Got sick and tired of removing all tools etc just to access the sawdust, shavings, etc for cleaning.
When I was in the RAAF, we (Avionics Technicians) had a vacuum inlet on the workbench. A small diameter hose was attached for sucking up small foreign matter. We made our own traps at the inlet. These would stop anything we accidentally sucked up, like a small screw. Today, I made myself such a device. It attached to my vacuum cleaner.
Tested it on kitchen breadboard. The bread crumbs are collected in the jar.
PS: the smaller hose is really for small dust particles, especially for hard to get into places.
Edited by Tecko
Peter.
Current Builds:  Wardell Bridge, Bridge on River Kwai, ADLIB-1, and the U-2540
Sublime!!! I have to try it out with all the brass parts which skittered over the desk whilst trying to avoid final entrapment on the model, although, I would probably need a slightly wider hose
Carl
Love it!!!!!!!!
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
Thank you all for your responses. Glad that it is of interest to other modellers.
Please note that my drawing leaves out a length of hose from under the trap lid to about an inch from the bottom. It can be seen in the photographs. The hose was placed in to ensure deposits would be left on the bottom. If you like, you could add a small fly-screen filter over the intake tube of trap (vacuum cleaner end).
Peter.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
I would be tempted to make one if I could find hollow tubes small enough. I think the tubes on the one I posted are too large in diameter. They look like the stir sticks you get for your coffee in restaurants you could still suck up items like belaying pins and such.
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
What you presented looks fine. First of all it is good in the sense that it will only pick up small items (dust, filings, etc) and not larger than a few mm. The disadvantage is that it has no trap for easy retrieval of accidentally sucked up items. That is why I posted a simple and small DIY trap for the workbench.
In the RAAF cleanroom, where they repair delicate instruments, the dirt particles were mainly very small, but one of them could easily effect a bearing or a hairspring, for instance. The traps used were also very small, like the size of a baby food jar, and using a hose with about 3 mm inside diameter. The rule was to suck up foreign matter as soon as it was presented. The immediate work area had to be absolutely clean at all times.
The point is, a small trap can be used. I figured that a modeller would need something a bit bigger, like a pickle jar, and a hose with about 6 mm (1/4 inch) inside diameter.
Edited by Tecko
Peter.
The brush attachment was not an idea to replace the trap it was an alternative to the normal suction end that would still allow high air flow, (The force that actually picks the stuff up) and not grabbing every part up and sending down the tube.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
The separator is a good idea - it is easier to search through a small pile of debris than across the whole workbench (which unlikely is as clean as in a clean-room ;)). I gather the rentention capacity would depend on its length, so a long, narrow jar might be safer than a shallow one, or you would need to put a bit of foam in front of the internal suction pipe.
I would avoid using any further barriers to the negative pressure (suction). The reduction in intake area (small hose) already reduces the suction. I would go for a longer as opposed to a shorter jar. Let gravity assist in this matter.
Peter.
Small diameter clear tubes can be found at home depot, etc.
This vacuum setup has been used for over a century in Entomology (study of insects). When collections are made for very small insects. Instead of using a vacuum, you can use a bellows or suck really hard.
Insects that are in leaf matter on the forrest floor. I saw a similar setup in one of my Anatomy of Insect books from 1909.
Marcus
Current Built: Zeehaen 1639, Dutch Fluit from Dutch explorer Abel J. Tasman
Unofficial motto of the VOC:
"God is good, but trade is better"
Marcus
Come to think of it, I have seen them too in an entomology catalogue book.
Great idea. So those who were thinking they may have to buy another vacuum cleaner, they don't.
They are called Aspirators.
Edited by Tecko
Peter.
I recently moved into a codo so my large shop and scratch building days are over. My "shop/office, etc. is about 6' x 12' (next to the kitchen). I call it "the cave".  Not much room for a vacuum system. I recently purched a ShopVac Micro. It has plenty of power and so far seems to meet my needs....Moab/Allan
Completed Builds:
Ranger...Corel
Hansa Kogge...Dusek
Spray...BlueJacket
Under Construction:
