I'm starting this log as Chuck asked us to in his introduction to the project, but it will have to be a place holder for a while as I finish other builds.
Having said that,  I'm looking forward to testing my skills on scratch building as much of this project as possible, with the probable exception of the boxwood carvings and figurehead which look too good to resist! The first step will be to persuade dockyard officialdom (she who holds the pursestrings) that I need a scroll saw. I used a jeweller's piercing saw to produce the frames for a 1:48 pinnace for my current Royal Caroline build but that's not an experience I want to repeat on a larger model.
Good luck to all the folk who will be beating me out of the starting blocks - I'll watch your logs with interest.
Derek
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
As I said in my first post I won't be starting serious work for some time as I have other projects I need to finish first.
However I've done some initial prep work which I shall describe below. I mentioned using a jeweller's piercing saw on the pinnace for my Royal Caroline build - here's the result, built in boxwood:
Although I am happy with the end product I can't imagine cutting out all the Winchelsea components by hand, so I've ordered a Proxxon scroll saw which should arrive from Germany in the next day or so. I should add that I got the idea for the pinnace from Blue Ensign's Pegasus build, where he used Model Shipways' pinnace kit as a starting point, reducing the scale from 1:24. Like Blue Ensign, I want to complete the Model Shipways kit in its own right so that's next on the stocks:
An enjoyable and hopefully relatively short interlude. At the same time I need to complete the Royal Caroline, shown here in my homemade dust cabinet and just awaiting final tarting up:
I started the Caroline before I discovered MSW so much of it is cruder than I would now be happy with, but in time to scratch build some of the later fittings and the rigging. Apart from the pinnace, you might notice Chuck's lanterns. I also made all my own rigging using Syren's rope rocket.
Lastly, I have to finish off a Victory cross section I got as a present half way through the Caroline build:
Again, much cruder than I'd now aspire to but at least I scrapped the out-of-scale kit ladders.
Back to the Winchelsea. I've decided that I can at least get the plans and other materials together so that I can get off to a good start when the stocks are clear. I started by getting the larger, 40" X 30" plans printed by an online firm that specialises in architectural drawings as I described in a post elsewhere: UK Plan printing service.
Next, I enlisted my wife's help in preparing the templates need to cut components out of sheet material. She has a machine she uses for her card making and other hobbies, called a Brother Scan n' Cut. As the name suggests, you can scan drawings in, scale and edit them, and the machine will cut out the resulting shapes from paper or card. You can replace the cutter with a pen and it will draw the pattern rather than cut it. Alternatively, .pdf files such as Chuck's for the Wichelsea can be sent to the machine which eliminates the scanning stage and thus reduces the scope for error creeping in. I've used the machine several times when I've needed paper templates for small, intricate components and it's worked a treat. This time, my wife kindly offered her help in cutting out all the Winchelsea's components - here's one example:
Scan.thumb.jpg.4123b521cd36bb44a7923fcd6918ea8d.jpgCut.thumb.jpg.2922624d1249165fcd4b29a02305656e.jpg
Of course, it would be possible to stick the whole sheet of paper to the wood rather than cutting out the template, but I like the latter method for a number of reasons - you can shuffle individual templates around on the wood to minimise wastage, you use less glue, and I find it easier to cut to the paper line (where I can see the wood) rather than cutting through solid paper. Maybe that's just me - I'm sure others would be equally happy with the other method.
Next step will be sourcing suitable plywood and timber. On plywood, I was relieved when Chuck confirmed that using metric sheets (i.e. 6mm rather than 1/4") is not a big deal - I'll just need to make sure the bulkheads are a snug fit in the keel.
As for timber, I'm sorely tempted to go for Alaskan Yellow Cedar as used by Chuck. I've found a source in the UK, and I'll report back when I've received a sample. Meanwhile I'm enjoying following other folks' progress on the project.
Derek
Cheers, Derek
And let us know where you have found the cedar in the UK please, if it works out
Thanks
Paul
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
The Proxxon scroll saw has arrived, and after setting it up and playing with it I've discovered it requires more skill than I'd realised! In between practising and watching assorted "Scroll sawing for Beginners" videos on Youtube I've decided not to wait until I've finished my other projects before starting on the Winchelsea. I figured if I start slowly, cutting out one or two frames per week, I'll build up my skills over time rather than trying to cut out all the components in one go. I've ordered a couple of spare sheets of plywood so if my early attempts are rubbish I can replace them.
I've ordered birch ply for the false keel and light ply for the frames, as suggested by folk on the project - based on the rigidity and strength of the former and the easier sanding of the latter. As for timber, I've had to re-think using Alaskan yellow cedar. On further investigation (ie googling) it seems that most if not all sources in the UK are either boatyards or firms providing high-end cladding for buildings. In both cases the quantities and/or shipping charges are way too high for modelling. For example, the minimum delivery charge of £75 😲 quoted by one supplier would be OK if you were buying enough timber to build a full size boat, but not a three foot model! I was going to order a small sample piece from another boatyard until they tried to charge £21 for delivering a £9 plank. I suspect if I lived closer to a boatyard I might be able to explain my needs in person and negotiate something more sensible but I don't, so I've decided to fall back on boxwood.
Exotic Hardwoods do a variety of sizes of sawn castello boxwood boards which I've found to be good quality in the past. For example I got all the masts and yards for my Caroline build out of a 13mm board and was very happy with the quality. Not quite as fine as English boxwood but a good substitute. I've ordered three boards in different sizes to get me started. Original Marquetry also do castello boxwood in a few thinner sizes. For example, I used their 1.5mm sawn veneer to make the frames for the pinnace I mentioned in an earlier post.
I'm off to play practice with the scroll saw again!
Derek
Cheers, Derek
The plywood arrived today. Although it was well packaged, the light ply was warped. As a first step I've put it under a heavy MDF sheet with the weights off my dive belt on top. If that doesn't work I'll have to try for some advice from the forum:
Fingers crossed☹️!   The birch ply looks OK, so I'm going to have a go at cutting out the false keel with the new scroll saw.
Derek
Cheers, Derek
Couple of weeks off visiting family, so now I've finally taken the plunge and started making sawdust. My wife's help in cutting out the templates with her scan 'n cut machine certainly makes it easy to juggle the shapes around and minimise wastage. The pritt stick worked well in sticking the paper (I hadn't used it yet in this photo!).
Rough cuts on the bandsaw followed by trickier work on the scroll saw:
I haven't sanded the edges yet, and I won't finish the slots until I'm ready to fit the frames, but I'm quite pleased with this first attempt. It's given me the incentive to press on slowly with this preliminary work whilst I finish other projects.
Derek
Cheers, Derek
Nice....remember to cut outside your lines and then sand up to them later.  Especially at the bottoms and tops of those bulkheads.  It does make a big difference.  :D
