Some special attention is to be drawn to the lower deck clamp. To determine the angle of the upper side of the plank I fasten with clamps a lath on the bottom level of the lower deck beam. I hold a piece of cardboard against the frame and mark the lined of the bottom deck beam and the frame.
This cardboard will be the template to saw the deck beam.
While the glue is drying I start to make the lower deck beams and the lower deck beam arms. On the fourth picture the deck beams are laid in the model but not yet fastened. Before I will do that, the lower deck has to be tree nailed.
Thank you Allen, but do not overrate my skills, I am rather new in ship modeling.
Tree nailing is a bit a boring job. I didn't count them but at this stage I have to drill some hundreds of holes and fill them again with as much bamboo nails.
The deck beams are made, now I make the 4 hold pillars. I make five in case one of them is not good. On the plan they are represented as square pillars, I will round off the corners. I do it with a small chisel.
Now I can glue the deck beams in place. To fix the pillars, I drill a hole for a bamboo pin in both sides of the pillar and also on the locations where they will stand on the keelson and in the deck beams.
I did not see my mistake before everything was dry and fixed: I didn't look to the plan before fixing the deck beams and glued N° 1 to 3 at equal distances. That means: unfasten deck beam N° 3 and replacing it.
While drawing the notches  for the carlings on the deck beams, I realize that it would have been better to carve them before fastening the  deck beams. Anyway it is too late now, I have to carve them while they are in place. I learned my lesson for the gun deck.
And a very nice evening for me to watch the progress!
Tony
Now I make the ledges. I place a wooden stick below the middle hanging carling to support it as long the deck is not yet planked.
The open spaces in the lower deck are slowly filling up. As you can see I made also carling notches in the outside of the outer deck beam although they are not needed for the cross section, but I judge that the ship was not ending at the edge of the cross section.
When all ledges are made, it is time to glue the knees in place. Therefore I remove the ledges again in different stages.  To find my way in the puzzle I lay them out in same pattern as they are placed on the carlings.
Then I put tree nails in the carling ends.
I make now the main topsail sheet bitts. I think that the pictures are self explaining. I made the bitts sheaves in the same way as Tony (Tkay11) explained in his post 50 with the big difference that I made them of wood (I have no metal lathe). My pictures of the production process of the seaves are to unsharp to post them.
I will wait to fix the bitts until a later stage.
