Just happened on your build Steve.  A very interesting subject to model and you are doing a grand job with her.
cheers
Pat
I have made up the drip caps for the chimney stack bases.  I made them out of a 'beware of the dog" plastic sign.  The plastic is thin and takes rivet impressions and paint well.  It also bonds well with the solvent.  I am sure there is a way to design them with geometry.  I just used a hit and miss method for the diameter for the center cut out and the outside edge.
Finished (at least in my mind),  I painted the stacks and added two vent pipes aft of the stacks.  I think these would have been for the boiler safety valves or blow down. I think I will be weathering it a bit to look like it has been working.  This might also bring some of the detail into sharper contrast.
I'm looking at your latest  I was thinking it looks like the engine will fire up and work.  The devil is in the details and you nailed it.
