My copy of “The Search for Speed Under Sail” by Howard Chapelle finally arrived today.  It has full plans for the Prince de Neufchatel intended for the model maker.
I’ve already learned a lot.
If you’re going to build the Prince de Neufchatel, I strongly recommend it.
Edited by GrandpaPhil
Building:
I assembled 24 gunport lids.  I am going to use a pounce wheel on the lid straps, like I did on the Victory, to simulate rivets.
I think getting the hull done this weekend was a little overly optimistic, lol.
The blizzard wasn’t nearly as bad as the news said it was going to be.  I had us dug out by the early afternoon.  My driveway was dry by evening.
Oh, well there’s always next weekend.
Building:
I’ve been moving.
My shipyard is at my new house.  It is now located in an attached garage.  This means that I can have my heavy woodworking tools with it. 😀
I’ve been installing eyebolts.  I used all 100 that I made, so I need to make more.
 I am going to be using British gun rigging because I put an eyebolt on the deck directly behind the gunports, in British fashion.  Changing this would cause a bunch of problems since this is a card model.
I am going to fully rig my guns.  This will make the guns a little more complicated,  but that’s okay because the whole point of this project is to learn what I can do.
 I also figured out how to make my cleats. I’m just carving them from wood.
 I am going to apply my skills that I’m learning on this build to the Victory.  Then I’ll roll straight into the Triton.
Here’s where I’m at now:
Building:
Now, I would like to finish my gunport lids and install them.
First, I need to use a pounce wheel on the straps.
Next, I need to paint the underside of the lids.
Then I will install them and paint them.
Lastly, I will rig them.
However, in order to rig them, I need to make cleats to tie them off to.  So, I will make them and install them in the near future.
Building:
I painted the undersides of all of the gunport lids, green.  I also touched up the green on bulwarks and the rest of the fittings.
 I finished cutting out the scuppers.  I’ll paint them when I paint the tops of the gunport lids.
Next step is to make the cleats,  then finish painting everything.  I’m going to go ahead and do all dry brushing, weathering and highlighting as part of this painting.
Then I’ll rig the gunport lids.
Building:
Within 1 1/2 month you reached a hullmodel!!! Gratulor - that is great progress.
"Let's add every day 1/2 hour of
modelship building to our
projects' progress..."
Take care!
Christian Heinrich
simple, true and inpretentious motto of ROYAL LOUIS, 1668
Sunking's mediter. flagship most decorated ocean-going ship
Ships on build:
SAINT PHILIPPE, 1693:
1st rang French 90-gun ship - Lavente flagship (based on Heller SR - 1/92 & scratch in 1/64)
TONNANT, 1693:
1st rang French 90-gun ship - sister of SAINT PHILIPPE (mock-up/test-object for S.P. - scratch in 1/64)
Projects in planing:
L'AURORE, 1766:
French Pleasure Corvette (after Ancre plans - scatch in 1/64)
Some Spantaneous Short Term Projects
I made a total of 32 cleats.  24 were for the port lids, the other 8 were extra.  If I need more, then I will make more.
 I installed the 24 cleats for the port lids.  Once everything is dry, I will do the final painting, along with weathering, of the hull.
Then I will rig the gunport lids.
Building:
The Prince de Neufchatel now has a good base coat to work from.
 I’m going to use the faux metallic technique from my war gaming days to simulate metal.
Then I’ll apply a wash in the corners to simulate dirt before using dry brushing to add a bit more depth and create shadows.
As I mentioned before, I tend to treat my ship models like gigantic war gaming miniatures.
Building:
The Prince de Neufchatel now looks grungy and well used.
 I used a couple of different washes and did some dry brushing to add depth and make it look a little more real (in my opinion).
 I also put another coat of sealant on the entire model.
Now, I’m going to rig the gunport lids.
Building:
