Katsumoto
Santa Maria 1492 by Katsumoto - Artesania Latina - scale 1:65
3 hours ago, mtbediz said:
Very good job Peter. I tried to build Santa Maria last year as well. You can check if you want. May i ask which method you are using for tapering the strips at the bow? Do you cut or sand them? Thanks.
Thanks, I cut them with a knife along a steel ruler. Works very well. I didn’t know others like yourself already build the SM, I go and look into your log for sure. :)
Share this post
Link to post
Share on other sites
2 hours ago, nikbud said:
Lovely work, I really like the look of the walnut hull planking.
Thanks man, I really like the look of the walnut strips as well :)
Share this post
Link to post
Hi guys,
Today a small update on some other things. Planking of the hull continues slowely...
So, I made the base of the main mast.
Drilling some holes at the stern of the ship...
Some work on the hatch...
After the hatch I completed the work on the captains cabin.
Pter
Share this post
Link to post
4 hours ago, Wallace said:
That certainly is an interesting way to get the hull planked, and it looks decent too. Nicely done.
Thank you Wallace. I am pretty pleased with the result as well
Edited by Katsumoto
Share this post
Link to post
Well done Dutchman! Sharp and clean.... thats good craftsmanship.
Christos
Edited by MESSIS
Share this post
Link to post
Christos
Thank you Christos! I’ll do my best 🙂
Share this post
Link to post
Hi guys,
Today nothing special to show, only my progression of the planking proces.
So, on the picture below you can see the different line the second layer takes in comparison of the first layer.
Probably I will finish the hull somewhere next week or so...almost there....
So long,
Pter
Share this post
Link to post
***Chapter 10 - Hullplanking finished***
Hi Guys,
Today I have finished the planking proces of the hull. Both sides are the same.
 Sit back and hopefully enjoy!
And the finished hull...
Ciao!
Pter
Share this post
Link to post
Looks fantastic, you have done an excellent job!
Were there any extra difficulties in using pre-cut strips rather than one long plank?
Share this post
Link to post
Those pre-cut strips do not deter from the beauty of this hull. You have done a masterful job sir. Perhaps this is a method that could be adopted for my build? (at least for the first layer of planking. It would make things a little easier maybe......) I will have to give that some serious thought. Thanks also then for the inspiration :)
Share this post
Link to post
Thanks!
it works much better pre-cutting the strips. Easier to handle and the result is a nice pattern of colors on your hull.
Share this post
Link to post
Thanks Wallace. I’m sure your hull of the Victory will be a beauty as well.
You can apply this method to almost any hull, but sometimes an other method is needed depending on the ships timeperiod and origin and how accurate of the timeperiod you want to represent.
Share this post
Link to post
That is what will influence my final decision sir. I obviously want it to look right. But, if I do this on the first skin it will not be noticed :)
Share this post
Link to post
1 hour ago, Backer said:
Congratulations. Beautiful planking.
Which brand of beer do you drink  inbetween ;)
Hi Patrick, it was a Belgium IPA! Only the best... 😉
thanks!
Share this post
Link to post
6 hours ago, paulsutcliffe said:
Beautifully planked petr, a few coats of sanding sealer followed by some tung oil and that wood will look awesome
Regards
Paul
Hi Paul, thanks and it sure does after Some rubbing with tung or Danish Oil. 👍🏻
Share this post
Link to post
Planking Verdict: PERFECTO!!!!!!
Am anxious of what is to come.
Still long way untill embarking to America Dutch Colombus 😎
Christos
Share this post
Link to post
Christos
Thanks Christos. I’ll set sail for the new world and probably end up in Greece. 😎
maybe you’re in to be first lieutenant and we will start a new Oddessy!
Share this post
Link to post
I I Sir! But I am a bit further away than Greece.... I am in Cyprus. So no Odessy but still... I can take you a ride with the Kyrenia Ship replica of 450 bc!
Edited by MESSIS
Share this post
Link to post
When it's all about the rudder...
Hi friends,
Today I finished a simple task....constructing the rudder! However, Columbus set sail for the Indies and ended up in current America. So the rudder is part of keeping the right course and is pretty significant for this ship.
Before I'll show you the steps of constructing the rudder, first some other work I've done this weekend...
Step by step she turns into a nice ship...
Back towards the rudder then. It comes with the kit pre-made from walnut and all I had to do is some sanding to get rid of the laser burns.
I didn't liked the thickness of the wood, it felt to bulky to me and I was wondering what was wrong. So after a while I decided to taper the end part of the rudder.
Much better result so to say. Less bulky!
So in the next picture, I'll show some parts. The rudder, the helm(stick) (red arrow) and a metal band which is made from a strip of brass. (green arrow)
I decided to use some walnut veneer to cover the reddish wood because I didn't like the color. Also the hole is to large for the rudder to fit so I changed that as wel and made it smaller.
Next step is constructing the hinges. The premade hinges are way to big for this type of ship. So I changed it and made them a bit less bulky.
The pins are made of some 1,5mm brass roundbar.
So, normaly I use Brass Black of Birchwood Casey to blacken my brass. This is packed into a container and stored for the move to another house. So a new bottle costs about 25 USD over here in The Netherlands. I had some black paint on the shelve so I used that in stead.
Continuing the assembly of the rudder...
And placed the rudder on the ship...
So far so good, until the next episode / update. I wish you a very nice day and thank you for reading and replying on my log. I highly appreciate it!
regards,
Pter
Share this post
Link to post
12 minutes ago, nikbud said:
Stunning Stern Sir!
I keep repeating myself, but damn she looks good!
Thank you Sir! Keep repeating 😄
Share this post
Link to post
If there is such a phrase - meticulously fantastic! The intricacy and attention to detail is worthy of praise sir. Very well done. I will repeat myself too - you are truly an inspiration.
Share this post
Link to post
You give me too much credits Sir, thank you!
Share this post
Link to post
Credit where credit us due. You have done a great job. In German I would say: Wahnsinns gut :)
I know you are not German but I can't speak Dutch :)
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
    No registered users viewing this page.
The Guild is a non-profit educational organization whose mission is to provide support to our members in their efforts to raise the quality of their model shipcraft.
The Nautical Research Guild puts on ship modeling seminars, yearly conferences, and juried competitions. We publish books on ship modeling techniques as well as our world-renowned quarterly magazine, The Nautical Research Journal, whose pages are full of articles by master ship modelers who show you how they build those exquisite details on their models, and by maritime historians who show you what details to build.
Our Emblem
