I have run into an issue that has stumped me. I have on hand some old growth mahogany from the late 50's. I have ripped into 2 mm x 5 mm strips for the planking on the wales of my ship. When I try to bend it after soaking for 3 hours it breaks on the hardest bend around the bow. Am building the 1/60 Endeavour. I have ripped it the other way based on grain but still breaks.I know this is much thicker than say .05 mm planking. I am now soaking it for one week to see what happens. My concern is if this works, it may shrink after glue up and cause a later issues with gaps in the planking. What should I do? I am thinking that because of  it's age it has lost it's essential oils and become too brittle.
A couple of questions.... Is the grain straight.  If not, it will break.    Soak and then heat (I use an old curling iron).  Repeat as needed to get the bend you want.  It is possible that the wood is just too dry to be used.
I have found mahogany to be very brittle at the best of times. I’m not sure that soaking it for an extended period will make much difference. I suggest you rip it down to 0.5 mm and use it as a veneer over limewood or something similar.
Hornet
             Current Build: - USRC Harriet Lane - Model Expo.
             Completed Ship Builds:   Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
Wood contains a glue-like lignin - heat loosens its bonds  for bending -  the function of the water is to
allow efficient heat transfer.  No part of the wood is soluble in water.  The prolonged soaking will only
rehydrate the wood - undoing 50 years of seasoning and encouraging any fungus present.
Lignin is affected by anhydrous ammonia - an explosive and dangerous industrial chemical.
Household ammonia is 5-10% - too dilute to make it anything other than smelly water as far as wood bending.
What plane are you bending?  Down on the frames = you are stuck with heat bending. Up/down in the plane of
the planking = spilling - not bending.
Now that I think about it-  while not a pleasant prospect, if your stock is thick enough - you could carve both curves.
Edited by Jaager
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
    Another method would be to plane or sand the wood into much thinner planks which will bend much more readily.  Then soak or steam the planks to make them more pliable and bend enough layers of these thin planks to total the required final thickness around a form matching the shape required and clamp to dry.  When dry, laminate the layers with a thin layer of glue between and clamp the layers back on to the form and let dry.  With this method you can bend planks into very tight bends and there will be very little if any spring-back. Once trimmed and sanded they should be very easy to apply.
Edited by BETAQDAVE
spelling
Dave
“You’ve just got to know your limitations”  Dirty Harry
Current Builds:  Modified MS 1/8” scale Phantom, and modified plastic/wood hybrid of Aurora 1:87 scale whaling bark Wanderer.
Past Builds: (Done & sold) 1/8” scale A.J. Fisher 2 mast schooner Challenge, 1/6” scale scratch built whaler Wanderer w/ plans & fittings from A.J. Fisher, and numerous plastic kits including 1/8” scale Revell U.S.S. Constitution (twice), Cutty Sark, and Mayflower.
                  (Done & in dry dock) Modified 1/8” scale Revell U.S.S. Constitution w/ wooden deck and masting [too close encounter w/conc. floor in move]
Hope to get to builds: MS 3/16” scale Pride of Baltimore II,  MS 1/2” scale pinky schooner Glad Tidings,  a scratch build 3/16” scale  Phantom, and a scratch build 3/16" scale Denis Sullivan.
Thnx everyone. I have an electric plank bender and a custom jig. Worked well on the 1st planking and the 1 mm walnut. I believe I will rip some more mahogany at 1 mm and double plank this area. I was going for a variation of wood on the wales to break up a solid walnut look.If it still breaks oh well I will try another type of contrasting wood.
Thnx. I have an electric plank bender and a custom jig for bending. I suspect that the wood is too thick. I will re rip at 1mm x 4mm and see how it goes. I wanted a contrast in wood to ofset a solid walnut hull.
Ripping to 1mm and soaking, heating then bending should work. Maybe you could also score the rear of the planks at close intervals with a No 11 blade before attempting to bend. This has worked for me in the past.
Hornet
I used 2 mm maple in my current build. 30 secs under hot tap water and I could get the wood to take extreme twists but mahogany does not like bending much. My experience is also that it can have interlocked grain, same as walnut which often suddenly breaks instead of bending.
thnx vaddoc. I have maple and oak on hand. The reason for my choice of mahogany is it isn't too harsh of a contrast between the walnut planking but just enough to show another wood. Anything such as oak or maple would be too much of a contrast and draw your eye to this band. I know mahogany has a larger grain than walnut, so I will pick through my mahogany stock to find a sample with a much tighter grain. Hope it works.
