Mosel by Dan Vadas - Papershipwright - German Monitor, 1872 - CARD - FINISHED
Hi all, here's a simple free download from Papershipwright of a German Monitor named Mosel. I'm building this while waiting for my next "real" model. It should only take me less than a week to build this one.
Work starts with the bottom of the hull. This is a Waterline model, which simplifies everything a lot :). There are five tabs on either side in the almost straight midsection :
The internal bulkheads were fitted next :
Then the three decks were laminated to 0.3mm card and fitted to the hull :
Next the model was attached to a piece of heavy card as a "building board" using double-sided tape, and the sides were fitted. The support struts were rather flimsy until I glued a second piece inside them :
I've made the Turret "turnable" :
So far it's taken me 3 days to get to this stage.
Danny
Link to comment
Share on other sites
Believe it or not - I've finished this boat already :). That only took 4 1/2 days.
There are extra hatch covers which can be glued to the deck to make them look more realistic than simple printing :
The bridge had some rather flimsy legs, but it all turned out OK with a bit of care :
I've used some PE railings left over from one of my previous builds. This comes out a lot better than trying to make them from thread as the kit suggets :
The ship's wheel took a lot of careful cutting. It's only 5mm in diameter between the tips of the spokes :
I used my hole punch kit to make the various diameters of round pieces of the Capstan :
The middle deck Ventilators. There are two smaller ones on the fore deck :
The funnel has 3 steam pipes attached, which I cut from paper :
The Galley and two Heads were pretty straight-forward, although I cut all the tabs off and edge-glued the various joins :
The Bollards are the smallest ones I've made so far that use a rolled paper tube :
If I thought the bridge legs were flimsy, they paled in comparison to the Awning Supports. I wicked some CA glue on the edges for strength :
The Anchors and Chain. I used 40 link-per-inch :
The ship's boat was quite easy to make. It consisted of a mere 4 parts :
The tiny Navigation Lights were a bit of a pain to make :
And some overview pics of the completed model. It is only 200mm long :
The Companionway in this pic is also left-over PE. There is another behind it on the middle deck :
And the last piece fitted (as usual) - the German Imperial Flag :
I still need to make a base for the model. It will be a simple piece of Card, painted blue.
My next model arrived yesterday - just in time :D. It's a WW2 German tank, a Stug 40. A link to the build log for it will appear in my signature when I get started on it.
Danny
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
 Share
