I feel at this juncture, that I'm simply parting my ship together...small piece by piece.  As what looks obvious..the aft cabin is next...I almost started it last night..but I was required else ware. :huh:
My goal is to finish both the aft house and the helm next.
Currently I'm finishing the pump that goes with the main fife rail...between the main mast and house. It wasn't in the photo because it was being painted.
Rob
Current build:
Finished build:
Current build(On hold):
Rob
Hi Rob
You may be going 'small piece by small piece', but when looked upon as a whole model, the overall impression is Wow!
Looking good.
Cheers
Patrick
Edited by Omega1234
agreed..........very well done.  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Well..I worked a bit on the GR today.  First..my image quality was hurting so I figured out I had my camera's white light setting all wrong for the lighting of the room....I adjusted it now things are brighter.  The first image is still set on the wrong white light setting.  It is of the new Great Republic name board.
All other images are correct.
Current build:
Finished build:
Next I finished up the main mast fife rail with the pump installed.
Current build:
Finished build:
Lastly the mizzen fife rail and some over all images of the current state of the vessel.
Current build:
Finished build:
Thanks Albert.  I could be more pro-typical in my construction techniques...and neater too.
I didn't realize the shop was so messy.  Unlike some builders on these pages..I have *Zones* of messes and tools and such.  If I put everything away during my build...the tidiness of the shop would take more time to maintain then the build itself.
A couple of pieces of equipment..some may have wondered about, are my light curing unit, used for curing light cured plastic for custom made parts, and my vacuum former and a sanding disk /table saw lathe I built.(It's off to the far left), imaged sometimes.
Currently I am paneling the aft cabin and wheel house.  Experimenting with the design of the half dome skylight as well(wood, wire and glass)...Oh boy.
Rob
Current build:
Finished build:
Hi Rob,
I am amazed at the fine detail that you are able to do at this small scale.  As you do the paneling for your last two cabins could you take more step by step photos of how you do it.  It seems like magic to me.  love your work!!
John
future build: to finish Mary Rose
http://modelshipworld.com/index.php/topic/8507-mary-rose-by-tarbrush-scale-172-1545/?hl=%2Bmary+%2Brose
completed builds:  Constructo Steam Launch Louise
super progress Rob.........nice concept for the pump.   the deck is filling out  nicely as well  ;)   have a super Holiday....hope Santa is good to you  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Tarbrush.suppose I can take some images of the paneling step to document the process.  It might help some to see my multi media approach to construction.
The holidays are getting in the way of some serious building, but I hope the week after Christmas I can devote some real time to the project.
Rob
Current build:
Finished build:
Thanks Popeye..a lot.  I have only the two aft houses and the sky light and capstan....then the 6 crab winches and then I can tackle the main turned post rail.
Marry Christmas.
Rob
Current build:
Finished build:
Hi Rob,
Well let me see...
I first select a good swath of nylon mesh for the panel simulation
Current build:
Finished build:
Then I cut and collect all the square pieces
Current build:
Finished build:
After that I apply contact cement to the building sides and to each panel piece and locate them on the building.
I also apply *N* scale door panels as well and then paint the spot where the windows will be located.
Current build:
Finished build:
After this I select screen mesh and paint then cut out the window panes and add them.
Current build:
Finished build:
After this I fill and paint around the windows and all the panels in white paint.
I added the capstan polls to the rear of the aft cabin and the capstan.
Lastly will be the sky light and the 6 crab winches.
The scale is pretty small and most work requires magnifying goggles.  (I'm getting old)
I hope this little look into the unorthodox building techniques of these cabins helps demonstrate how much of a hack builder I really am.
Rob
Current build:
Finished build:
 I pretty much throw things together..so the kindness shown with all the likes is very much appreciated.
Smaller scale models lend to mimicked detail.....or applied detail.  I can get away with many flaws.
Rob
Current build:
Finished build:
Rob you're way too hard on yourself. I think your window/panel technique is a great time saver.
Happy New Year to you and yours!
Jeff
Well...My way is always the easiest route...not the best.....sometimes.  Thanks for the fine comments.
Rob
Current build:
Finished build:
Thanks so much for the step by step process on the cabins Rob.  very ingenious technique, makes me want to give it a try!   your results are just awesome!
John
I appreciate that Omega and Tarbrush.  I'm always looking for ways to save time and effort and in the end the result is quite convincing.
Wood doesn't always have to be the final choice of building material.  And since these panels are 1/8" in size...I found the compromise to tediousness.
Rob :P
Edited by rwiederrich
Current build:
Finished build:
I like the window technique as well Rob.........small scale ships would benefit greatly.   superb job my friend......I hope you had an great Christmas!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks for the holiday salutations.....Popeye.  Wishing the best for you and yours this Christmas season as well.
I keep a varied size of mesh screen on hand for such an occasion.  It has many applications in the modeling world.
I'll utilize anything in the building of my clippers.
Rob
Current build:
Finished build:
W2YSM..(ie).. Picard.. ^_^
I'm very pleased with the results.  If my hands and eyes were 20 years younger...I may have taken another route.  That route surely would have included re-engineering something to create the panels..that's for sure.
I tend to settle for things..then I did years ago.  One thing remains....I try to inject something ingenious(jab at humour), that makes the build easier to complete.
I truly appreciate the many likes and fine comments.
Rob
Current build:
Finished build:
What a wonderful holiday Christmas season...I hope and pray all my friends here had a great time with family and friends.  I was up to a bit of creativeness apart from my GR build.  For Christmas a cousin gave me a brass porthole with the glass intact that came from a 45ft sailboat he purchased in Japan 40 years ago.  the boat has been destroyed since then, but he retained 7 of the portholes..one of which he gave me.
So I dusted it off and retained the old chipped paint and oxidized brass and I then added a clock to it and placed it above the whaling section of my nautical den.  What a perfect addition to my nautical collection.  Here's a couple images for your enjoyment.
I'm in the process of fabricating the 6 crab winches and aft sky light........
Rob
Current build:
Finished build:
