Hi all model makers. I love our hobby ,the only thing that scares me when building is doing the name on the boat and scroll work if needed. I grew up with applying decals to all my plastic kits and that was easy.   However ,  I'm just about nearing the end of the Bluenose by Model Shipways . The build has been a labour of love but always in the back of my mind was the dreaded lettering and scroll work , If you could offer some advice I would be most grateful. Thank you all and happy boat building....Jim
Maybe if you could photograph the work required and then take it to a lettering shop or maybe Officeworks and get them to print same to the scale required onto an adhesive backed vinyl strip , you can then strip the backing off and stick it to the hull.
Maybe you can get some Lettraset.
just a thought.
Eddie.
Current Projects: Souvereign of the Seas by De Agostini
                            Sciabecco. By Amati
Finished projects: Port Jackson by Modellers Shipyard
                             Botter boat by Amati
                             King of the Mississippi by Artensia Latina
                             Endeavor by Artensia Latina
Fabric shops here have letter size sheets of Mylar, used for patterns.
A computer drawing program = font sizing and rotation
Web has sites with free fonts.
An exact pattern of the location can be made from the model and that scanned into the drawing program
You can practice the scroll in the drawing program.
Print the result on the Mylar - cut it out and you have a stencil
double stick tape to reduce seeping
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Custom-printed decals would be my first thought. However, you need a special printer that is able to print 'white'. It is a while since I searched the market, but then there were only one or two models around for home use. There are various suppliers for custom-decals for modellers though.
Not sure how good the market for these still is, but there are also dry rub-on letters, e.g. by Letraset. Dito. for lining, inclduing curves - check out model railway supplies.
It would be probably an overkill for just one or two name-boards, but one could also etch a stencil from thin brass and then spray-paint with it the lettering.
Finally, there is a steady hand ... 👹
Testors makes a Clear and White background inkjet decal paper. Try Testors  and DecalGear.com - Decal Accessories for scale-model hobbyists
Jack
Current buildUS Constellation
A lot of people make white decal paper - but that doesn't give you white letters ...
A semi steady-hand option would be to print the outline of the lettering on a clear decal sheet and then fill the letters with paint, while the sheet is flat on the table. Should be a lot easier than doing it on the model and wou have infinite tries too.
Use the white background paper for white letters.  You have to match the color of the surface you are putting the decal down onto for the area surrounding the letters so the decal doesn't show.  Remember to make sure the surface where the decal is going has to be glossy so the decal doesn't "silver" with trapped air between the decal and flat paint - apply the appropriate dull or matte coat over the decals once dry.
Kurt
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Kurt
Toyed with this idea at various times, but unless the background has a uniform and 'simple' colour that seems to be difficult to achieve, even, if you cut the decal very close to the lettering, thus minimising the printed area.
The Bluenose is a perfect subject to use white decal paper on because the hull is black. I have made 2 MS Bluenoses and drew the name and scrollwork in Turbocad, with the yellow and black printed, leaving the letters white. It worked great and the decal was all but invisible.
From about as far from the ocean as you can get in North America!
