more than I am giving. Hope to have some photos of tomorrow and I will post the PDF. She is mounted on a plate (3/4" plywood) and ready to transport. Alan
Monday 22 December 2014 (afternoon) I completed the port side main mast ratlines and started on the starboard side fore mast ratlines but my eyes kept wandering to the rear. It was there, my mind could see it but my eyes would not register it. After quite a few glances aft it popped out like a sore thumb. I had the main mast shrouds forward of the ratlines! Yes... both sides. (no sense doing a job half way) Cut the dead eye running lines off and corrected them all. I completed the ratlines and then installed the handrail wires (22 gauge bright steel wire from the florist section of the hobby shop) I finished them off with some black electrical wire heat shrink tubing Touched up some of the painting and (drum roll please)...... she is done! I will now complete the PDF collection of build photos to go with her so they can appreciate where she started from and how she got to where she is now. Delivery... 9 am tomorrow morning.
Sunday 21 December 2014 I attached the flag. Added two small ringlets to the halyard and secured the flag to them Completed the rigging of the deadeyes Had to re-do one from Saturday as it wasn't quite right Started on the ratlines My table got a workout during this phase (raising and lowering) and this made a huge impact on comfort. I used what I had that seemed correct for scale and was very concerned it would be too small a line ... but it looks very good to me. Managed to get the port side foremast ratlines completed and about 90% of the port side mainmast ratlines before I had to call it a day. I should be able to finish these today (Monday) and get the handrails installed to the stanchions ... and then I am done. Depending on the time it will be delivered today or tomorrow (Tuesday) morning.
Saturday, 20 December 2014 Made the second flag which turned out slightly better (the first had a little ripple between layers on one side) Re-rigged the forward fife rail and did not get carried away with snugness (yes Druxey, everything worked out wonderfully!) Started on the standing rigging when it happened (oh yes, yet again) I was wearing my magnifying lens head gear and had it flipped up Leaned in to focus with my music glasses (12" to arms distance focus) and the headgear pushed on the rigging and she toppled off the cradle. No I did not have her secured permanently to the base. Thanks be to the Big Guy upstairs nothing was damaged! I pulled out a piece of 1/4" diameter dowel (actually measured 0.2400" - 0.2411" diameter) Drill a 15/64" (0.2344") in the aft base post and in the keel Cut grooves in the pin, glued and hammered it into the post Placed the model onto the base and tapped her home with the palm of my hand on the cabin roof She is berthed solid now. I measured out and drilled the holes for the handrail stanchions then I installed these as I wouldn't have the room once the standing rigging was secured to the deck I used a small block of wood, marked off with the top of handrail and two holes as a gauge to assure all stanchions were all the same height. The top of stanchion and lower holes were not my primary gauge, the top hand wire hole was used for alignment. The holes drilled into the deck (at 1-3/4" spacing until I got to the rounded stern) are smaller than the copper wire is round so they are essentially dry nailed into place. I used every stanchion I made, no spares left over (and I planned for two). The reason was that the rounded aft wouldn't work at the planned spacing. I needed to tighten it up which caused the extra posts to be used up. Then I worked on rigging the deadeyes. Started the first one wrong (stopper Knot in the bottom) and had to start it over (stopper Knot in the top) I used an unconventional figure eight stopper knot as I was concerned it might pull through. I wrapped (turned the end through the bite) the line three times to increase the knot size. Finished one set. Prepared the second set, then called it a day. I am hoping to finish today (Sunday), but tomorrow (Monday) will be okay as he will still have it for Christmas. For my second ever model she is looking damn good if I do say so. Not masterful, but I am proud of what I've accomplished.
