Hi all,
- cabin trunk almost completed,
- applying chain plates.
Ciao
Completing hull painting (a little glossy?) and applying name board on the bow chock-rail.
Hi Patrick, thank you.
it happens that black colour was too glossy and copper red too matt.
So I used a transparent matt to have the same effect on both colours.
Furthermore, actual new ships were not completely matt but a little bit glossy (See for example Bluenose II).
Ciao,
Giorgio
Nice paint job.  If it is a bit glossy leave it alone.  Since you are going the yacht route that is the way it should look.  Beautiful work.
David B
Bow scroll painted with 0.7 yellow marker.
Could be better, but I'm satisfied. Or not?
Could be better, you say???  post-76-0-83250100-1447307745.gif  Looks fantastic from here.
The steering wheel, from a brass blind nut (Why waste money for a expensive 1m, 12mm DIA bar?).
Oh,no!
I've jus bought five nuts for 3 euro (4-5$)!!
Ciao!
Hi Patrick,
I used the UNI-POSCA yellow marker extra fine:
http://www.posca.com/uk/all-material-markers/pc-1mr
Ciao,
Giorgio
Hi David,
I applied a round 2mm wooden rod with adesive strip along the line track.
The marker followed this track!
Then I removed the 2mm rod.
Ciao,
Giorgio
Hi all. 15 days to prepare fife rails and bitts!
This is the second attempt. I think is okay: made from a 1mm brass sheet.
The first one was made of 1 mm ply: too weak!!
Ciao,
Giorgio
