Welcome to our new sponsor - Engine DIY. See banner ad on Home page. ×
Michael. Some time back I found these little lanterns, as produced by MSW member Timbers_B_Shiverin. He has made his to 1:64 scale, but I am sure you could scale them to suit your own size. I have made some rudimentary attempts to produce a lantern at 1:76 scale for my Constitution (still working on that little side project). I used the plastic sleeve from the tip of a paintbrush, pushing the LED down inside of the sleeve.
Edited by CaptainSteve
Corrected hyperlink.
CaptainSteve
                        Apostol Felipe (OcCre)
                        HMS Victory (Constructo)
Excellent work Michael.Two suggestions re lanterns.One is to cast them with the LED inside using clear casting resin.Other option would be to buy larger LEDS and file to shape.The body is clear epoxy I believe so should shape and polish with files and wet and dry abrasive.
Kind Regards
Nigel
Currently working on Royal Caroline
Hi Mates,
Martyn: Nice idea indeed.
Oops – I have fallen behind on your log – need to fix that :(
Captain Steve: Thanks as well – lot’s of excellent work. Plastic sleeve is a clever idea!!
Nigel: great idea – my skills make me a bit unsure of this very clever solution.
 The lighting subject is interesting as well as a new to be learned skill. Appreciate all the advice that you are all posting.
 PLAN: the hold, and storage decks one will hang from above (center). In the two gun decks I will attach two to each wall per side. So will need 10 lights in all. Will need to make some sort of housings as well.
First decision is what types to purchase.
• Some have shrunk wrap connectors.
•Some are rectangular but also have bulky (for my purposes) wires.
• Colors warm white or yellow?
• Flickering (random) or steady light?
If I were adding these to within the hull it would not be such a dilemma. For this cross section all the lights themselves will be visible. So wiring with shrink wrap could be an issue
The Nano or pico might be the best.
I spoke with a very nice person at Model Train Software. He also said that I could purchase soft white and then purchase yellow Galley Glass paint. A product used by stain glass hobbyists. I could apply as many coats of this translucent paint as needed to create the yellowish lighting that I specifically wanted.
I think that I will go with the Nano or Pico style of LED – those will allow for the stealthiest wiring installation.
Also leaning towards flickering yellow to avoid experimenting with yellow paints.
Will also purchase the 3V outputs attaching all the lights to that very smart button battery housing that also has an on and off switch. The lights are already at 3V set-ups.
 After receiving the lights I will think of how to make the housings.
 Here are various photos from Model Train Software. AND The last photo might be great for some ships as stern lanterns
Square-dimensions1.jpg.32f0540b97dff297bf130d05310f276e.jpgchip-sizes.jpg.abd037b54b49015a6c79a03218f36505.jpgsolid-leds-for-battery-36.gif.9081728b0429877c6e575b5417108dfa.gifchip-light-kit-19.gif.074477e81bb3228e474531d5300fb26d.gifcoincelllights.jpg.85e58239d53d80f0ac2c440eedbcf416.jpgsmd-chip-leds-13.thumb.gif.dea82a99d010957ecc057b101ebe2567.gifminiature-wall-lamp-1.gif.60daa52dd6d369903200a2c9885a7c1a.gif
Michael
Current buildSovereign of the Seas 1/78 Sergal
Under the table:
Golden Hind - C Mamoli    Oseberg - Billings 720 - Drakkar - Amati
Completed:
Santa Maria-Mantua --
Vasa-Corel -
Martyn,
Yes copper tape is also a good solution. In my case were I to completely plank all the decks I would also prefer tape.
I might be trying to do a bit too much with this current build.
Michiel sent me this link a bit closer for you - They ave a lot of choices for LED lights
http://www.expressmodels.co.uk/acatalog/WHITE_LEDs.html
Michael
Under the table:
Completed:
Vasa-Corel -
I'm  little late to the discussion but, I went with the flickering amber lights on my interior work on SR. They are the same ones I have used for simulating campfires on my model railroad and I think look very nice as they give the space that orange, fire glow. The flickering is I think important for a flame sourced light. As for the lantern, mine (though a bit large for the scale) are made from air line tubing for the glass and wood trimmed to make the frames. Nothing fancy but they serve their purpose. I think you could probably scratch something together easily enough. The wiring is small enough that you should be able to run it inside the framework with little trouble.
Be sure to plan where the wires are going to exit and what will turn them on and off! I have mine exiting the bottom of the hull and will travel down the stand in to the display case bottom. There it will connect to a switch/battery compartment for the power and easy access for on/off.
Good luck! Looking forward to your new improvements! :D
"A Smooth Sea NEVER made a Skilled Sailor"
- John George Hermanson
-E.J.
Current Builds - Royal Louis - Mamoli
                    Royal Caroline - Panart
Member : Nautical Research Guild
E.J: thanks for you thoughts as well. Yes you are also correct flickering is indeed the correct style of lights to include.
That said, in this case they won’t work for this cross-section. The available flickering added tech, at the base of the LED, along with the bulky shrink-wrap make them too large and bulky for this particular very visible application.
Intended locations for both gun decks are here – both sides
So ordered these super tiny Pico in yellow.
Captain Steve: I sure like your idea of using paint brush sleeves –Thanks for the tip. Ordered some tubing from Amazon
1.5mm id - 3mm od.
I will play around and make lanterns that look something like this one (From AMC “The Terror” series).
Again mates thanks for you advice and suggestions.
Regards,
Michael
Under the table:
Completed:
Vasa-Corel -
Michael there is a useful guide to Leds on this website,this is where I get my LEDS and various other items for my RC builds.
https://www.componentshop.co.uk/
Kind Regards
Nigel
P.S. make sure you follow the guide to voltage,required voltage varies with the colour of the LED,too low it won't work,too high it will blow.This is why you quite often have to incorporate resistors in the circuit.
Nigel,
As always thanks so much for your continued advice. Yes voltage is an aspect that I am just learning about. This vender, it appears, has
incorporated voltage choices for the consumer. Here is a link to the available pre-volted purchase choices. Easy for novices such as I.
https://www.modeltrainsoftware.com/smd-chip-leds.html
Do appreciate the advice,
PS: Glad that you are back active in your yard!
Cheers,
Michael
Under the table:
Completed:
Vasa-Corel -
Hi Mates,
Patrick: thanks so kind - especially from such a perfectionist such as yourself :imNotWorthy: . Yes, it was time for a new profile photo.
Minor lateral update. Re-did the hold ballast rocks. Don't know what I was thinking before. These may be a bit too big as well, but certainly
more to scale. Satisfied with this bit.
Now waiting for the lights and will start the next floor. I intend on using pear wood that I received from
Cornwall Model Boats (PS: great vender) as many of you already know. Here are a couple of updated shots.
Cheers,
0.thumb.jpg.9b6e1b813c0ba20c2c62bfec1cc0d8a9.jpg1.thumb.jpg.1d7a2e6aa885463e17b68f01b840f70e.jpg2.thumb.jpg.61695d5c8bce1a493dbb3327d5d55f55.jpg
Michael
Under the table:
Completed:
Vasa-Corel -
those rocks are a big improvement.......OK just as they are  ;)   they don't have a shine......and if you went smaller,  you might as well use pebbles.  they are a nice colorful mix....the ones at Home Depot are likely all one color.   ...and you've decided to turn it up yet another notch........bravo!   lighting is always nice......kinda dumb in that area myself.  I'll look into one of those links  thanks for posting them.   wonderful progress  :)
Edited by popeye the sailor
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks michael
These rocks are indeed much better.
Actually
I am very curious about the further finishing of your decks.
To get ideas for the finishing of the decks in my G.H. ;).
Patrick,
If you are asking about artificial sealers that are typically used to protect wood, I have never used any.
My Vasa is also entirely unprotected in that regard. Subjectively speaking I don't care for the look of woods after sealers have been added.
I do know that they should, in fact, be used.
For me, the exception would be using an oil such as Wacto. That I did apply on my old Santa Maria - still looks the same after all these years.
I had thought of that for the Vasa's hull but decided not to.
Here are a couple of recent photos of the SM.
5aec7f4a79523_IMG_2061copy.thumb.JPG.ae2d0f15f86601df121286635893383c.JPG5aec7f4e53873_IMG_2145copy.thumb.JPG.8f92dc354426cc2456bf769b92c911a8.JPG5aec7f511b651_IMG_2135copy.thumb.jpg.0e4f6ebf466814428e611d48fb17325e.jpg5aec802e44253_IMG_005copy2.JPG.9823945ad4d3ce37eedeb407c640a57e.JPG
Michael
Under the table:
Completed:
Vasa-Corel -
Hi,
I must say I felt inspired by your build. So inspired in fact that I ended up doing something similar hehe
Only difference is that for the fittings I did not use metal, but cardboard painted with metallic paints
By the way, do you intend keeping the cannons in their original color?
All the cannons I've seen in real life are iron, the ones in the kit seems like brass
I had a spare cannon from another build I decided to play around.
Sorry the pic is a bit out of focus, I can't get the focus right on such small things with the cellphone
Edited by federicoaa
Current building
Santisima trinidad cross section - Occre - 1:90
Finished
Bounty Boat - OCCRE - 1:24
federicoaa,
Nice detail. Glad that you could make use of this detail. A detail that I also borrowed from an other build log.
Regarding the canons, yes they will be air-brushed black. I will not use the kit supplied issues instead using the same ones
that I used in my previous Vasa build. I will also hand make the carriages. The kit provided metal one piece bits - I prefer to
make these up.
here are a few shots of how they should look once done - from the Vasa. Thanks for dropping by much appreciated.
2.thumb.JPG.6f90a7291f7b55006cb8b22b89251359.JPG4.thumb.jpg.d8618cc242cb2756a9faa4d235cec9cc.jpg3.thumb.jpg.fd489a3afae446a156c05b0e4e08f12c.jpg
Michael
Under the table:
Completed:
Vasa-Corel -
federico,
Canons with emblems can be bought from most ship model supply companies. They come in several sizes as well.
 1) paint black (air brush allows for a super smooth flat cover)
 2) Using a flat blade to scape off the paint from the emblem
 3) add a clear coat after just to the emblem – helps to keep the brass brighter.
 Here is a link to the store from which I bought these canons;
https://www.cornwallmodelboats.co.uk/cgi-bin/sh000001.pl?WD=a4169&PN=4169-Decorative-Cannon-Barrel-36mm-A4169%2ehtml#SID=1552
PS: All members here at MSW are super helpful – any questions will always be answered.
These canons do not have the correct emblem for the last ship I built (that's for sure)
and not for this one that I am building now. Almost nobody will ever know the difference -
well some here would haha
In any case it does make for nice added details. Hope this helps.
5aef20f91cbbe_IMG_003copy.thumb.JPG.1a07b1557e1c060bd0ef8a79060169f3.JPG5aef20fbe5748_IMG_006copy.thumb.jpg.6793ce20c8428d788569c97e2d7e5114.jpg
Michael
Under the table:
Completed:
Vasa-Corel -
Hi Mates,
FYI: The LED 3V lights and switch arrived. YES these will be perfect.The LED is so tiny that it will, in scale seem, like a candle.
Waiting of the silicone 3mm tubing so that I can build the lanterns.
The wires are also so tiny that I think that I can manage to actually install the lights through the bottom of the lanterns, add a bit of white paint to represent the
candle wax within the lantern housing, easily hiding the wires from view - I think (:-)
Very happy with this light supplier!!  Will update soon--
0.thumb.jpg.5aa977d02bdeea9a62007b4783882070.jpg1.thumb.jpg.55e178137bcc51d9e92668ccee92a4bc.jpg2.thumb.jpg.acbc0f503da92214f23f52c94ac9ce31.jpg3.thumb.jpg.19f38e4ba4a2a96042ad7de8d596229f.jpg
Michael
Under the table:
Completed:
Vasa-Corel -
look'in good Michael  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Mates,
Thanks so much for the likes, and comments always so appreciated.
First attempt with lights done. Well the first one in any case. I very much like the look of these super tiny yellow LED's
Parts: toothpick, silicone tubing, black pinstripe tape. Here are some updated shots.
The next lights will all attach to the side walls so will need to make tops that will attach with hooks. This first lantern will hardly be  viisible
so just attached it directly to that beam.
1.thumb.jpg.eb6c37531b7dda809323dc69868dcce9.jpg2.thumb.jpg.24b962214fa77d5352c6a78b93f22443.jpg3.thumb.jpg.01e4e10ef36980176cc859219297ddfd.jpg4.thumb.jpg.db0c0ad30feacab35df85810d32d187f.jpg5.thumb.jpg.e0286069170ffbc2229b07fcbed8ad22.jpg6.thumb.jpg.d363860b44a7a6d351f7de8360ae4c7a.jpg7.thumb.jpg.cf5b768dfbe9ce6123ed55b5b386a4fa.jpg8.thumb.jpg.9d5f8646090140e9b4713127aef0965a.jpg9.thumb.jpg.4c0711e96f65d8a8c93e527c9991f2e5.jpg10.thumb.jpg.a1fc4faf5601a937e38b811c1e1d6ae6.jpg
Michael
Under the table:
Completed:
Vasa-Corel -
awesome job on the lantern!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Awesome lantern! Well done indeed!
-E.J.
Mates thank for the super nice comments!
Martyn, See my post one above the last one - 3V using a button battery all lights will hook up to the on/off bat. holder.
Michael
Under the table:
Completed:
Vasa-Corel -
Martyn,
A bit more  - from this vender you can order exactly what you need with the voltage resistors pre-installed. They work right out of the box, no need to fiddle
with adding resistors. lights wires have two colors red and green.
Once all of your lights are installed, grab all of the red wires and spool them together to make a single red bundle. Do the same for the green wires.
Then just connect the bundled red wires to the red wire on the battery pack, then same for other side. click "on" there you go lights on everywhere.
PS: This very simple wiring is the same for all battery packs. Just be sure that you order the lights that are the correct voltage for the battery and
holder you plan on using. AAs' 9V etc. According to the order I placed this 3V button battery will power up to 10 LEDs of the type I bought.
Hope this helps
PS: there are two LED wire lengths available. I got the 8" had not thought about the resistor toward the end of the wire. I don't know the size of your cross-section.
You might want to order longer wires (12" If I remember correctly)
Michael
Under the table:
Completed:
Vasa-Corel -
