C&L Barge No. 1 by Canute - Sheepscot Scale Products - 1/87 scale
Here's another work barge, although this one had multiple uses. It was moved by tug and could be used as a lifting crane or pile driver. These usually weren't railroad owned; several contractors would have a number of these barges. I picked this up a number of years ago, but it was buried under whatever other accumulated stuff I'd collected over the years.  I put the instructions into a binder to prevent any further losses. I did have to gather up a good collection of stripwood, since some of the kit stuff went over the hills and far away.
The kit brass held up pretty well, seems to have minimal corrosion. The kit dates from 1986.
The barge hull is a plywood former, to which I will be applying HO scale 2 x 6 inch planks. The following is is the rest of what comes in the box.
147338326_castmetalparts.thumb.jpg.b8b3b833fa681ed41b360646e189d074.jpg1841921952_Coaltirestankformers.thumb.jpg.6662677ebdacb84fb758d4f0522a6a89.jpg605233755_Brassandplastictubing.thumb.jpg.8d27579cc3c3546d7332ca2365442340.jpg
Ken
Started: MS Bounty Longboat,
Link to comment
Share on other sites
Started planking the hull sides, but ran into a bit of a quandary. I suspect the hull former, a piece of plywood, is pretty dried out due to it's age. I think my glue seeped into the wood too fast. I'm using an Aleene's extra tacky glue; this glue feels like working with the old Duco cement, without the odor. I applied the Aleene's glue, but by the time I could lay a strip down, the glue seemed dry. No stickiness. I had one suggestion for sealing the wood with glue and letting it dry. Expect it should work; it's what I do if gluing metals to wood with CA.
My plan is to glue the bottom planking around the hull and paint it anti fouling red. The rest of the planking will just be stained brownish black.
Ken
Link to comment
Looks like a decent set of parts to work with. Sealing up the wood should work. I'm looking forward to where you go with this... a lot of different possibilities for cargo!
Bob Cardone
On the bench:
Gunboat Philadelphia Model Shipways 1:24
CSS Palmetto State Verlinden 1:200
Next up:
USN Picket Boat #1 Model Shipways 1:24
Completed:
F-4 Phantom Hasegawa 1:48
Smilodon Fatalis Unknown manufacturer and scale
Panzer IV 1:32 Unimax/ Forces of Valor prebuilt with mods, diorama
Link to comment
Thanks, Bob. The deck will get cluttered with hose and some pilings, along with the fixed mast, lifting boom and pile driving mechanism.
The deck scow I'm also working on will end up with some kind of cargo, maybe some cement canisters and building materials. There are a number of items I can use.
Ken
Link to comment
Sorry I'm late to this Ken - looks like an interesting build  give me five while I pinch some of Marks popcorn.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Where has this build been hiding over the last few days? I am beginning to think that the  "All unread since last visit" button is not working right for me.:( Hope it keeps popping up so I can follow Ken. Looks like a potentially interesting build.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
It's with being in  the rafters, you can miss stuff😏
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Thanks, guys. It's pretty new. More intricate than the deck scow I also have in work. That's a laser cut kit, with no rigging; this one is a box of sticks. Only stuff pre-cut is the PE and this kit's brass is thicker than the PE we work with nowadays. It'll be fun.
Ken
Link to comment
So it's almost a scratch build, Ken?
Link to comment
Well, it's pretty darn close, Mark. Maybe more like a kit-bash. The kit supplies sticks, tubing, wire, cordage and a handful of lead/pewter castings. Somewhere a lot of kit wood walked and I ended up acquiring a lot of replacement packs.
Been pulling dimensions from the plans for the deck house. I'm gonna replace the provided wood sticks for the house siding with some Evergreen Novelty siding. Sometimes called ship-lap siding. The marine equipment of many of the NY harbor railroads used the stuff on their craft. Puzzling over the windows and doors. May replace the sticks with some plastic castings that actually look like windows and doors.
In this scale , I'm wondering if cutting the 2" x 6" planking into 24' lengths would be worth the effort; too small to see the difference
Ken
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
