Arther, I am waiting on getting some dowels. Also, this weekend is filled with activities so I may not get a whole lot done. However, I do plan to work on the Oarlocks next. I will make a template of metal to use as a drill guide so that I get all the spacings the same. I still don’t know exactly what size or color. Do you have any suggestions?
Paul
Cutty Sark, Scientific Models (no build log)
18th Century Armed Longboat, Model Shipways
Civil War Coffee Wagon and Limber, Model Shipways side project
New Bedford Whaleboat, Model Shipways
Civil War Gatling Gun, Model Shipways side project
The Oarlocks were turned from 1/16”x1/16”x3/4”basswood with a Dremel to 3/64” round.  They were cut at 5/32” height after gluing in place and then painted red to match the cap rails.  I used a block of scrap basswood with two holes drilled in it as a template to position the Oarlocks.BF6CF3E6-1B01-4B11-9C47-EE3F66853281.thumb.jpeg.669cde42b19442fc15e681b162162460.jpeg
Edited by Dr PS - Paul Schulze
Paul
Arthur, I chucked the wood pieces tightly in the Dremel so they would not wobble and then used Squadron course sanding sticks. Usually when they first turned round, they would be 1/16”.  Then I would go to medium grit sticks and finish them to 3/64” which seemed to be the next step in sanding. This size would be 1-1/8 inches in diameter prototype which seemed reasonable. They probably would have used a real hard wood. I think 1/16” would have been okay as well but 3/64” just came out well as a finished product.
BTW, I used a Dremel drill press work station to hold the Dremel.
Paul
3 hours ago, Arthur Wayne said:
Awesome thanks! I'm going to go the same route.
I think the kit oarlocks looked to be too large and, in my opinion, seemed to dominate the scene. I like the looks of the smaller oarlocks painted the same color as the cap rails.  They don’t draw attention to themselves.
Paul
The Boom was made from 1/4" round birch dowel.  A piece of dowel 15" long was cut and marks made at 1.5 inches from each end and 5.5 inches from one end.  The end nearest the 5.5 inch end was turned down to 3/16" at the 1.5 inch mark and the the other end at the 1.5 inch mark was turned down to 1/8 inch.  The former will be the hook end.  The 1.5 inch pieces on both ends were used to clamp the dowel in an electric drill and were cut off after finishing.
Both tapers were started by cutting around the dowel at the 1.5 inch marks and then making slicing cuts towards the cuts moving around the dowel as well as away from the 1.5 inch marks.  In this way a rough taper was cut.  The dowel was then put in the electric drill and brought to final shape with 50 grit sandpaper.  The dowel was clamped in the drill with the chuck nearest the end being worked on so that chances of the dowel breaking were reduced.  Finally, 250 grit sandpaper was used to finish the piece.
Initial slicing cuts to form end of taper were made from the downward cut at the 1.5" mark backward towards the 5.5" mark - -
Rough cut taper and coarse grit sanding done on one end - -
Finished Boom before cutting off chuck holding ends - -
The finished Boom (not shown) is 12 inches long and has a shoulder notch cut at the 1/8" end for the Topping Lift Rope.
As a note in passing, I made the mast from basswood and the boom from birch and I think that the birch is a whole lot easier to work with.
Paul
Finished shaping and painting the Mast, Boom, Gaff and Bowsprit. All of these were shaped using the technique described above. Also, all small parts were blackened using Jax Pewter Black. The Horse was blackened using Birchwood Casey Brass Black.423E60D7-FC05-4A84-98AE-3B19CCE5F813.thumb.jpeg.3a4d5344551ee03040da22f221241fc7.jpeg
Paul
Working on rigging but undecided as what to do with the chainplates and strops. I am looking at various options which also includes those offered in the kit.
Paul
I'm copying as best I can, the way the Medway Longboat is rigged. I'm using the kit chain plates but lopped off the "Y" and I'm making metal strops for the deadeye and will attach via hooks. Hopefully I can post some progress tonight. Also I picked up rigging from Syren Model Ship Company which just arrived, I think the kit supplied tan 1.5 mm rigging is way too big for running rigging, it's quite a bit bigger than the standing rigging which doesn't make sense to me. I think something got crossed up between the prototype and the kit. And the kit model doesn't look like it's using that large of rigging either. I noticed this when Dwight rigged his boat.
Lastly, have you looked at the traveler on the bowsprit? As rigged, it can't travel. LOL While I don't think most folks will know the difference, it bugs me so I'm continuing with my theme of ripping off ideas and designs from Chucks Medway Longboat. Like they say, imitation is the highest form of flattery so.... I may be imitating, I'm certainly not capable of duplicating.
Current Build: Gunboat Philadelphia
Completed Build:  MS 18th Century Armed Longboat
I think Chuck is happy when boats are improved in any way. I have slowed way down as I ponder what I am going to do next.
Paul
Arthur, I have not looked at the bowsprit Traveler at all other to make sure it fit and slid. Can the rigging be made to reflect reality?
With regards to your rigging, what size are you considering? Chuck on his rigging plan uses 0.45 mm and 0.63 mm. I have some of both and some other sizes leftover from my Cutty Sark build. Also, are you using wire or brass for your strops?  I tried using 1/32” brass rod but it is way too hard to shape and also I think it looks too large. I think 20 gauge wire might be the ticket.
Paul
Paul I'm updating my log in just a minute that should answer most of your questions regarding the strops. Also for the bowsprit traveler I copied Chuck's design on his Medway Longboat. After reviewing the instructions again, I see now that the kit arrangement actually will work.
For rigging I have .88mm brown for the shrouds, and some .20mm brown for seizing etc. I also have light brown .63mm, .45mm and .20mm (for seizing etc). The .63mm is for the haliards and .45mm seems to be used anywhere the rigging is going through a block.
I have adopted Arthur’s approach to chainplates and deadeye strops as we are both on an approach of modifying our boats using Chuck’s design.
I tried forming strops from small brass rods but found it difficult to create the small curves. I experimented with various wire and decided copper would work well. I settled on 20 gauge thermostat wire. I used small round nosed jewelry pliers to form the bends and curves.  In order to create a black color, I used Brass Black Metal Finish on the copper parts. Holes were drilled in the deadeyes to receive the eyebolts.  The bands and hooks were glued with thin CA.
I would refer readers to Arthur’s fine detailed description, but basically there are four parts: modified kit chainplates, strop rings or bands, strop eyebolts and strop-chainplate hooks. In the first photograph below, the parts are shown with the strop bands appearing as unbent straight wires.
Finished assemblies  -
Paul
I like it! Will try to use the same method...
     Current:         Emma C. Berry Lobster Smack-Model Shipways-1:32-1866
        Back on the shelf:    USS Essex- MS- "Old Yellow Box" Solid Hull  Wall Hanger (Half Hull)
   Completed:    18th Century Armed Longboat-MS 1/24
                          USN Picket Boat-MS 1864 1/24
                          US Brig Syren by Sea Hoss- Model Shipways-1803
                          18th Century Carronade/Ship Section
                          Mayflower-Pilgrims Pride by Sea Hoss-Model Shipways-1620
                          18th Century Long Boat by Sea Hoss-Model Shipways
                          USS Constitution by Sea Hoss-Revel-Plastic
Thanks all for the comments. I don’t think Arthur and I are in a mad dash to finish rather we want to do the best we can. Actually I find it interesting and fun to make modifications to the kit plans. Both of us have been in a discovery mode and we hope it will give others ideas and help as they work on their builds.
Paul
Before proceeding to the rigging, I decided to redo the canon mounts. I cut them from 3/8” dowel. The stem starboard gun mount was carved to fit between the bow Thwart and G bulkhead/frame, then come up inside and over the cap rail.
0549FEEB-14A9-4DB8-955C-D83034726CF5.thumb.jpeg.44bbfc84e8af34371d0279347f3a890a.jpeg75C1C616-1193-4A11-960B-4DD0A6DAC14C.thumb.jpeg.59c5b07bb025cea1a4e42ec033aa4c5e.jpegDEA1C46D-2A0A-47C2-9C35-FC6E435F8683.thumb.jpeg.cb773c0ede022c2eaee0c02f397a3ca0.jpeg9447CF13-CEC0-4106-9304-B5BA43DB119B.thumb.jpeg.6c8988a433c59eeaaabb9c0d36f2c01e.jpeg
Paul
Do it Arthur.  It took about 2.5 hours at most. If you don’t you’ll wished you had later. Now is the time. Carve the front one before you take anything off and then you can decide from there.
Paul
Looks way more sturdy, I'll do the same, a little more research first though. It's all coming together very well Paul.
Rigging underway- chainplates, deadeyes and shrouds.
I used the Kit supplied black rope to string the deadeyes but went with a smaller non-kit tan shroud rope. I installed the modified chainplates along with the home constructed hooks and stropped deadeyes. The deadeyes were strung off the boat, as shown below, and then moved into place. Next, the backstays were strung. All this went without much difficulty. Finally, I installed the bowsprit brace and post. I decided to install the bowsprit post in the center of the forward thwart as was done for the Medway version. I was concerned about making a rectangular hole in the deck as it was to be located under the thwart. As it turned out it was a piece of cake. I drilled a 1/16” hole through the thwart down into the deck. Next the hole in the thwart was shaped and the post inserted. I pushed a bit on the post to mark its shape and to my surprise it popped through the deck. Viola! Easy peasy!
Paul
Arthur, just a possible solution, use Elmer’s Pro Bond Wood Filer, redrilll the hole and cover the patch with the coiled rope.  I think you will find the wood filler does a pretty good job matching the unpainted wood. B7F651DA-45A0-41F1-A495-32ACDF31FB09.thumb.jpeg.ad36d8db9f5de2b220b3b39cdcf988fd.jpeg
Paul
Just a few shots of the rigging which is almost finished.  No real problems were encountered although I decided to use a thinner tan line than the kit supplied rope for the running rigging. The line I used was 0.7mm. Also, instead of using the kit supplied horse traveler, I opted for a rope loop attached to a block. IMG_3587.thumb.JPG.e919c3bb3b5fe189bbcaaa39eeca9370.JPG
IMG_3585.thumb.JPG.414ac8d00369e2f7f839ec68aa872366.JPGIMG_3586.thumb.JPG.cbb2d9b61869b382cce6b831b2995f01.JPGIMG_3591.thumb.JPG.b445bf720ce2947f7d5a1d73ef1d4743.JPGIMG_3589.thumb.JPG.cd37ecfce709cf8bd00c4fd6b75301a9.JPG
Paul
I’m not done with the rigging yet but I  decided to spend time and get the oars done. I carved and painted 13 oats just in case one didn’t turn out. They all turned out fairly well so I tied two bundles of six as per instructions.  I’m not sure what to do with the thirteenth oar. Maybe I’ll mount it on the display base I want to make.
53E3E609-3B38-4AA2-A809-8A4183B13ABE.thumb.jpeg.180c625002a4083248925585cab8cdec.jpegBA6EF034-8499-44E3-9FBE-B900F7EEB3A7.thumb.jpeg.ea702b4df5f144cb396546ad84cd6846.jpeg
After painting, I sprayed the oars with the matte finish in order to seal them.
Paul
In order to make uniform rope coils, I used this simple construct. The side wood pieces glued on the dowel keep the coils from sliding down. The enlarged hole facilitated tying the rope off.  After coiling, diluted white glue was applied. After the glue was dry, the knot was cut away.
Paul
