Hannah by jct - FINISHED - somewhere between 1/72 ish and 1/60 ish scale
Well...here we are, almost 3 months since I visited the Hanna...I was busy with some non-ship builds, sometimes I need a bit of a break...but this build will resume, so today's progress
The mast hole are drilled and the dowels cut to length
and teh deck grates have been assembled and cut to rough shape, they all still need to be finish sanded
IMG_9895.JPG.432be07f93edd99d81c80e1c3c74a37b.JPGIMG_9897.JPG.bc0a4b1fd40a59e47252141facc2da7b.JPGIMG_9898.JPG.a9d469e0424f1ad2c346b4ca9382f334.JPGIMG_9899.JPG.2134e8ca02f5714b51f90f750fe76d3d.JPG
nothing is attached just placed to check sizes
Link to comment
Share on other sites
Spent more time on the deck gratings...sanded them and attached the comings
IMG_9901.JPG.55069719efd28017938ca7e00714c026.JPGIMG_9903.JPG.8f95427ade0ed41d811c7da2b21a8558.JPG
just laying out the deck at this pointIMG_9904.JPG.b0bf74a2faf8006c82db9503cdc2affe.JPG
ditto
Still have the deck houses to build as well as the binnacle, belfry, and the cheeks for the windlass
Link to comment
Finished the binnacle
Started with a framework of basswood
and added trim made from 1/16 wide strips of walnut veneer
needs a little more sanding before paint
Link to comment
nicely done J
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
A bit more to add...thanks to all who've commented or hit the like button...much appreciated
The comings were painted the red ochre mix but the grates left natural, a sure test of my cut-in skills :P...the grates were stained with a natural stain...poly will follow laterIMG_9915.JPG.0e53416a4f4f26b5362ef0ba553e443e.JPGsorry for the lousy focus IMG_9917.JPG.79ae5ecc301578599f76006e0f75a783.JPG
the deck houses and binnacle were painted as well
along with the windlass cheeks
two coats of tallow were applied the the hull bottom...IMG_9920.JPG.83bdb29685b93a0c6d1a5c5528db32a5.JPG
the rest of the hull paint will be added over the course of the week...I want this stuff to have plenty of time to cure out...this is infamous model shipways paint but thinned with iso and distilled water (50,25,25 ratio), seems to make a difference in how it lays down
Link to comment
THX to all participants...a little more to add
Today I was working on the "iron" banding, for this I broke out a specialized tool not used for shipbuilding so much but priceless for glass work, they are pattern cutting shears...three bladed scissors that remove a fixed width of material in the center.   For glass this leaves space in your patterns for the came between the pieces.  I use them here to cut card stock to a perfectly uniform width
here you see some painted black
and applied to the windlass to simulate the iron banding
and here as hinges
Applied poly to the finished deck furniture...still have to build the belfry, pumps, and the Charlie Noble, among other odds and ends
Link to comment
Hi Dave
Any stained glass supply place would carry them, but with that said... those stores have gotten few and far between around my area, here's an amazon link for those interested
 Stained glass pattern shears
Link to comment
Hi folks...today's update
Decided to work on the belfry, here's a shot of the plan view I was trying to replicate, the curved top being the challenge
Started by tracing the curve from the plans to a piece of scrap basswood and giving it a ride through the bandsaw...
which left me with  couple bending forms, to clamp around soaked basswood IMG_9930.JPG.41da118558613e21f2f2539adf6fc367.JPG
left it overnight to dry
here's the original piece...unfortunately the bend did not hold and within a few hours was almost flat, so I repeated the process but this time laminated the basswood strip with walnut veneer, this was successful...you can see the completed pieces belowIMG_9934.JPG.8224585c8fbeced973be169ae83a9060.JPG
the uprights had notches filed in them to accept the cross beam...
IMG_9936.JPG.0e741096d785e44be2300258bd04245f.JPG here's the glue up
the paint is still wet...thus the shine...still have to figure how I want to do the bell, may just turn a chunk of styrene, got plenty laying around
thx to all for the likes
Link to comment
Link to comment
Link to comment
Testing how I can add updates through my phone...going to be away for most of the summer with limited or no internet access.
pic is just a watercolor I had finished last year and had a pic of on my phone
Link to comment
very nice progress on Hannah :)   sweet job on the binnacle and belfry.   I'll likely late in catching you,  but enjoy the summer and your trip!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Gonna try to chip away at the Hanna while I'm hanging out in the RV...not sue how the pics will turn out as I'm using my phone with just lighting from the dining table but we'll give it a try...
I got the base color scheme laid down...three coats on all but the black....only two needed there
still a little touch up required here and there...started working on the rudder...groves were filed for the pintles and color applied...the pintles themselves are just more of the painted strips with small bits of dowel added
Well that's all for today...may add more tomorrow, gonna depend n the weather :rolleyes:
Link to comment
Hi all, continued working on the little stuff...worked up the gun carriages...IMG-0030.JPG.9bd6c7d24763247e7a0ef0e61d8100d7.JPG cut and glued up small bits for the sides, base and axles...
and painted them all
while I was laying out all the fore deck accessories I discovered a major fubar....I drilled the foremast mounting hole to far aft...it should be where the yellow circle is.   If left where it is the windlass placement will interfere with the gun carriages...guess I should have triple checked.
Plan is to fill the hole with a dowel, the windlass will cover it so hopefully it wont be to noticeable...shezz
Edited by jct
Link to comment
Well thats an ooops, not like I havent made plenty of my own. At least the windlass will cover it. No one would know if ou hadnt said anything.
Your lighting doesnt look bad, remember you can take a piece of white notebook or printer paper and use it to reflect some light into the shadows.
The other parts look good to my eye.
Sam
Current Build Constructo Enterprise
Link to comment
Link to comment
Don’t feel bad.  We all have them. And some are real doozies!  The windlass will cover, but I agree with a dowel up to the level of the sub deck and then fit in little pieces of decking to match your planking pattern, to camouflage the boo boo!
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
