Hello
This is a mini-update. I have finally got some time over to start the planking.
Off to a humble start:
As you see I really suck at planking. But there will be a second layer so...
The planking goes towards the bottom of the hull. I have to turn her upside down and therefore broken some of the tops of the frames. It'll be fun gluing them back on.... :rolleyes:
Hopefully I'll have something more exciting next time...
Mr. Pucko
Building:
Nuestra Senora del Pilar - Occre
Titanic - Amati
HMS Victory cross-section - AL
Fram - Occre
Pucko,
Knowing your ability of recovery from minor mishaps the broken tops is nothing, just take it easy with no rush.
Is it to late to redo some of the planking?
Respectfully
I too am thankful for double planked hulls to help cover my mistakes and I have also broken many of those extended frame parts off when she is upside down. I just mark where they came from and reattach later when I am done planking the bottom.
It is good to see more work being done on the actual ship! Smart of you to wait till you had a lot of planking to do a bunch at the same time.
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Two tips from my own practice:
Whenfairing your frames, make sure you go all teh way: the plank should make contct everywhere, most of the time that implies that the whole charring on the outside has gone when you're finished
Second: dont start a new plank on the frame, but in between, and glue a part of wood behind the connection, that way, there will be a smoother run of the plank.
Jan
Jan
Hi
And specially for that price.
Bamboo as for planking?
Wondering if DeAgostino is doing this to all the "subscription" kits?
The answer to the question is yes. 3 kits I have built so far and All had bamboo strip wood. If you look closely you can see the dark area of the knuckles.
I replaced mine with good quality wood I milled myself.
If you use it...make sure all the tools for cutting are very sharp. I like the look of bamboo as a finish but it's not easy to work with.
BTW nice build.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Thanks for the replies. The ****** planking is not all my fault. Lot of the strips are a little wavy and that results in the gaps. I will have to do a lot of sanding and filling anyway so I thought this could just go along.
The plus side of bamboo is that it's very easy to bend.... So I'll use them. Just hope the final layer is better quality.
I've done worse planking than this, (and better) and got quite a good result in the end so I'll let these strips stay on. I don't want to risk the frames breaking as they are quite thin.
Hopefully the planking will get better....
Mr. Pucko
Building:
Titanic - Amati
Fram - Occre
I have just got my first parts by mail, and is really tempted to start building, but will try to wait until I have got a few more shipments. But Im really tempted to begin now after having seen your build-log Im really tempted to start right away. I will just finish the ship Im building right now (HMS Halifax by Mamoli)
Hello Nisse,
If you can wait I would recommend to start building after issue 19 or 20.... A lot of trouble with aligning etc can be avoided.
You can always paint decorations until then....  :)
I keep all the painted figures in the plastic bags they came in... Until I find some kind of box with lots of compartments (80 would do).
Edited by puckotred
Mr. Pucko
Building:
Titanic - Amati
Fram - Occre
Puckotred and Nisse,
I would recommend the boxes used for fish tackle.
I am using them and wrap the figurines in silk paper.
Then label each compartment on the lid of what they contain, maybe with a picture of the figure.
Respectfully
At last the new shipment arrived. Issues 33 to 36.
And this is what I got:
False deck parts, another 51 planks (239 so far) and some deck planks. no decorations this time.
This is how far I've come with the first planking:
Planks differ some in both width and thickness, but I will have to do some heavy filling and sanding anyway so...
Three of the deck parts in place.
 No matter how I measured and checked, the slots on the decks did not align with the frames. There are reinforcements from earlier that line up correctly but the frames are still off. I knocked them loose but hit a little too hard on one and it broke.
A couple of doors will go here:
Everything fit nicely with the beam.
The right frame was pulled forward a little and glued in place later
And the last piece of deck:
So, back to planking...
Edited by puckotred
Mr. Pucko
Building:
Titanic - Amati
Fram - Occre
Hi Mr. Pucko.
When i see the planking of you with that bamboo then i'm happy that i use planks from my Aggy.
There is a lot of work for you what about filling and sanding.....
But i have faith in you that you bring it to a good end.
Sjors
Yes, not the best of material. (And not the best planking skill) But then again it's very easy to bend, and nice to sand.... tested a little sanding on the hull and it was very easy, much easier than walnut or the stuff that came with the Bohuslän. That took forever to sand down. So the finishing job won't take long... I hope.  ^_^
Edited by puckotred
Mr. Pucko
Building:
Titanic - Amati
Fram - Occre
I have now caught up with the instructions regarding the planking.
This is how she looks after 184 planks:
A lot of variations in thickness and width.
I gave up early trying to sand the planks so the thickness would be equal.
She's one big fat mama...
You get the feel of her size now that the hull is coming along.
Iphone box there so I won't break any more frame tips when turning her over:
A lot of sanding ahed of me (but not yet). But until the next shipment I have a few decorations to paint.
Mr. Pucko
Building:
Titanic - Amati
Fram - Occre
Nice work Pucko! Can't wait until how it looks sanded. I will catch up on you but you will always be one delivery in front of me :)
I was thinking, the simulated floor for the battery deck, wouldn't there actually be gratings instead? I don't have the real vasa plans yet but I will check it. But maybe nothing is to be seen anyway. And also what do you think about the long guns that has arrived so far in the kit? For me the muzzle breaks looks very funny. I compare them to the Claytons fantastic work for the Vasa 1:10.
https://sites.google.com/site/clayton707/1-10-scale-vasa-artillery
Jörgen
Current:  Sherbourne - Caldercraft 1/64
            Vasa - DeAgostini 1/65
Finished: Endeavour - Americas Cup J class 1934 - Amati 1/80
Other:    Airplanes and Tanks
Jörgen: I'm not sure I follow you. I don't see all that much of a difference on the cannons. maybe ours are a little longer? There should be gratings on the batterydeck alright. Don't know what DeAgostini is up to there but... One could always make some and put there. And you wrote, not too much will be visible down there...
I guess you will catch up with me before I get to the sanding...
In April these will come:
Jan: I solved it the way politicians solve problems... I just pretended there was no problem.. ;)
No, I sanded the frame down to size.
Mr. Pucko
Building:
Titanic - Amati
Fram - Occre
7 minutes ago, amateur said:
You made it an alternative frame, sounds sensible :)
:D:D:D
Mr. Pucko
Building:
Titanic - Amati
Fram - Occre
The monthly shipment has arrived!
Hull planks (52 of them), Upper stern decks and 2 metal pieces:
They are only labelled as "Metal components"
but I think they are the roofs of some of the doors on one of the stern decks...
More to come when I assemble the parts...
Mr. Pucko
Building:
Titanic - Amati
Fram - Occre
It took about a half hour to assemble this months parts ;)
The two decks:
The doors, or whatever it's called...
The single aftmost door:
Somehow the deck was 3-4 mm too low so I had to lift it up and hang it on the door frames:
Later the planking will help keep it in place...
The metal pieces that came are the roofs of the doors at the bottom of the photograph.
More to come when I start planking again...
I have also more or less finished the Battlestation now. Only have to mount the netting on top and do a couple of ropecoils for the left cannon.
This is how it looks:
When this is done and out of the house a tram and Lisboa diorama is up for building in the background of Vasa.
Mr. Pucko
Building:
Titanic - Amati
Fram - Occre
Planking is now on par with instructions.
A lot of cutting must be done to fit the keel and bowsprit:
Why you should not use wet planks. A lot of shrinking when they dry:
Instructions wants you to start planking the deck now but I'll wait a little longer before I do that.
I got some new brushes and stuff so I'll do the rest of the decorations soon.
Mr. Pucko
Building:
Titanic - Amati
Fram - Occre
Puckotred,
Very nice re-thinking of the instructions.
The combo of "wood - water - drying " which equal  shrink  and gaps is something we all can relate to.
Like the recovery you did.
Respectfully
Looks good Pucko. I think it is worth to wait now until bowparts and other visual parts starts to arrive so some planning can be made how to do things. I don't like the instructions at all for how they want to build the ship.
Jörgen
This months shipment is here!
More hullplanks, porthole templates, 2 decorations, the keel, deckplanks and planks with the meaurements 0,5X5mm
And here are the templates taped to the hull:
a nice gap there at the second plank from top
More to follow as usual...
Mr. Pucko
Building:
Titanic - Amati
Fram - Occre
Yes, you will have to line it with some nicer wood or make your own.
Mr. Pucko
Building:
Titanic - Amati
Fram - Occre
