you have some great detail in the main structure........as well as the cage. don't fall victim to the 'own worst critic' syndrome.......just remember......"I did that" ;) it looks great, you know! :)
remember.....I'm taking notes for when I do my PT boat :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks to all of you fro the nice words.  I feel we should be critical of our own work, thats the only to work into the same catagory of all the GREAT model builders here at Model Ship World!
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
Tim, you are right, we need to be critical. But years ago I was with my aunt and her family.  Her  daughter, just learning to crochet, showed her work to her mother and said’ “ I missed a stitch here and messed up here and. . .” her mother interrupted her and said, ”The blanket is lovely and those mistakes are for you only.  Others will look at it and only see the beauty.”   Tim, Please don’t point out the mistakes and take away my joy.  I see your boat as very fine workmanship.  I see the beauty.
Bob
Current build:  SS_ Mariefred
Greetings,
The windscreen is complete an has been installed, (photos in the next post).  The next step is to cut the port cockpit spray shield from the 1/64" plywood along with the step from the supplied 3/32" basswood strip.  I will need to soak the spray shield in water to soften them which will allow me to wrap them around the supplied 7/16' dowel.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings,
The port spray shield had soaked for a couple of hours in warm water, the next step was to clamp the wood sheeting around the dowel and dry over night.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Great pictures, thought they were rabbits holding your frame  inplace  Tim.
Great work and PT boats do have a flavour of there own.
John Wayne's film of this iconic boat  and the history of its operations gets my attention to your build.
Keep it coming. :)
foxy :piratebo5:
Greetings,
The port spray shield is complete. The assembly was easy for the most part, I glued the straight part if the shield first then slowly added CA while I worked my way around the bend.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Thanks John!   :)
Tim
Future Build:
Completed Builds:
Member:
Now to start on the starboard spray shield!     :cheers:
Tim
Future Build:
Completed Builds:
Member:
Brian,
You answered the question!  A quick bond is the answer for gluing items which would be hard to clamp, as with the spray shields with their rounded shape.  Often I will use CA and wood glue together.  I will apply CA at both ends and depending on the length of the item to be glued along the middle section, just using a drop in these areas, then I will follow with wood glue between the CA,  The CA gives a quick bond and the wood glue when dry gives a stronger bond.
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings,
I have completed the spray shields, I have to admit it took a couple of attempts at getting the curve in the correct place.  I have to admit I have lot's of cleanup work to complete but that will all come before the final coat of paint.
Now on to the engine room hatch!
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Thanks John, they were a little tricky and I'm not afraid to say, I didn't get them right on the first try!   :rolleyes:
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Thanks Elia!
It's getting there, little by little!
Tim
Tim
Future Build:
Completed Builds:
Member:
Harvy,
Thank you for the compliment!
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings,
My next step is to construct the "Main Engine Room Hatch".   The engine room hatch coamings are cut from 1/32" x 3/32" strip wood, a small radius needs to be sanded at the aft end of each coaming.  Then two end pieces are cut from 1/16" x 1/8" strip wood, then glued to to the coaming to make the frame.  The hatch is then cut from 1/32" x 3" sheet plywood to fit the frame, it will need to overhang the frame by 1/32" all around.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Tim,
    That came out beautiful. Excellent work on the detail. This is going to be one Beautiful build when you done. Have been watching since you started and will be waiting for more updates. Thanks for sharing.
Wacko
Joe :D
Go MSW :) :)
My apologies for putting my remarks Ina different log. You have done a terrific job taking a average kit and turning into a masterpiece.
David B
a obvious statement:   "nothing looks as great during the process,  as the end result!"     the structure looks superb Tim......the detail your putting into it is really going to dress up the hull.   now that I think of it.........are there any pictures of it dry fitted on the hull?    <nudge and wink> I'm sure you've seen it ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
You only had to do them twice?  Fantastic !  I would have had to . . . Enough of that.  They look great.
Bob
Thanks to everyone for the nice comments!   :)
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings,
I've completed building the Main Engine Room Hatch and put a coat of primer on it.  When the paint has dried I will sand the camber into it the same way I did with the Chart House, once that is complete the placement for the cowl vents will be marked and drilled.
Cheers,
Tim
Edited by Timothy Wood
Tim
Future Build:
Completed Builds:
Member:
