POF Kit
Roandad
 Share
Hi all
having completed my Bounty model last year I now want to start a POF model kit where, hopefully, the frame elements are already prepared so I don’t have to spend aeons planning and preparing them. I am looking at a 17th or 18th century ship but clearly limited by what is available, which appears to be  somewhat restricted. Any recommendations out there
tx
Paul
Link to comment
Share on other sites
Thanks all for your responses..
Mark, I guess I am referring to laser cut frame pieces ready to be assembled rather than milled timber for example.
Christian I am looking at the Lumberyard site with interest and seeing if the kits are suitable, so many thanks
regards
Paul
Link to comment
Paul,
Most of the Lumberyard (but not all) are a pile of wood to cut into blanks, assemble, then cut the frames.  As for pre-cut framing... other than the Oneida mentioned and one that Chuck is exploring to make, I'm not sure there any.   Many of the center section kits are however.
Link to comment
Bulkheads are generally solid flat pieces cut to shape; frames are hollow and often built up of several pieces like the real thing.
Look at HMS Winchelsea for an example of the former and a Swan cross-section for an example of the latter.
Link to comment
No... not really.   The bulkhead (POB) kits usually use plywood or similar and about the only decks to be built are the gun deck and upper decks fore and aft.   Look at Chuck's Winchester (link below) as an example or almost any AL kit as examples.   A POF would be like my Licorne and probably 80% of the scratch builds.  POF more closely resemble actual practice and allow everything below decks to be done.   Other than the Orniada I don't recall any of the Lumberyard's Hahn sets being precut for the frames.   Bob Hunt (Lauck Street Shipyard) did some that fully framed.  I've attached a link for one of those build.
Link to comment
Keep in mind that you will see plenty of POF kits from Chinese companies like ZHL.  Because these companies have been known to pirate and steal the hard work of other reputable ship model MFGs, they are banned from this forum.  So please read up on our banned list of pirated MFGs and be aware that we do not allow them on our site or any person building them.  If this is something that is as important to you as it is to MSW and the NRG and the ship model community at large, you may want to avoid any products from these companies as well.
See here for the details
Link to comment
On 5/6/2018 at 6:14 PM, Submarinerblue said:
Oneida is an excellent kit with pre-cut futtocks from which to assemble frames. Also has the online practicum. Not sure if it is a complete kit or if you need to get fittings separately. Check it out. I built it and was very satisfied. Let me know if you want to see pics of mine.
Most, of the Lumberyard offerings are only timbering kits.  However, the Oneida appears to be a complete kit as is the Caustic.   A quick email to The Lumberyard will verify this.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
 Share
