My build of Le Cerf is nearing the phase when I have to start rigging the ship's cannons. There are 16 pcs 6 pounders and 2 pcs 8 pounders on the deck, but unfortunately the plans lack completely their rigging. Because of this I wonder if any of you might give me a link or tutorial to show how these are rigged in the correct way.
You have to rig your cannons as in this photo to the reserve of only one tackle in the back.
The dimensions of the elements are as follows (guns of 6 / guns of 8), real dimensions to scale for your model
- single and double block: 175mm/200 mm
- rope of tackle: diameter: 17mm/20 mm
- breeching: diameter : 32mm/47 mm
GD
I have never before seen a breeching rope that goes through the gun carriage rather than round the cascabel.  How common was this?  The wear rate must have been terrific.
John
Diorama, Washington & Philadelphia - 1776.  1:144 scale scratch build
Sir Edward Hawke - Schooner, 1776.  1:72 scale scratch build from H Hahn plans
Matthew - 1497.  1:25 scale scratch build from Colin Mudie plans
Mediterranean Cog - 1343.  1:40 scale scratch build from Xavier Pastor plans
Nonsuch - 1650.  1:32 scale Aeropiccola kit
Caustic - gunboat, 1776 . 1:36 scale scratch build
Very common on the French ships.  I'm not sure why but that seems to be the way they did it.
I too am surprised about the breaching rope.   What is the purpose of the cascabel if not to secure the breaching rope.  I do not think that it can add to the strength of the barrel.  Does anyone know?
Phil Roach
Former Director, Nautical Research Guild
Member Shipmodeler's Guild Southwest Florida
I presume the cascabel was there as the same/similar cannons were used by the army and fortifications?  Then again... dont-know.gif.a4de48c86c41b45fdd9321b485755d2d.gif
Balance, good handhold, also a good place to lash rigging to while moving or securing the gun and Uncle Carly tied his teeth to them while sleeping, being a good fiddle player, allowances were made for him.
jud
Thank you, Georges.  I am a great fan of ANCRE and your group, so I am sure that you are correct.  I'm just surprised that I had never seen this before.
Entirely my own fault - I have had a copy of "The 74 Gun Ship" since soon after it was published, and there it is - clearly shown in Fig.197 - but I had never noticed its significance.
John
