I use  Revell  Styrene poly cement.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Tamiya Extra Thin with the green cap. It's acetone based so it evaporates pretty fast. Hold parts in place, a quick swipe with your glue brush, count to 5 and it's bonded. Not super hard; should let it set up an hour or so. I generally have 3 kits going, so I can rotate through various steps in a session.
May want to rough up the mating surfaces even for CA glue.  That works on resin parts, too.
Ken
Started: MS Bounty Longboat,
I tend to rough them up too......I'm finding more kits don't have "square" edges.  could be something with the plastic too.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
I use plastic specific glue for the kit parts from the spruces, anything else metal like is attached with CA. I like BSI insta-cure+ . No specific treatments whatsoever. I do, however, remove any paint from the surfaces which will be glued, but for the spot where I need to glue a brass piece on if that happens to be after painting. I try to get all brass on before priming, which, as you will have encountered also, is not always evident
Carl
