Ahoy
There is absolutely no rush in any comments (if any are provided), as it will be at least a month before I will again attempt to not ruin a boat.
I have been reading a lot in the past couple of months, and have concentrated on filler blocks for the fore and aft portions of the false frame prior to planking.  I have observed several different methods, and now wonder what is the easiest method of carving and shaping these pieces?  I totally understand that the size and shape might affect the final product, so I am looking for a middle of the road solution that will pretty much cover all circumstances.
We are in the process of moving to Topeka, Kansas so, again, no need to stop what you are doing and comment.
I bow in envy to the master craftsmen.
Chuck A
Chuck A.
If at first you don't succeed, destroy all evidence that you even tried.
What power tools are available to you?
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
I just cut balsa blocks to the correct width to fit between the bulkheads ...
These were very roughly cut to shape before gluing into position ...
After the glue had set, a detail sander was used to trim the filler blocks back to the bulkheads ...
Sandpaper was then used for final shaping ...
Hope that was what you were asking.
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
If you have a chainsaw, there are other options ...
:cheers:
CaptainSteve
Rough cutting the shapes of your blocks and then using a power tool such as a dremmel for sanding will help it go quickly. Otherwise combinations of carving tools, saws and lots of sandpaper is what you will need.
I don't know if the is a easy method for all uses mostly due to the differences in ships hull design each model will have different shapes that will be needed. However as all you are doing is following the lines of the bulkheads it is a fairly easy process if a little time consuming. If you are looking to make the process faster then only worry about fillers at the bow and maybe one or two spaces back and at the ster plus one or two spaces.
Unfirtunately, like most aspects of model ship building it is a lot of handwork and time. It is worth it though as this sets up the rest of the project so care should be given to make it right.
Good luck when you finally get settled in and can start on your build.
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
I use balsa wood blocks, cut them to size to fit between frames then shape with sandpaper glued to a wooden block.
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
I found that balsa is easier to shape to fit, but it doesn't give much (or any) grip for pins for actually helping hold the planks.  It's good to shape the planks, but not hold them.
For the areas where I want to do a filler where it will actually give me something I can pin into, I use the same techniques as already suggested, but use basswood instead of balsa, as it's hard enough to accept pins/nails to secure planks.  It's also a good surface to glue to as well.
If you use balsa for the blocks, hit them heavy with PVA and water mix or even thin CA.  It'll toughen the surface up a bit.     :)
