Still have to tackle the pendants around the masts before the real fun begins. This is my first go at seizing threads together.
Really need 4-5 helping hands getting this done... I used 2mm styrene tubes sliced off with a scalpel and wound black thread around it, then seized using 0.18mm black fishing wire.
Seized and placed over the foremast starboard before port side. A little glue and an assortment of weights to shape the thread.
My main mast snapped recently (could be the kids) and I had to glue it back and possibly adjust again when the shrouds and stays are rigged ... Could someone please confirm the mast-deck angle from a side view (90 deg?)
Cheers
Edited by rkwz
Being a newbie, I forgot to stiffen the thread at the point where the burton pendants loop over the mast. The result (see main mast) looked totally unnatural unless it was a very windy day 😁.
Fixed this problem with a second run on the fore mast as you can see. Looking a little better but still the threads are a little curved.
A touch of paint on the pendants to pass them off as wood.
I'm a little paranoid about access before the shrouds go on. Next I'll get some blocks attached to the eyebolts around each mast.
Edited by rkwz
So far, I've found the method that works for me is to mark with paint the position for the deadeyes during a dry fitting run (after seizing the loop that goes over the mast), I figured I would have to "tar" the shrouds later anyway 😁
Different coloured paint to differentiate the shroud positions.
Example of a finished shroud. Seizing is becoming faster and easier now that I've gotten the hang of it. Fishing line may not be realistic but it works at this scale.
A little dry fitting again using copper wire to hold it in place albeit loosely.
Now before I get too excited and get ahead of myself as has occurred many many times prior, I decided to stop here with the first 4 shrouds aft.
After dry brushing the deadeyes and once they are dry, I will rig these in place with beige thread just to see if I'm on the right track.
I am a little worried the foremast is beginning to tilt back at a slight angle (I had broken this too when I dropped the ship a few days ago) so I'll need to tread carefully when tensioning the lanyards.
Edit:
Then I realised the sequence of shrouds over the mast head is the other way round (fore to aft)... 🤦‍♂️
Edited by rkwz
Just a little update (haven't given up yet!). Still battling on with shrouds.
Once I get the fore and main stays in place, I should then be able to tension the lanyards and adjust the foremast which is slightly leaning aft.
Just counted my deadeyes and realised I only have 2 left over for the bowsprit rigging. Looks like another top up purchase is in order...
Had a busy night fitting the bobstays. The foremost one in particular took longer than the rest.
I noticed there are some variations to blocks used for the bobstays. Gil Middleton's Victory Bible uses deadeyes but since I'm all out of deadeyes, I decided to make my own.
Heart blocks were made by slicing off O tubes of styrene (2.5mm), gently shaped using pliers, glued with CA to keep it's shape, then painted to simulate wood.
Edited by rkwz
How tall, long and wide?  The complete model.  I have the black pearl 1/72 (50cm X 47Cm X 9Cm) and I want the HMS Victory airfix to make a Custum to the HMS ENDEAVOR of pirates of the Caribbean.  greetings from Mexico
Edited by Arturocaretta
Ortography
About 60cm L x 50cm H (don't know the width yet as I haven't placed the spars yet). The hull is 39cm long.
Wonder if the Victory with it's 104 guns would be an unfair match against the Black Pearl? 🤔 Then again ... The undead!
Edited by rkwz
31 minutes ago, rkwz said:
Alrededor de 60cm L x 50cm H (no sé el ancho todavía, ya que no he colocado los largueros todavía). El casco mide 39 cm de largo.
¿Me pregunto si la Victoria con sus 104 cañones sería un partido injusto contra la Perla Negra? 🤔 Entonces otra vez ... ¡Los muertos vivientes!
I just ordered the HMS victory airfix and I hope it is a good scale (in real life the pearl and endeavor are 50 M and 60 M long respectively) your work will inspire my project a lot, just  I don't think I get that much for the custum, it's hard to get them to send parts to Mexico.  It will be a great scene to put the HMS Victory vs The Pearl !!  This is my first model and it lacks a rival!
Made some progress with the main and fore stays and their respective preventer stays.IMG_20200306_142517.thumb.jpg.86be42c350dcc08277dddef8406b1c40.jpg
Seizing the rope around the main mast
My stay mouse cheat (slightly thinner thread wound several times around and shaped with a drop of CA)
Now to research how to tie the snaking line across the stays... Advice please for a newbie ! 🙏
8 hours ago, rkwz said:
Hizo algunos progresos con las estancias principales y anteriores y sus respectivas estancias preventivas.IMG_20200306_142517.thumb.jpg.86be42c350dcc08277dddef8406b1c40.jpg
Apoderarse de la cuerda alrededor del mástil principal
Mi truco del ratón de la estancia (ligeramente más delgado hilo enrollado varias veces alrededor y en forma con una gota de CA)
Ahora para investigar cómo atar la línea de snaking a través de las estancias... Consejos por favor para un novato ! 🙏
Wow !! It's looking amazing!  Now what I see seems to be that it is larger than the pearl (1/72) I will certainly inspire my custom of the HMS Endeavor, it is a pity that DHL delayed the delivery of my model for 3 more days.  Do you have any preview of the candles?
Did you mean the stern lanterns? Here's a pic...no work done on them yet as I just can foresee these flimsy things snapping off throughout the rigging process! I'll leave that to the last along with the rest of the cannons and gun port covers.
On another note, I've worked out a way to snake the stays using bits of fishing line and CA. Tried threading with a needle, tying clove hitches, simple overhead knots, but simply couldn't seem to get a result I was happy with so I resorted to this cheat.
Edited by rkwz
I was referring to these parts (indicated in the photo) the rig is a huge problem, I used kola loka glue.  if the model has pulleys use them in your favor so that the rig is tense
Oh I see. I'll be taking a risk and will be using the kit supplied masts as I have little to no experience working with wood.
I am doing my best to follow Hackney's rigging guide with the system of blocks. It has given me an appreciation of the beauty of how these period ships were constructed...every step in the rigging process seems to have an important function in keeping the ship together.
Meanwhile I will be practicing tying clove hitches and pondering how I can get the ratlines done without making a mess of it.
Great work,
Succes on the ratlines.  On this small scale,  you are a brave man.
But, this will work out well 👍
On 3/12/2020 at 4:37 AM, rkwz said:
Comienza el trabajo en las líneas de rata, después de haber completado las estancias más bajas del mástil y el preventor se queda.
Manténgase seguro y saludable a todos...
On 3/12/2020 at 3:27 PM, Wallace said:
Tú también amigo. Por cierto, estás haciendo un buen trabajo.
Mi modelo HMS victoria al HMS Endeavour
Whilst waiting for my COVID-19 test results, I keep myself occupied by tying the ratlines in...
Also I finally received my copy of Longridge's book from Booktopia after my first order went missing in the post 😠.
What a gem of a book. So much detail and analysis of the Victory!
:cheers:
Well, it took a while but after tying over 1900 clove hitches, I feel it was worth the effort after all.
All the while knowing this is the easy bit as the upper mast ratlines will come later...
And incidentally my test results came back negative 😪
On this small scale.
You are a brave man.
What a pleasure it is to see you putting so much effort into this build, I continue to be impressed with your work.
I'm sure you are already putting ideas together for your next build. Many here would encourage you to 'progress' to something wooden. You're fast approaching the rigging stage having already done most of the work on the shrouds and ratlines. It's this area where the 'faff' aspect will come to your attention and try your patience. Looking forward to that.
For what it's worth, may I suggest you give the Airfix 'Bounty' some consideration. Being 1:87 it's twice the scale of the 'Vic'. Like the AOTS book of the 'Vic', the Bounty title emphasises the accuracy of the Airfix kit.
You will have the option of the Bounty (just a few guns to mount), or a simple kit bash and build the previous merchantman incarnation of the ship, 'Bethia' (no guns at all!).
Both versions have full ship rig at a scale where each and every detail could be accomplished. No doubt you would learn all there is to rigging any ship model. That would be the value of that build.
And of course it wouldn't break the bank.
Looking forward to more of your posts.
Thank you everyone for your words of encouragement :)
Thanks, Shipman... There is still so much I don't know and I look forward to each stage/challenge and gain more experience through this build. I realise I have saved a significant amount of time and frustration with a plastic hull but do plan to start a wooden build albeit a less ambitious one after I complete the Victory.
Thanks for the tip for the Airfix bounty. Will definitely consider that on my to do list.
IMG_20200328_121541.thumb.jpg.c761f3eebca7b512bb2431a3a8dddd7b.jpgIMG_20200328_122847.thumb.jpg.9b294c3c21dd72f25b4dbafd587e34a5.jpg
While waiting for my order for more blocks (ran out of triples for the jeer blocks), I've began preparations for the topmast stays.
