I use both oil based and water based depending on what i am varnishing. The oil based seems to soak into the wood a bit better but even when using clear oil varnish it still stains the wood slightly. The water based seems to leave the colour of the wood almost the same as it was before varnishing, and to help it soak into the wood i water it down slightly. But it is all a personal preference on how you want the finish to turn out. I tend to only use matt varnish as naturall wood doesn't shine. Remember though once you varnish it the normal wood glues will not be as effective as they are on bare wood
"Beauty is in the eye of the beholder".  So apply whatever finish you think looks good :)
Personally, I like Teak Oil on the darker woods...it gives a rich look with no shine.  I seal almost everything with a water based matte polyurethane finish (again no shine).
I would highly recommend you do some testing with finishes you like on spare pieces of wood  :)
Boyd
Current Build - HMS Bounty - Artesania Latina - Scale1:48
The symbol Ø represent the drill bit diameter for making the hole.
If part 46 and 47 are to installed then yes, those should be installed, use part 47 to line up the holes.
Guessing part 46 is the rudder stock. Drill that hole in sequences starting with smaller drills going up to 6mm.
Your Bounty is coming along nicely.
Edited by Nirvana
Respectfully
GentleGiant,
Use medium CA (15-25 sec.) to glue the cleats to wood.
This will give you the best result, when it comes to CA glue "Less is More", an activator helps to strengthen and shorten the time.
In general you when gluing metal to metal/wood/plastic or in any combination, CA is the best applicator.
Good luck
Respectfully
In part 51 is this the good part?
GentleGiant,
Look at the parts list and explain the material to us, but to me it looks like a drum piece made out of brass.
This will help us unless someone else has the list and will be able to give a direct explanation.
Good luck
Respectfully
Do you paint or varnish the Blocks around the Steering Wheel ???
And how do you fix the block at the pin ( brass wire or cotton thread)
        Thank You Gentle
Edited by Gentlegiant
very nice progress GG,
your deck fitting out looks great....
Nils
Current builds
-Lightship Elbe 1
Completed
Hi GG,
I do`nt know if this is historicly wise correct, but this is how I did it (Boat lashing)
Hope it can be of help to you, if you like....
Nils
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
GG,
I`m not sure if I understand what you mean, I presume you only have two double-sheave blocks and would like to tackle these correctly.
Here is an enclosed little handscetch showing in detail how you can do it......
You may have to strop the blocks accordingly. Watch for the position of the sheave holes
Nils
Current builds
-Lightship Elbe 1
Completed
One of the many reasons I don't use superglue or CA is that a tiny drop spreads into a large area. My feeling is that you did overuse the glue. To fix knots use flat lacquer varnish or diluted white glue. They don't spread and make your lines stiff, do not make the lines brittle and do not leave a shiny spot,. All this things CA does. In any case, if you must use CA try to use a gel or a thicker one.
Hope this helps.
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
If you have to use CA, make an applicator.  I take very small diameter length of music wire (get at local hobby shop).  Then I bend tiny bit of the end, say 1/16",  back on itself, say 180 degrees, to form a very small "spoon".  I place a tiny drop of CA on wax paper and use this applicator to grab an even tinier drop.  You can then just touch this applicator to the knot and the very tiny drop will wick into the knot.  Even using cotton thread, the CA rarely wicks beyond the knot.
If you are using the applicator in quick succession, tap it the wax paper between picking up CA.  This will prevent dried CA from building on the music wire.
Current Build:  HMS Dreadnought - PLASTIC - Waterline
Completed Builds:  USS Cairo by BlueJacket;  Nave Egizia by Amati;  Harriet Lane by Model Shipways
Or you can take a needle and file or cut half of the eye. Different needle sizes will give you a variety of tools for a wide range of applications.
