Thanks for all the likes and comments.
Gratings:
Started glueing 1mm x 1mm strips of basswood on basswood squares. Once dry I will cut them in 3mm pieces. Then I will turn them on edge and glue the pieces together. Once dry, a frame will be made around it and installed on the decks. (I am using the example on pg 113, 114 of Ship Modeler's Shop Notes 1 from the NRG).
1100516631_364FluitZeehaendeckgratings.thumb.jpg.2d8eca25a2405c5a8e78726552bc727e.jpg
Next, slowly planking the deck. The wood strips that are located where the gratings go are 8mm and 9mm wide and all other strips are 6mm wide. The average length on all of them is 200mm. Planking the decks towards the edge of the inside of the hull wall is another exercise of patience. Unlike most ships the hull wall goes straight up but on the Fluit it bends inward. Lots of trail and error.
161207008_365FluitZeehaenbakdekplanking.thumb.jpg.6e7cdd1c998cd2dee2c72dce7eb90420.jpg
1928861701_366FluitZeehaenupperdeckplanking.thumb.jpg.4d4bbfe3260a4a241541c108433dc166.jpg
226149055_367FluitZeehaenupperdeckplanking.thumb.jpg.0f85c958398925077f436488e29bf769.jpg
1482281969_368FluitZeehaenupperdeckplanking.thumb.jpg.7c8431e3b3dba62fcb9dec0694196dad.jpg
Stern windows have been glued.
Marcus
Current Built: Zeehaen 1639, Dutch Fluit from Dutch explorer Abel J. Tasman
Unofficial motto of the VOC:
"God is good, but trade is better"
Last couple of days have been in the 70's F (20°C) (rare watm weather) so spend time cleaning up the flower beds and edible garden.
Finished the tiller and whipstaff. I will install this when I am ready to put the back deck in. I built it in a way that once installed it actually works.
1926108734_370FluitZeehaenKolderstokroer.thumb.jpg.4996d65c75a4f437590b1148a546be6d.jpg
The nosy cat, Boomer at 18 years.
Gratings have been glued together and need a good sanding. Also made the mast holders (don't know the name) and the railings with the reiling pillars.
Cut out all the different types of bits and started shaping them.
Did some more Sculpey work. These two faces/heads need to be identical, but they are not. Will need to adjust this or leave it as is.
Marcus
7 hours ago, Meriadoc Brandybuck said:
Silicon casting is kind of costly and troublesome but would allow you to duplicate small parts accurately.
I am going to look into this and see what the costs are. Thank you for recommending this to me.
Marcus
Always felt, planking a deck is a bit like mowing a lawn, easy, but very satisfying. Nice work on your decks and for the rest of the build it’s really come to fruition after your earlier struggles.
Edited by Slowhand
More info
Slowhand,
Current build Apostle Felipe - OcCre
Polacca scratch build from Amati plan - on hold
San Martin - OcCre
HMS Resolution - Corel
Half Moon - Corel
Dragon keel boat - Billings
Thanks for all the likes, suggestions and comments.
375 This is wat the Zeehaen presently looks like.
1332099011_376FluitZeehaenralingsMarsblack.thumb.jpg.0a4ef954cb22ffee32a686ac4204bb87.jpg
376. Made the railings. Cut numerous little blocks from square dowels and glued them in place, then added a strip of wood on top and painted it all with Acrylic Mars Black which is matt.
920328767_377FluitZeehaenrailingsorreilings.thumb.jpg.d15f140b3c087c63f00e11cc525b56a5.jpg
377 Railings
2042498743_378FluitZeehaenbowspritedavitsorankerkraan.thumb.jpg.65acf7660a05be3a2a2a951a77ef19cb.jpg
378 Front area which has not been glued on the ship yet. The davits have been glued on an angle in place.
379 Railings on an angle.
304245866_380FluitZeehaengratingsorlattenroosters.thumb.jpg.51c3e7e1168549103c87c14a82ac3008.jpg
380 All gratings were made from walnut and added 4 rings to the large and medium grate an 2 rings to the smaller one.
1954234241_381FluitZeehaenchannelsorrusten.thumb.jpg.179d10b3e0de165373d779e3c8422e2b.jpg
381 Starting to work on the channels.
As the weather gets warmer, I spend less time building and more time in the garden. This year my edible garden will be intense.
Marcus
  • 3 months later...
Today till Saturday on and off rain so no garden work. We get much needed rain whereas the South and the East of the US are floating away as they have too much rain.
Actively working on deck items.
Different types of bits.
Pump
1721865777_385FluitZeehaenwhipstaffkolderstok.thumb.jpg.1c9db093631b097b8f0959466f1242a8.jpg
Whipstaff and how it is installed under the deck.
1730980206_386FluitZeehaenwhipstaffkolderstok.thumb.jpg.5c7128b27ee386526ebc43ed0e36bedf.jpg
Whipstaff
1044584695_387FluitZeehaendoororkoepel.thumb.jpg.dacb02d1a8323ccd59e9e3278ff2d14b.jpg
This door is first cut out of balsa and sanded to specs. On the left a block of cherry with the outline of the door
1554094616_388FluitZeehaendoororkoepel.thumb.jpg.d97b8f090a224d5030396b1ee583a2e9.jpg
Balsa door template on the left, final cherry door on the right.
Location of the door.
Gratings made out of cherry and walnut.
Gratings installed on the decks.
1267246194_392FluitZeehaendecksandwhipstaff.thumb.jpg.511bf3c77091c85b4199644e184b160e.jpg
Door from the captain's quarters.
75835852_393FluitZeehaendifferentdecks.thumb.jpg.37a0d78c7977f525157c0ab0b4ff7fba.jpg
Different layers of decks.
Different installed bits
Deck items in place.
1365006536_395FluitZeehaenFocselandbits.thumb.jpg.843484f5019c561a2941ada49067de9e.jpg
Deck items.
Marcus
  • 2 months later...
Now that there is less work in the garden I am continuing work on the Zeehaen and working on the windlass. After the 1st try, which went in the wood box the second attempt is much better. I use walnut as I have a lot of that and I like working with that wood.
This will be an 8 sided windlass. After I pm'd Ab Hoving on this he msgd., me that the Dutch in the 17th century used either a 6 or an 8 sided windlass. It all depended on how large the ship was and how much power you needed to haul material.
I have a jig to plane 4 sides to a 45 degree angle.
Small vice bolted to a dremel stand clamped to a table.
Mark distance with pencil and use a carving knife and Xacto blade to slowly shave of areas. The outer sides are lower than the inner ones.
Next side.
The end pieces will be cut off.
The square holes are made and still needs to be sanded.
Marcus
After sanding the windlass barrel, added the ratchet teeth for the pawl bit. Painted the holes matt black. Added the supporting posts on each side and installed the complete piece on the upper deck. Added the anchor rope and put the excess into the holes of the hatch cover.
1774132158_406FluitZeehaen1639Windlass7.thumb.jpg.75cc87494da02939f69a2a0965c3a59f.jpg
1809546760_407FluitZeehaen1639Windlass8.thumb.jpg.2c13b30dd402353d428ab325e33dfee9.jpg
I will also add the square poles that fit into the square holes.
For a change of pace looked through the 2 mast and accessories plans en ID'd all the parts that make up the different masts. Using the measurements from the index of the book and the plans and multiplied it by 2 figured out the sizes of it all. My model is twice the size. Plans are 1:75 and model is 1:37.5. It is going to be a rather large model. I knew it was going to be big, but not "that" big. I'm not even going to think about when she is finished and where I am going to put her.
Marcus
  • 5 months later...
Now that my wife has retired I have less time to work on the Fluit. Went on vacation to Bonaire, Netherlands Antilles. Snorkeling, sailing and checking out the island. There is only one shipwreck, the Dutch Brigantine Sirene from 1831.
We are doing a major house cleaning and donating many items to Salvation Army, Goodwill, etc.
I worked on the deadeyes and the necessary iron work that goes with it. The tape with the lines under the wale show the angle of the iron work.
Marcus
2 small boats.
I have tried out several methods as well as what is described in the book of Mondfeld. I saw on the Dutch modelbouwforum.nl a method that I am using. It has been challenging. Lots of trail and errors.  I find it about as difficult as building the hull of the model itself.
My woodworkers club had reps. from Diablo and Freud. The Diablo rep showed us a new type of sanding technology. It is a net made of a ceramic blend and does not clog or tear. It lasts longer that regular sandpaper and made in Switzerland.
Personally, it works great, better than anything I have used before. The 220 grit I use feels like the 100 grit regular sandpaper.
Marcus
  • 2 months later...
Between the little vacations, the flower and the edible garden I find time to work on the small boats. I have the most difficulties with the smaller boat. The shape is a tough one. I decided to build both boats with 2 layers of planking as I made many mistakes planking the small one. (I don't know how people work in scales of 200 and up, mind boggling).
1600083817_444FluitZeehaen2smallboats.thumb.jpg.80060677ebc6a8c1a21d01fe16e9d23d.jpg1498830822_443FluitZeehaen2smallboats.thumb.jpg.880b8c7752f4fef7f9d3a18831d58ac6.jpg
Both have the first layer of planking completed and have started on the second layer which should hide the mistakes I made on the smaller boat.
It is good that the smaller boat goes into the bigger boat and when I add 2 masts, 4 sails and the rigging you don't see much of the smaller boat. I am not sure if I am going to add the mast, sails and rigging to the boats. This may look like someone left a pile of junk on the deck and forgot to clean up.
What are the suggestions?
Marcus
Out of curiosity, how long are these boats?  Also what is the thickness of the planks you're using?  It strikes me that the planks must be tapered and possibly spiled quite a bit to cover the surface.  Of course that's much more easily done on the second layer as you're doing.
I think some neatly stowed masts and gear would look good in the boats, though I imagine in actual sailing conditions the crew might cover the boats with a canvas tarp.
-Meriadoc
@Meriadoc Brandybuck
Large boat 18cm long x 6cm wide x 2cm high. Small boat 15cm long x 4.5cm wide x 2cm high.
Planking on small boat 3mm wide x 1mm thick. On large boat 4mm wide x 1mm thick.
The spilling is difficult on these boats. But I am trying that.
Covering the boats with canvas is an option but then everything is hidden and wasn't really done around that time.
Marcus
  • 2 years later...
In November of 2024 we went 4 days to Taiwan and 10 days to Vietnam. In Taiwan I went to a wood museum and a wood craft fair. I purchased some interesting planners (pictures will follow). I will attach the facebook pages from the woodcrafters I visited. All the temples we visited had very intricate carvings. Taiwan is very clean (not a piece of paper on the roads), and the people are very friendly and that goes for Vietnam as well.
In March of this year we are going to Capetown, South Africa for a little less than 3 weeks.  South Africa has been on my bucket list for decades.
That little crescent shaped piece of the Southern tip of South Africa called, Cape Flora Kingdom is one of the 6 unique plant kingdoms in the world.
About 70% of its flora is found nowhere else on the planet. As a retired Horticulturist/Plant & Soil Scientist I just have to see this before I die and the Botanical Garden, Kirstenbosch is the place to see some of these species.
Also interested in the Dutch history and the maritime museum.
Add some updates which were done last year.
Added sails, oars, the sticks that belong to the windlass in one of the boats.
Tied it all together and will be placed on the Fluit once the masts, sails and rigging is completed. The little boats were difficult to make and the next ones that go on the Heemskerck (War Yacht and sister ship of the Zeehaen) will be made differently.
Marcus
454FluitZeehaenBoatsail1.thumb.jpg.055fb3d5b4933dd44153b22349a957b4.jpg455FluitZeehaenBoatsail2.thumb.jpg.1551e57c588f208bfa3572413f19995a.jpg458FluitZeehaen2smallboats.thumb.jpg.d6f8629fe69dba8373ab03ed8dd5fc00.jpg459FluitZeehaen2smallboats.thumb.jpg.dd24164882b872055a46bc353c4ad504.jpg460FluitZeehaen2smallboats.thumb.jpg.ae96b27f3eeb9fafce7c7b8b0db9a528.jpg461FluitZeehaen2smallboats.thumb.jpg.912fcb6c3729a1a194864b7769ba5113.jpg464FluitZeehaenBoats07.thumb.jpg.a53330f875cb24af42076868793a60ea.jpg465FluitZeehaenBoats08.thumb.jpg.47b7a739c51c407bfc04ade906ce7e0b.jpg466FluitZeehaenBoats09.thumb.jpg.784b1f2201089b4aad6d2886e5adb3c2.jpg
In the summer of 2024, I started working on the blocks. Using TurboCAD, I took the block plan from the book and used the measurements for the scale I am using.
Copied both the front and side of the blocks and filled the page with copies of the individual blocks and are ready for printing.
Marcus
Cut square and rectangular dowels from walnut on the bandsaw and glued the front of the block on one side and the side of the block on the other side.
They are now ready for drilling using a 1mm diameter bit.
Marcus
While in Taiwan I went to Wood Craft Fair and purchased some interesting planers.
Facebook links:
lukangtools - Chisels, planers, etc. - Taiwan
https://www.facebook.com/lukangtools
sincerecraft - Taiwan
Check out their facebook page and some of their videos.
https://www.facebook.com/sincerecraft.tw
  • 4 months later...
I have got some bad news.
I have been diagnosed with ALS (Amyotrophic lateral sclerosis) symptoms in April of 2025. This disease is fatal & there is no cure. Some doctors say that you live 2 to 5 years but can also be 7 to 10 years. It all depends on good nutrition and continue to move around as much as possible. ALS is also known as ‘Lou Gehrig’s Disease’ My wife and I think it slowly started in 2023 and then in 2024 I could not open a plastic bottle and I fell here there, I was losing my balance.
I don’t have the “ALS gene”, but I do have all the symptoms. There are many variants and if you don’t have the gene it is difficult to pin point which one it is.
In most cases, ALS patients do not typically experience significantly impaired sensory neural functioning, intellectual reasoning, vision or hearing and eye and bladder muscles.
Presently taking some meds that will slow down degeneration of the motor neurons by 25%. One of the positive signs of this disease is that there is NEVER any pain.
I still have fine motor skills in both of my hands but my right arm is now stronger than my left arm. I know I will not be able to finish my present built, the fluit, the Zeehaen. I have decided to keep on building and will be mostly to exercise my joints in my hands. Once I lose all my muscles in my hands and arms and the ship is not finished, I will give it a “Viking Funeral.”
If you have any questions, just PM me.
Regards,
Marcus
That's a tough diagnosis, Marcus, and I'm with Patrick on wishing you strength for the challenges to come. But I think I would not be alone in hoping that you would seriously reconsider the 'Viking funeral' plan for your model. Certainly someone in your family would appreciate having it, even if it is not completed? Might even be the kind of project someone would be willing to finish up for your family.
