That would be great! If the scale is not in the 1:48 range, I would certainly consider buying.
There is a set of drawings around from the Lelystad Werf were they do the replica (Drazen is using that set for building is model of the ZP)
btw: this painting is also coming from Lelystad, it is an artist impression of the replica afloat.
Jan
I still don't understand why mamoli has installed rubbing strakes on the hull.
It is completely 'undutch'....
Nevertheless: she's turning into a nice lady!
Jan
Edited by amateur
Hi I just noticed your buildlog this week for the first time. looks great specially the modifications i saw you did to the standard kit
Jan V.
current build: Vasa-1628 Corel / Battle Station Mantua/Panart,
previous: Statenjacht / Cross section HMS Victory / diorama shipyard
Amazing work here! I've always been curious about this kit and it's nice to see it come alive in such capable hands. Just read through this log with great interest - I'm also happy to hear that you put your modelling work to such good causes!!
hamilton
Hmm does anyone know what wood is used for the second planking of this kit?
Kits owned: Mamoli Royal Louis, Mamoli Friesland, Mamoli HMS Victory 1:90, Occre Santisima Trinidad, Constructo HMS Prince
I have had much enjoyment reading through your log,absolutely stunning build AJ ,love it to bits :wub:  :wub:
I look forward to the next installment.
Kind Regards Nigel
Currently working on Royal Caroline
Beautiful!
hamilton
Hello,
I know this may be a bit late, but could you please explain, with photos if possible, or
even drawings, how you were able to make all those "diamond" cuts so symmetrical, and precise?
Also, if you don't mind, the gratings on the first level seem to pop out of the deck, but you have
the borders somehow tapered as you reach the grating.  Again, photos would be great.
Appreciative and desperate novice.
Many thanks.
Which cuts do you mean, actually?
Those oval shaped 'holes' in the stern are made by Mamoli.
The gratings are glued on to the deck, and a small strip of wood (slightly thicker than the deck planking is glued around them. The gratings themseleves are build up from prefabricated (by Mamoli) strips of wood.
Jan
Edited by amateur
How do you get your gold decoration to look so shiny?
Thanks for your response.  The "diamond" cuts I'm talking about are the triangular looking cuts made at the tips of most standing columns.
If you look at Mamoli's instructions for the Friesland page 2,  it is shown as part number 46, figure 10.
Thanks.
Figure 40.jpg in your blog is a great example of what I'm asking about.  I believe it is called a diamond cut because, the tip of the column actually looks like a big diamond.
Thanks again.
Hello Alfonse, I actually just filed down the ends of each square piece with a  fine metal file until they all matched then glued the pieces together to make one piece overall, then I drilled holes in the bottoms to place a small metal nail and to fix to the deck.   The grating on the main deck is supposed to be flush with the deck also just like the upper decks, I chose to raise them a little, just a personal touch.
Hi Greatgalleons,
I got my Friesland kit recently and have started to work in it.  It's only my second build, so I'll be relying heavily on your posts to guide me along.  The quarter galleries look especially challenging.  Mamoli has made some changes to the kit because the first thing I checked were the lower deck cannons, and they appear to be the correct length.  There may be other improvements but I don't know yet.  The one obvious disappointment is that the mast dowels are not made of walnut but some light wood that I'll have to stain, although I'll probably just buy some walnut dowels.
At any rate, keep the posts, especially the pictures, coming.  If my build comes out looking anything like yours I'll be extremely happy.
Steve J
I do not have any recent photos of this kit build because I was offered a price I could not refuse for the finished hull.   I would have liked to have finished it with the mast and rigging.   It was always intended to be for sale, but not so soon.    I do not usually get into the mast, spar and rigging in my logs because I figure square rigging is  common knowledge among ship modelers.  I mainly focus on hull construction.
I'm really disappointed that there won't be any more updates to your build, but I don't blame you for taking the money.  I would, however, like to follow up on a couple of items: how do you make the ornamentation look so nice and shiny, and what is JB Weld, the stuff you use to attach the ornamentation?  Where can I get it?
Many thanks for your excellent posts and pictures.  I'll miss the updates.
Steve J
