Hello All,
I built this model 10 years ago. From my teens (now I'm 40) I have been a modeler, building plastic kits of all kinds, but always wanted to build a wooden ship. I gave a try to a solid hull, pretty simple Santa Maria (shaping the hull with a rasp from a square block..), then, when I could afford, a Billings Mayflower (which was not up to publishing standards).
The Corel kit was a major step up, the first ship I taken seriously, and this became the period of my modeling, I enjoyed the most. I found the old DDM site, read a lot, purchased books and discovered something new with each part I made. This will never come back, and this model still reminds me to these exciting times.
Things have changed a lot since. Having two kids now, in addition to heavily increased workload, I mostly exercise model building by watching other people's work. Recently I read a post about majority of MSW members are not participating. Feeling guilty in this regard here comes my log of the Prins Willem.
I built the kit mostly out of the box, and despite it's shortcomings on the historical accuracy, had a lot of fun. I will try to continuously update the log as time allows.
David
Past builds: Prins Willem,  Amati Coca
Current Build: Occre Diana
She looks good David!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Yup, I'll be dropping in as well and watch the progression.  I love them old Dutch ships.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
thank you for the views and likes.
A few words on the kit. This one is from a period before laser cutting, and certainly was a high quality offering of that time. But modern kits are certainly more precise. The quality of the planking material is very good, like other walnut strips included. The kit uses an extensive amount of beech strips for various items – while the strips are well cut and consistent, for small sizes it’s just too brittle and difficult to work with. There was a few missing items in my box, but got immediate response for my emails and received everything is short time.
What I particularly liked, is a well structured list of all parts at the end of the manual, they show the part number, which material they are made of, and complied in the recommended sequence of building. It worked for me very well, gave a structure to the whole process, and allow planning for upcoming steps in time (ie painting parts for future steps).
The ship is built on a plywood central piece, with no separate sternpost. A ply stem piece is attached later in the build. The accuracy of the precut bulkheads was not perfect, some adjustments were nedded by removing/ adding wood. The lime strips was very easy to work with, though.
The kit uses a unique system for making the dummy gunports. The height of the gunport is two strips width, so the top and bottom planks fit with exactly two strips width apart. Then a U shaped strip cut to size is glued from the back, which will hold the half barrel.It is strongly advised to have them pre-drilled before glued in place. The space between the vertical edges of the holder pieces then filled with short lenghts of planking, forming the gunports. The joint of the gun holder pieces must be very strong.. I lost some of them inside the hull at the very end of the build and had to find a workaround to mount the guns.
Nice planking David!
-Elijah
Current build(s):
Completed build(s):
Member of:
  • 4 months later...
Nice start to the planking. Good job.
Regards, Scott
Completed builds:
Awaiting construction:
  • 8 months later...
thank you for the comments.
can't believe a year passed since the last update.. log writing goes as slow as building..
here is a picture of the first planking, actually my first properly planked hull. I was satisfied with it, but most importantly the whole planking was trouble free. I wasn't sure in the beginning, but it gave me the hope that I will be able to build the ship to a reasonable standard.
I still like the idea to have the flow of gunports defined by the planking strips above and below.
start of the second planking with the highest wale. as for the first layer, the wood was well cut, straight, and uniform in width. not uniform in color, so some sorting was needed, but now after ten years I see the planks of different color blend together nicely. The dark strips became lighter over time. A spacer, made up from the required number of planks helped to position the wale strip near the stern.
the quarter galleries are carved from a block. they are preshaped in section, but the forward profile must be carved in. a pretty difficult task, especially I used a very basic toolset. If it is inevitable to have some blood in the model... this one has mine. Seriously, do not carve hardwood, held in your hand, with a knife in the other hand. Lesson learned.
The blocks finally glued in place. As they will be planked and heavily decorated, there is still opportunity to adjust the shape.
after the inner bulwarks planked, the posts glued in place. there are a several hundred of them..
this is the point when the kit switches to beech strips, not a favorable move. in such a small section (2x2 mm and like) they don't hold the edge at all, and it makes cutting them nicely very difficult.
the next step is fitting out the deck with various hatches, gratings and decorations. If I was to do it now, should have replaced the gratings to smaller ones. but that time there wasn't such a supply of aftermarket parts. It is one area of the model I'm the least satisfied now.
In this stage the first step is also taken on the road of endless painting of parts.
now let's see a major mistake in the construction. I tried to illustrate it on the picture below - my black piece above the scroll is too short. I can't recall why. Could be a bad piece supplied, or I just screwed it up. As a result, my figurehead (of which the position is guided by the scroll cover piece) is too low, and I had to insert a filler piece to connect the yellow decorative element end the scroll cover.
Hey howya goin DavidG mate, shes looking good mate.   :bird-vi:
I'm probably not going to live long enough to build all these but I'm BLOODY going to try HAHAHA.
Future Builds: The Schooner Bluenose, scale 1:48, POF Scratch Build (Gene Bodnar practicum - Plans from modelshipbuilder.com)
                       HMS Victory, scale 1:64 or 1:48, POF Scratch Build (John McKay's plans)
Current Builds: 42ft Longboat Armed for War 1834, scale 1:36 POF Scratch Build (Plans from A.N.C.R.E.)
                        Galley Washington 1776, scale 1:48, POF Scratch Build (NRG's Plans)
                        Ragusian Carrack, scale 1:59, POB kit (MarisStella)
                        King of the Mississippi, scale 1:80, POB Kit (Artesania Latina)
                        HMS Snake 1797, 18 Gun Sloop of War, scale 1:64, POB Kit (Jotika/CalderCraft)
Current Build: Stage Coach 1848, scale 1:10, Kit (Artesania Latina) Shhh don't tell the Admins I'm building this I'll hide it here ^under this line^ so they don't see it HAHAHA.
You make it look real easy. i know it is not...:)
did you check the heihgt of the scroll, ie does the bowsprit fit in the right position?
When i did it (years ago) the scroll ended up too high (and as your lion looks pretty much in place, I was wondering on the fit of the bowsprit....)
jan
Hi Jan,
thanks for looking in. You certainly set the standard how to build this kit.
You are right, the scroll ended up too high, and later in the build I had to lower it. The overall headrail assembly should be at a lower position, on the other hand the lower posts (which connect the lower edge of the rail to the stem) must maintain the upward angle, which restricts the downward positioning. Nevertheless, everything could be fine if I had my figurehead level with the upper edge of the scroll, but it was too late to adjust.
finally the framing filled with gratings cut to size. This is a scary picture to look at. By now I don't like the scale of the gratings, and can't recall why didn't I sand it properly. Anyway, it is painted black at a later stage, which hides most of the unevenness. Neither it was a good idea to paint the grating on the model, pretty difficult to cover all the holes, in and out, up and down.
But the construction of the head is ready, huhh...
Next, the decorations and painting and painting.
Guys, thank you for the nice comments and likes.
The basic hull structure is done, let's paint. A ton of shiny stuff waits to be glued on. They are mixed quality, these two guys are some better pieces. In size they match the drawings, fit quite well, with no or minimal adjustment. I underestimated the time needed to paint them.
