Do me a favour, count the posts which are related to this build, and subtrack them from the total postings on this build ... I don't mind some fun ... livens things up, but I start to wonder who's build this is
Carl
Mate,  have you thought of also doing a K class destroyer like HMS Kelly   aka from the film    -   https://en.wikipedia.org/wiki/In_Which_We_Serve
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
If I'm not mistaken, I should receive one presently ... I might make the whole UK destroyer fleet if I don't watch meself! I know there is a Dutch destroyer amongst the lot, just need to find it, and get a fitting kit to build it
Carl
Blue screen of death ?
Jack
Current buildUS Constellation
It depends how it locks up ...
it doesn't respond to anything anymore (not even Ctrl + Alt + Del)
you get a blue screen (of death)
is it a pc/laptop or a flimsy tablet ... options, options, options
Carl
When that happens, press and hold the power on/ off button until it powers down, wait a minute or two amd power back on.
Jack
4 minutes ago, RGL said:
I was going to say your IJN build......
:D:D  Did not see that one coming ! :D:D
Jack
There is a distinct difference between a PC and and a model ship, but as digibeet - what you call an illiterate - you probably wouldn't know
Carl
Tried my hand at the hull, airbrush anti-fouling... mixture Vallejo Air hull red 15 drops, white 1 drop, 10 drops of thinner, used for the hull 75 hull red (calculate the rest yerself lads)
5b4ce142d6a78_IMG_3760copy.thumb.jpg.c1e91d3ddd2f9fc5acfbac18463b0588.jpg5b4ce150e098f_IMG_3761copy.thumb.jpg.80dde8166a0d1e43579a574b852c0a9b.jpg
Cut the bridge's planking to size ... sweaty work...
Carl
Carl, did you cut individual strips or is it a piece of scribed wood or plastic? Nicely done, either way. Did you pre-shade the hull?
Ken
Started: MS Bounty Longboat,
Ha, no way, Ken. That's a piece of wooden deck from Musashi. As you can see on the grey part, I preshaded very lightly. Might have given a pass less of the red ... Next the water line and the uper hull. Something to look forward to for tomorrow
Carl
Never knew it was for that, thought you needed it to stick the decals on :huh:  I use painter's masking tape a lot cause it's wider and cheaper, the blue one. I let this dry unil tomorrow before I mask it
Carl
The red anti fouling has come out real nice mate.
OC.
Current builds
Completed works.
I use both tapes, although I try to cut the blue painter's tape with a straight edge to make sure the edges are sharp. Also stick it on my pant leg to reduce the stickiness of the blue tape.
Ken
really great progress so far Carl
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Nice work Carl.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Gents, thanks for the likes and the comments.
Ken, I read somewhere that a bloke stuck the tape to his forehead to make it less sticky ... interesting, as it would mean you are adding grease to the part below the masking tape. Not  something you would be looking for whilst painting a model ...
Carl
Hmm, another technique. I think I like the pant leg method, a bit of dust/dirt versus grease. Any grease/oils are anathema for our paints sticking properly.
Ken
Never seen this before, interesting technique. Would not use skin, that’s why I use acetone on all large pieces of PE now to help the primer stick, acrylics just won’t stick.
Edited by RGL
Greg
Acrylics don't adhere to PE, whatever you try to clean it. The only options are: 1. Use a primer which sticks to it, or etches into the surface, or 2. use an ageing agent like blacken-it. However, even the latter isn't 100% proof, if you dare, the most certain way is an etching primer. Since PE can be rather thin, you do run a risk
Carl
What primer brand do you find works best?  Testors ? Tamiya ? or ??????
Edited by Jack12477
Jack
On PE, Tamiya, vallejo doesn't stick, at least their airbrushable primer.
I've bought a rattle can primer from vallejo, which I have tot try. Since I do have quite a stack of PE leftovers, I'll be trying it on some of that. Let you know how that will turn out. I used the flat and gloss rattle cans from them, and those worked fine. A little getting used to in the beginning, as you do not see the quantity very well, so better a pass less than a pass to many I would suggest. You can always add another layer if needs be. I hope it will be as good as Tamiya. Tamiya is rather expensive here in Europe due to import duties, and transport. Vallejo is Spanish so that gives them a fair advantage
Carl
