Really makes me want to experiment more with shellac as it seems to penetrate really well compared to other options.  I would guess the tensile strength is nothing compared to super glue though. 🤔
Glad you're sharing your experiences Phil.  Thanks as always.
Edited by Coyote_6
Steve
San Diego Ship Modelers Guild
I decided to test several "glues" to see which was best for bonding polyester rope.
I used Syren Ultra Brown 0.018 inch (0.45 mm)scale rope in these tests. It is a medium size rope that provides a good surface area and volume to test the adhesives.
The "glues" were:
White glue - Office Works acid free school glue. It was used full strength, undiluted.
Sig-Bond  - an aliphatic resin.
Duco Cement - an acetone solution of nitrocellulose.
Loctite Super Glue Gel Control - cyanoacrylate (CA).
Zinsser Bulls Eye Shellac - from spray can. I sprayed into a small bottle and then painted the shellac onto the rope with a brush.
I twisted two strands of rope together and clamped both ends. Then a liberal amount of the adhesive was painted onto the strands. I used a metal needle to work the liquid between the two rope strands. Then the rope was pulled tight and twisted to keep the strands together while the glue dried.
gluetest1.jpg.e085bff624ab296110c6e3c0311af372.jpggluetest2.jpg.5558744cdb953a40970ca58d6b2329ba.jpg
After the glues had set for 12 hours I clamped the ends of each strand with forceps. One of the forceps was clamped to the edge of the work table. On the other forceps a line was looped around the handles and the other end of the line was attached to a plastic bucket hanging above a small waste basket. The waste basket was there to catch the quarters when the bucket fell - they tend to "splash" out of the bucket when it lands.
I have a box full of US quarters (25 cent pieces) for spare change. Quarters weigh 0.2 ounces or 5.6 grams. These were my test weights.
gluetest3.jpg.9ab1b6b45be444135320e160f8ba8b47.jpggluetest4.jpg.8a206bbec542a85763eb2a2edb760a32.jpg
With the bucket suspended from the lower forceps I added quarters to the bucket until the weight was enough to break the glue bond. Or that was the plan. Here are the results.
Shellac - 0 g - The rope strands separated before I got them clamped into the forceps.
White glue - 1187 g - With 2 lb. 9.9 oz. pull the cement failed.
Sig-Bond - >2080 g - With 4 lb. 9.3 oz. pull the rope unravelled and pulled from the forceps before the glue bond failed. *
Duco Cement - 2196 g - The glue bond failed with 4 lb. 13.5 oz. pull.
Super Glue - 1410 g - the rope broke with only 3 lb. 1.7 oz. pull before the glue bond failed. The rope strands were tightly glued together but I could pull them apart by hand. *
* The Sig-Bond and Super Glue failures were due to experimental design. When the rope was clamped in the forceps it tended to unwind. With the Sig-Bond the unwound strands pulled out of the forceps. With the Super Glue the strands frayed and cut along the edge of the forceps jaws. To do the experiment properly some means must be developed forholding the ends of the rope strands securely without damaging the rope.
It is clear that shellac alone does not bond the rope strands together. It does serve to stiffen the rope. White glue was easily the weakest of the four glues. Sig-Bond produced a strong attachment between the rope strands, but it dried with a thick off-white crust on the ropes.
Duco Cement and the Super Glue did not leave a noticeable residue on the ropes and both were better than white glue. Duco smells like acetone - it is the familiar "glue" smell from my childhood, and I don't find it objectionable. So little is used it isn't a hazard. Super Glue has an odor that really bothers some people. It makes my eyes burn if I use it a lot.
I think I will use the Duco Cement from now on. Duco starts getting sticky in 20-30 seconds and sets in a minute or so, leaving plenty of time to tidy up a seizing. Even the "slow" Superglue gel starts to harden before I have time to finish the turns in a seizing, without reworking them, leaving a lumpy seizing.
Edited by Dr PR
Phil
Current build: USS Cape MSI-2
Current build: Albatros topsail schooner
Wow Phil!!  That is impressive.  You have done your fellow modelers a profound service with keen findings.  Thank you very much.
I had procured Duco on previous recommendation from you.  I have used diluted white glue previously and liked how it soaked in and dried with little indication - so the million dollar question:
Does Duco soak in and cure to a nice flat sheen, or do you find we will need to use Duco sparingly and possibly dullcoat afterwards?
Your tests are compelling!
Edit -  I see my million dollar question was asked and answered above - "Duco Cement and the Super Glue did not leave a noticeable residue on the ropes and both were better than white glue."
The Duco soaks in nicely then?
Edited by Coyote_6
Steve
Steve,
I have been using Duco or something like it since I was a kid (1950s). It soaks into and adheres to anything that is porous. In the test I used a metal point to work the glue in between the rope strands. But I think it is fluid enough to soak in on its own.
The polyester rope tends to unravel after it is cut. I always stick the freshly cut ends into the opening of the Duco cement tube to get a drop on the rope end. Then I twist the rope end between my fingers and the glue soaks in. When it dries (a few seconds) the end of the rope is stiff enough to push through holes in blocks and such.
Even though I wipe my fingers immediately on a paper towel, I do go around with dried glue in my fingerprints! But unlike CA it wears off quickly.
Duco does leave a dried film on anything it touches. In the case of the ropes it isn't noticeable because the surface isn't smooth. But if you look closely with a magnifier you might be able to see traces of the glue. Where it soaks into wood surfaces it can change how stains appear so use it sparingly. For most wood to wood jobs I use Sig-Bond aliphatic resin. I think Titebond is about the same.
Edited by Dr PR
Phil
Thanks Phil.  I am very thankful to have your Albatros build log as reference for the Prince.  The Albatros looks great and is just well thought out.
Steve
Well it has been "thought out" many times. Each time I think I have the final solution I run across more information that makes me think it out again!
I have a bit more progress to report.
I finally got the fore course yard in position with all the rigging (I think)! After failed seizing, broken hooks, adjusted sling, and I don't remember how many other hassles it is hanging in the right place!
There were other reasons for delays in continuing with the model. I traded in my 15 year old car for a new model. It has more bells and whistles than the US Navy! I have spent much of the week reading about 950 pages of the User Manuals to figure out how to make all that stuff work! And I had to wire a new circuit in the garage so I can plug it in for charging. Lots of fun!
And the non-profit I am Treasurer for learned that the Federal funding for a three year project has been cut off! That has left us scrambling! We have contracts with a couple of businesses for the project, and some materials for the project that are already paid for. So we may have an unfinished project, wasting a lot of taxpayers money for the work already done. I guess this is the new "government efficiency." I wonder how many unfinished bridges there are in the country now?
So it has been a hectic week. I am glad to be back at ship modelling!!
Phil
More progress, sort of ... Two steps forward and one step back.
The fore topsail has sheets, clew lines and buntlines attached, along with the blocks for the clew tackle. This is the aft side where the bolt ropes are attached.
Here is the sail installed on the fore mast. The bunt lines attach to cringles on the foot of the sail. They run up the forward side of the sail through wooden thimbles lashed to the topsail yard and up through single blocks attached to the top of the fore topmast. They lead down through fairleads on the mast top crosstrees and then belay to the fife rail at the bottom of the mast.
Another picture from the rear.
Things are getting crowded around the fore masthead! The topsail yard halliard, clue lines, topsail yard lifts and fore course yard lifts also run through the crosstree fairleads and down to belay at the fife rail or the bulkhead pin rails. So far the lines are running clear with no chafing. I may not need to reroute any of them!
While rigging all of these lines the halliard slipped a bit, lowering the topsail yard - probably while I was rigging the buntlines. I didn't intend for the sail to billow out as if there was a strong following wind! Fortunately all of the lines are belayed with just one turn around the belaying pin, and held in place by water soluble white glue. So it is pretty easy to place a drop of water on the glued area and readjust the length of the lines.
Pretty obvious are the dangling topsail yard brace pendants and locks. I have discovered that I didn't order enough of the 0.012 inch (0.30 mm) tan rope from Syren. But I did order one extra dark brown 0.012" package! I made the order calculations with my rigging spreadsheet, and I may have mixed the tan and brown ropes when selecting rope length cells. Or maybe I just used more rope than I calculated - I need about four feet more! I have ordered more. Work doesn't have to stop though. I have all the rope I need to finish the foresheets.
The topsail yard braces will be some of the last lines to belay. I don't look forward to that! They belay on the rail at the base of the main mast, and that is one of the most inaccessible places on the model! It took me one hour each to rig the main topmast staysail halliard and sheet on that rail! The topsail yard braces belay inboard of those two lines. I'll have to devise some tool to improve my chances of rigging these lines!
Edited by Dr PR
Phil
One more! The fore staysail is pretty simple. Lever (The Young Sea Officers Sheet Anchor, page 59) said that fore staysails were not used on merchant vessels, but were only used on warships. This likely applies only to square rigged vessels, for multiple foresheets are common on fore-and-aft rigged vessels. But you can see from this photo why the fore staysail and the main course would not be flown at the same time. The clue of the staysail extends back behind the fore mast, passing through the space where the fore course sail would hang.
Schooner sails were mainly fore-and-aft with the occasional square topsail, topgallant and maybe a fore course. So the fore staysail was probably used in most cases, with the course rigged only when there was a good wind from astern.
I had to find a place for the halliard block pendant to attach to the mast top. Rather than tie it to the stay as is sometimes done I lashed it to the front crosstree, similar to how the main boom topping lift pendants are attached to the aft crosstree on the main mast top.
I attached the fore staysail and jib block pendants to the crosstree before attaching the topsail. The topsail hangs down over these blocks, making it a bit harder to rig the sails. In hindsight it would have been a bit easier to rig the fore staysail and jib before adding the topsail!
The staysail tack is lashed to the port side of the bridle for the lower forestay open heart. The staysail downhaul block is lashed to the starboard side of the heart bridle. The downhaul is belayed to a pin on the starboard bow pin rail.
I have tied all of the hanks to the sail, but the glue is still drying so I haven't trimmed the loose ends of the lines.
The sheets are not rigged yet. The sail interferes with getting to belaying points on the fife rail at the base of the fore mast. With the sheets loose I can pull the sail back forward to open access to the fife rail.
I have learned that good access to the fife rail is important. Each of the many lines to points on the fore mast interacts with all the others. I did haul the topsail yard back to its highest position, and this put some lift on the fore course yard. That in turn loosened the fore course yard truss lines and the fore course yard lifts. So those lines had to be tightened.
Again, it was wise to use white glue to secure lines after they have been belayed. Adding a drop of water loosened the glue so I could pull the belayed truss and lift lines tight again. And I had to adjust the fore topsail buntlines after raising the topsail yard.
I would be willing to bet this won't be the last time I need to adjust lines before the model is finished!
Edited by Dr PR
Phil
I found time today to install another sail - the jib.
The jib halliard is rigged like the fore staysail halliard - through a block that is tied to the forward crosstree on the fore mast top. The tack is fastened to the jib preventer stay just above the bees on the bowsprit. The downhaul runner block is also belayed to the preventer. The downhaul runs through this block and belays on the starboard bow pin rail. The sheets have not been rigged so the sail can be pulled forward to provide clearance to the bow pin rails.
Only one sail to go!
Phil
Man Phil - the sail color is just spot on.  Looking very good!
Steve
Yes Phil, I second that. The sails look incredible. Appearance, color shape etc. definitely worth the fuss. Beautiful work.
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
I have been thinking abut a problem that developed as I was adding the fore topsail to the mast. You can see it in these pictures.
Liftandsheet1.jpg.a5e7aace7068365c3eb6621602aaa8b2.jpgLiftandsheet2.jpg.de67f8e3b002ce650790e1e08ea85880.jpg
The lift blocks and sheet blocks were jammed together, and the lift lines were rubbing against the sail clews and the clew blocks. It looked OK "on paper" but just wasn't right after the sail was installed.
The sheet block was in the correct place, with the sail clew and clew line block OK. I decided to remove the lift blocks and give them a longer pendant. But I had to do this in place, and things were a bit crowded. Some vessels used a sister block or "violin block" with the lift running through the inner sheave and the sheet in the outer sheave. And in some cases the two blocks were just stropped together end to end to keep the two lines separate.
Liftandsheet3.jpg.0a0db3ffdcfecc80f8476bd5dc4900f4.jpgLiftandsheet4.jpg.73a449a0abc56e0168a69c5ab21d7d7e.jpg
Now the lift blocks fit under the clew of the sail and the sheet is free to run naturally. It wasn't as much trouble as I thought it would be. But Murphy did get in his licks. While removing the old lift blocks the plastic hook on one of the double blocks at the mast top broke! I replaced the plastic hook with one of my metal hooks and the repair was finished. One step back, one step forward.
All of this happened while I was installing the outer jib.
That was the last sail!
Like the other fore sails the sheets are still hanging loose. But the rest of the rigging is in place! Two steps forward.
The nomenclature for this sail is a bit confused. Some authors call it the outer jib, but others call it the flying jib. However, the term "flying" sometimes means a sail is not attached to a stay, but is hanging only by the halliard and tack. But there are many references showing a sail that is riding on a stay but is called a flying jib anyway. Likewise the main sail is sometimes said to be flying if there is no boom, and in other books is is flying it it is attached to the boom only at the tack and clew, without being laced to the boom. This is also called "loose footed." So the term "flying" seems to mean different things to different authors.
With the installation of the outer jib almost all of the rigging is installed. Most of the lines are belayed and only a few need to be adjusted. The belayed ends are still a couple inches long to allow them to be adjusted, so the deck looks like a bowl of spaghetti. But most of the work was done!
And then the backdrop I was using for this last photo fell over and hit the model! The blow caused the seizing to fail on the starboard sheet block attached near the center of the fore course yard! It was in one of the most inaccessible places in the rats nest of rigging just under the fore top.
One giant leap backwards! Murphy was busy today!!
If there are any newbies following this log keep this in mind. If it can go wrong it will go wrong!
Edited by Dr PR
Phil
Wow Phil.  "Albatros" looks splendid!  Good luck on that rats nest repair. Last week I dropped the PdN and made a quick grab, and my first ever rigging is now my most recent rigging.  It was vexxing but accessible at least.
It'll be interesting to see your approach to the tight repair, as I am sure Murphy has more in store for all of us and you always take a well thought out approach.
Finally, how many more plastic hooks does "Albatros" have?  That has been a tough lesson!  I hope to make a bunch of brass hooks today, but not as pretty as yours!
Good luck pushing her across the line Phil.
Steve
Thanks for the encouragement guys!
The irony in this last goof-up is that I was trying to get a better picture of the outer jib. I was using a white dry erase marker board as background and the shiny surface was reflecting the ring light. So I repositioned the board, and as I stepped back to take the picture the board fell over against the model. Fortunately I was still close enough to catch things before the model took a dive to the floor! Otherwise I might be thinking about reconstructing a lot more of the masts and rigging!
So Murphy didn't have the last say! And I relearned a lesson that I have learned far too many times in the past - pay attention to what you are doing!
The model kit was titled "Albatross" but I  can find no record of a real vessel with that name. And since I am building a model of an imaginary 100 ton revenue cutter of the early 1800s I have been reluctant to give the model a name. That might imply that it is a model of a real vessel.
But now I am thinking of calling it Murphy's Jest or something like that!
Murphy's Joke
Murphy Bait
Murphy's Taunt
Murphy's Fun
Edited by Dr PR
Phil
I like Murphy’s Jest but I think giving it a name is appropriate. As long as you have with it a note as a representative 1800’s revenue cutter somewhere so when someone finds it in like 100 - 200 years from now they know. Lol.
Steve,
There are still too many plastic hooks on this model! But take note that they are not failing during the normal rigging process. I don't put a lot of strain on the lines, just enough to make them run pretty straight. The hooks are breaking when I screw up and accidentally put too much stress on the lines. Murphy again!
I repaired the sheet block.
Sheetblockrepair1.jpg.3165d653391f92c2923ca621a705a72f.jpgI wrapped some 0.025" (0.63 mm) rope around the block for stropping and glued it in place around the block with white glue. Then I put a drop of Duco Cement on the two strands and wound some fine black cotton thread around it to create the seizing.
After that was set I looped the long end of the 0.025" rope around the fore course yard inside the sling cleats (in the photo at left). I tied a piece of black thread around the rope strands with an overhand knot. Then I put a drop of Duco Cement on the two rope strands and held them together a few seconds until the glue started to set. Then the long end of the thread was wrapped around the ropes to finish the seizing. It was a tight fit!
One point in Duco Cement's favor - over CA - is that like the white glue you can loosen the knots easily, but with a bit of acetone instead of water.
The sheet rope had a small block seized to the lower end as part of a runner tackle. Since I couldn't pull this through the sheet block the sheet rope was pulled back and held out of the way with blue tape while I made the repair.
Then I discovered that the sheet rope was wrapped around the footropes on the yard and one of the other ropes descending from above! I had to remove the lower block from the end of the sheet rope and reroute the line through and around the rats nest of ropes around the mast top. Of course, I had glued the lower block strop seizing with Duco Cement, and it didn't want to come undone. But the strop was glued with white glue where it passed around the block. A little water on the strop to loosen the white glue and I was able to pull the block free. Then I had to soak the seizing in acetone to dissolve the Duco Cement. After a while the seizing came off and the rope end was free. I didn't want to wet the block with acetone because the dye that I used to stain the block might wash out.
Sheetblockrepair2.jpg.2409614d9757f69aaceec59f60aba5b7.jpgAfter rerouting the sheet rope the lower block was attached again - with Duco Cement to ensure that the seizing doesn't fail.
This photo shows the repaired block, with the sheet rope threaded through and around the other lines so it descends to the runner tackle belayed to an eye bolt on deck and a pin on the fife rail at the base of the mast.
In the process the course yard creeped up on the mast again. It should be just at the top of the metal shield for the gaff jaws. Now I will need to readjust all of the lifts, sheets, buntlines, trusses and braces to get it back down again!
Maybe Murphy's Folly would be a good name for the ship.
Edited by Dr PR
Phil
You have great processes Phil.  Glad to see her back in ship shape.
Steve
One less plastic hook on the model. The crash also broke the hook on the top block of the main gaff peak halliard luff tackle! One step back.
I am repairing it using one of my metal hooks. Another step forward.
Look at it this way - all those broken hooks and failed seizing just lets me have the pleasure of doing the rigging again! Thank you Murphy!
Phil
Just another opportunity to excel and perfect. So close to the finish line.
I see what you did there.
Steve
The model is fully rigged (almost) - I think. All of the sails and running rigging are in place. I still have a lot of tidying up to do to trim excess line lengths and add the rope loops to belaying points. But I think all of the lines are in place except the ratlines.
The thought of tying thousands of knots for the ratlines brings nothing but joy to my heart!
One more plastic hook broke. I replaced it with one of my metal hooks.
I suspect it will be necessary to tighten some of the lines, but at least the all are in place (I hope)!
After that the ships boat will have to be added. I have a Vanguard Models 18 foot Cutter kit for the boat.
Phil
I worked for a couple of days to clean up the loose ends of the belayed lines and attach the rope loops. I left the lines longer than needed so they could be loosened and tightened as necessary to get them running right. The deck was a mess of loose ends looking more like a plate of spaghetti than a ship. After they were all glued in place I cut off the loose ends.
Then I installed the rope loops I made in post #307. I did match the rope size in the loops with the size of the actual line, but I made no special attempt to make the rope coils any special length. In reality some would have more loops than others. Maybe on the next build!
At the bow the lines from the fore sails belayed at pins on the port and starboard bow pin rails. Some of these lines are the sheets for the fore sails, and they must wrap around the stays of the sails farther aft. I haven't "tamed" them yet to hang in a realistic fashion. The sheets of the fore staysail pull the clew of the sail forward, causing it to fold back. I haven't figured out how I will fix this so the sail hangs more naturally.
portbow1.jpg.5b01f9c2f0061b38f8ab1bde0622a5d9.jpgstarboardbow.jpg.3cd30276aba1dabf2d918617ef7fe3a1.jpg
The fife rail at the base of the fore mast has many lines belayed to it. This was the most difficult part of the belaying plan - there were more lines than there were belaying pins. But by putting some of the tackle aloft - such as the yard lift gun tackles - the number of lines to be belayed and the crowding of tackles around the base of the mast was reduced.
foremastfiferail1.jpg.3648e999e7acb5da602fc8b55b34e6e3.jpgforemastfiferail2.jpg.6a4316e381350855f93a413a60cd8bd4.jpg
The area around the fore top is pretty crowded. The lines from high on the mast are routed through fairleads on the fore top crosstrees to eliminate tangles and chafing. Some of these lines had to be untied after belaying, pulled back, and rerouted several times to get all of the lines to hang without tangles and chafing!
stbdfwdpinrail2.jpg.775f59e40656001550c49a969d9df8cb.jpgI was worried about getting the lines belayed and the rope loops hanging correctly on the bulwark pin rails because I had to work "blind" from outboard to get the lines hooked around the bottom of the belaying pins. The gaff sails hanging on the centerline prevented me from having unobstructed access from across the ship.
It did take some patience and repeated attempts but I learned the routine and it wasn't as bad as I had imagined.
The rope loops with two "eyes" to fit over the belaying pin worked nicely. I put a small drop of cyanoacrylate (CA) glue on the part of the loop that would rest against the pin rail. After the loop was in place I put diluted white glue on the top of the pin and the loops that fit over the pin. I think they worked out OK.
I worried most about the four lines that belayed to the main mast fife rail. Access to these belaying points was the most restricted of all because of all the other rigging.
mainmastfiferail.jpg.9c7a8dddb801a358092e4037f2a13bea.jpgmainmastfiferail3.jpg.712b85905640f18bd8f91c4d5ab5b906.jpg
The main problem can be seen in the picture left above. The pivot gun table is much too close to the fife rail to allow the rope loops to hang on the forward side. So the lines had to be belayed from the aft side of the rail. I made a wire hook to help pull the lines under the rail and loop them around the bottom of the belaying pins. The picture right above shows the rope loops hanging behind the rail. Fortunately there were only four lines to rig this way!
portstern.jpg.cda600e1c113097d4684caee02f7c665.jpgThere aren't many lines to belay at the stern. However, the lines there belay to cleats, and not belaying pins. This requires a different arrangement for the small loops that tie around the cleats.
My pre-assembled rope loops weren't optimal for this belaying method.
There are still a few more lines associated with the ship's boat to be belayed here.
The ratlines and the boat are all that remain to be rigged on the model. I will be doing this bit by bit, while I resume my USS Cape build.
I will also need to make a permanent base to display the ship.
I did discover one more broken plastic hook - on the port cat block. Soon that will have a metal hook!
Edited by Dr PR
Phil
Nice work Phil.  You know the old saying, a scale model is never truly finished, you only stop adding details. The working gear (Anchors, foot ropes etc) is a good idea if you want to add that.  I’d also suggest a flag and corresponding halliards too if you wish.
btw, I know you are in Corvallis, did you ever make it over to the OSU ROTC building there?  There is a ship model there.
I have printed the flag, and the flag halliard is already in position. I am trying to figure out how to fold the flag so it hangs "naturally." I need to print it on lighter weight paper.
I never visited the NROTC building at OSU. It used to be a Quonset hut down by the railroad tracks. I don't know where it is today.
Edited by Dr PR
Phil
