Brilliant!
Regards,
David
David Robinson
Boston, MA area
Completed:  Constructo J.S. Elcano, Artesinia Latina Sanson, Dumas Mt. Washington, Bluejacket Nantucket, Amati Revenge, Artesania Latina  King of the Mississippi,
Amati Grand Banks Heritage 46, Amati HMS Fly, Amati Titanic, Dumas Chris Craft Commuter, Mantua Cutty Sark, Mantua Bruma, Kolderstok Batavia, Vanguard Models HM Cutter Alert, Caldercraft HMS Victory, Dumas USCG Fast Response Cutter, Amati Bismarck, Occre Jupiter Locomotive, Caldercraft Brannaren
Currently Building:  Mantua/Panart Amerigo Verspucci
awesome progress Chris........got some really nice detail going on!   stairways look really well done...as well with how you did the paddle wheel.   really great job!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Perfect scale, Chris.
Regards,
David
David Robinson
Boston, MA area
A bit late, so running to catch up ... marvelous build, you are doing wonders
Carl
Dave, yeah even though these guys are actually steam era railway figures, I reckon they don't look out of place here. Carl, thanks for the nice comments, good to have you aboard.
Chris
looking good Chris!  :)   I'm looking forward to the day I can populate my decks  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Moving upward. Some shots of the next level cabins planked, filled, sanded, and with doors and windows cut out.
And now some with the first coat of white paint. The structure is just sitting in place at the moment.
Cheers
Chris.
Looks great, Chris.  You are really making progress now.
Regards,
David
David Robinson
Boston, MA area
my god........I'm standing still!  :o   your really moving along on her.............look'in really sweet!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi all, have done and placed the doors in the upper cabin structure. Decided to go with the same color curtains as the lower deck. Still need to do the shutters for each doorway now. Currently the structure is just sitting there.
Have also planked (bar the outer edge) the next deck level. Again this is just sitting on top. No glue.
Cheers
Chris
Chris:
She is really looking terrific, and from your pics, it looks like you have yet another deck or structure to add on.  She will be impressive!
Regards,
David
David Robinson
Boston, MA area
Small update.
Front and rear of doors before fitting. A small blob of Blu-Tack stops the door handle from ever slipping out. Drapes are simply cut out of stiffish yellow cardboard.
For the small window in the structure I decided to have curtains instead of fancy drapes. Perhaps a bit out of scale but it looks pretty good irl.
At the front of this structure there is a overhanging veranda which has fancy posts and rails around it. It is also slightly raised from the deck itself. I decided to plank this bit a little bit fancier for the comfort of my passengers.
All structures at this level are only placed and not glued as yet.
Cheers
Chris
Chris:
I also really like that parquet planking pattern.  Was that in the kit plans, or something you just did?
The doors are also really nice looking.  You have a real talent for very clean workmanship.
Regards,
David
David Robinson
Boston, MA area
Thanks David. The external flooring outside the doors just calls for it to be planked the same as the deck. I just wanted to jazz things up a bit for my high class passengers. I think it will look heaps better when the edging goes on as well as the fancy handrails.
Cheers
Chris
fantastic update Chris.......the windows look really cool!   third level is coming along in super fashion........you'll be finished before I get there ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I didn't realise, but I just see the steps outside the upper deck cabins. A bit odd, as the middle deck cabins do not have the high instep ...
Carl
hi carl, on my boat I made the middle deck the dining room and on the side are the windows on either side of one long room. they are not individual doors, and hence have no handles. the upper structure I envisage as separate cabins, hence the individual doorways with handles and steps leading up to them.
just my take on things.
cheers
chris
nice a bit like: Two roads diverged in yellow wood ... It does make a difference
Carl
coming along nicely Chris  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks. Should have a photographic update this weekend. Been working on small, fiddly stuff like shutters and skirting boards. Would have been heaps easier to apply these before the I fixed the upper deck in place, but after soaking, bending, painting, clamping, and gluing little by little in place I will get there. It does give the structure a nice straight bottom edge and finishes it off nicely I reckon.
Cheers
Chris
still shaping up to be a first class model  ;)    I'll be getting back to mine very soon now...still hoping it come out as good as yours.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
so finally got all the shutters done and glue on.DSCN0239.jpg.eeff947bd537d944ca71726b3fd77f36.jpg
upper structure is now also glued into place. just have to add the skirting board around the bottom like I did with the second structure. the top deck is not yet glued into place so this should make it easier to do that. also added the top balustrades to complete the three tier passenger staircase. I really like how this turned out. looks really "busy" and cool in real life.
also added the bow water protection. I ended up scratch building this part myself as the kit one was a really hard pinkish type of wood that I didn't like. this one is the exact same dimensions and should blend in well once it gets a few coats of matt clear to match the deck.
next up, put the false beams on the underside of the top deck and affix that to the upper structure. the pilot house is nearly finished and just awaiting a few interior details I might add. once the top deck is attached I will begin the fancy railings around all decks. should look pretty cool I reckon!
cheers
chris
Chris:
This looks great -- I particularly like the stairs and balustrades.
Eagerly awaiting what the fancy railings will look like.
Regards,
David
David Robinson
Boston, MA area
