HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
Tim,
Make some is the easiest answer.  Use dowel of the appropriate size and work from there. Or... check with your local hobby store for model railroad barrels.  You might need to take a small ruler with you as I'm sure that it'll take some poking and measuring around to find something the right size.
Thanks Mark,
I had thought of something along those lines, but I run into a little different problem when it comes to the roll-off rack they were mounted on, I guess I could find a set of drawings and build it from scratch!
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
Thanks Mark,
Tim
I think you could pull that one off.  As I recall they were made of tubing?  Maybe just use some styrene.  If you can't find plans, use pictures.  you can probably scale your rack from a known object in the picture.
Mark,
Finding a drawing isn't too much of a problem...  All I need now is the dimensions, it looks like I have plenty if time to them them down, because there I have several steps to complete before I need them.
Thanks,
Tim
Edited by Timothy Wood
Tim
Future Build:
Completed Builds:
Member:
if you don't mind plastic...you could check out squadron,  dragon,  or waterloo
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks Popeye,
I'll give those three a try!
Tim
Tim
Future Build:
Completed Builds:
Member:
surely!  there are other places that carry accessories......those are just a few
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye,
There are many places which cary PT Boat parts, the only problem is most don't carry 1/48th scale.
Tim
Tim
Future Build:
Completed Builds:
Member:
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Kevin,
Thank you...   This will help more than you can imagine!
Tim
Tim
Future Build:
Completed Builds:
Member:
My next step is making the chart house & cockpit from the supplied basswood in the kit.  The chart house has a slightly cambered roof, I have sanded it to the desired shape and correct height shown on the plans.  I also needed to match the camber of the hull to match the underside of the chart house and cockpit, I accomplished this by gouging out the underside of the chart house block to a depth of 1/8" and to within 1/8" of all four sides of the wood block.  I then placed a piece of sandpaper on the deck and proceeded to work the block back and forth until it matched the angle of the hull.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Chart house shown on the hull to check camber of the mating surface.  (This photo shown earlier in the build).
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Thanks Russ,
It was tricky because the basswood wanted to split at the forward leading edge where the chart house meets the deck.  I had to glue one one piece back onto the leading edge, if you look close you can see it.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Alfons,
I hope I don't disapoint you if I choose to paint the boat gray, as they were painted by Elco....  I still havn't made the discision which way I'm going tyo go with her...
Tim
Tim
Future Build:
Completed Builds:
Member:
Nice work on the deck houses.
Bob
Current build:  SS_ Mariefred
that's a common color for them......there were also the olive drab....some even went camo,  depending on the theatre or crew.  paint looks really good.  the main structures will look really nice with added detail.....good work! ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Bob, Richard and Popeye,
Thank you for the kind words of encouragement.  My next step, which I jumping ahead to, is to make sure the area/cut out for the 50 cal. mounts fit properly before I add anything to the chart house and day cabin.
Thanks again!
Tim
PS: Richard, if you want a good PT Boat movie watch "They Were Expendable".....
Tim
Future Build:
Completed Builds:
Member:
It's been a couple weeks since I had a chance to get back to the model bench and it felt good to be back!
My next step was to shape the instrument panel.  The instrument panel takes the form of a truncated triangle in cross-section.  It is shaped from a 3/2" x 1" x 1 1/4" block.  I had to take roughly 33 degrees from the forward edge of the instrument panel to get the correct slope, this pretty much matches the rearward a angle of the forward chart house, and the rear instrument panel has a little steeper angle.  The first couple of photos show the angle if the sander settings for the instrument pane, the remaining shots shows the sanding process.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Thanks Jim,
I wish I could work on it "Full Time" but the real world keeps getting in the way!
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
a little at a time can be a milestone.....nicely done ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hey Popeye,
I couldn't have said it any better!  ;)
Thanks, Tim
Tim
Future Build:
Completed Builds:
Member:
An overall look of where she sits at this point, as you can see I'm moving along like a "Herd of Turtles."   :ph34r:
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Thanks Russ,
The paint is only a coat of gray primer!  The actual color will be a lighter shade of gray.
Tim
Tim
Future Build:
Completed Builds:
Member:
looking sweet Tim.......:)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
