I ordered the kit from Model Expo, got a great deal with the Father's Day sale.  Unfortunately she's back-ordered for a few weeks, but I hope to be unpacking soon!
I'll be using the Syren Model Company blocks and rope, so it should be a good upgrade from my last build where I used cheap square blocks, but that'll be a ways down the road.
Edited by Jamie Coleman
“The sea, once it casts its spell, holds one in its net of wonder forever.”
― Jacques Yves Cousteau
Work in Progress: US Brig Syren
Completed Works: Thermopylae
2 hours ago, Louie da fly said:
Mind if I pull up a chair? Looking forward to watching this one after seeing your Thermopylae build.
Glad to have you aboard, hopefully the back orders get cleared up and Model Shipways starts shipping kits.
2 hours ago, Chuck said:
Welcome to the Syren club....Glad you started a build log. Have fun with the project.
Chuck
Your fantastic instructions are the reason I chose the Syren, hoping to live up to the quality of the design.
The kit has arrived!  I started with an inventory, and everything looks to have been included.
I decided to work on the ship’s boat as well as the main, so I’d have a side project while glue was drying, etc.
I started with glueing up the lifts, then started filing and sanding the overall shape.  I found a rasp to work very well for the outside shaping, followed by 80 grit.  More to come on the boat.
In the meantime, dry fit of the bulkheads just to make sure there were no glaring errors, looking fine so far.  Nice flat/straight bulkhead former.
Followed by soaking the rabbet strip, and letting it dry wrapped around the bulkhead former, then glueing it in place and “clamping” it up with some rubber bands.
I did order a hobby zone building slip, and it’s on back-order, so I’ll be slow walking the build just a bit, I’d like to have it before I start glueing on the bulkheads.
Love your avatar pic!😆
Pulling up a chair!  Great to see another Syren build!  Will look forward to your journey.  This forum provides a lot of great resources from others building the same kit...so you are most definitely in good (and plentiful) company.
“Here.  Hold my beer..." --- Common phrase uttered by Lord Admiral Nelson at any pub. 🍺
Hi Jamie - Nice start.  I'll be following along as I recently started Syren as well.  Good idea to work on the ship's boat a project within a project.  I have been scratching my head a bit as I glue and clamp something and then have to wait 24 hours.  Very different from the plastic models I'm used to where you can keep going.
A little further along, tapered the bulkhead former from the bearding line down to the rabbet strip (mostly chisel work, followed by a light sanding), I added the stem knee, and keel.  Keel was ever so slight thicker than the knee, so I took a few shavings off with a block plane.
After that all had a chance to dry, I sanded the stem down to accept the figurehead.  A bit fussy of a job, but just took it slow until it just fit.
I decided to copy a few others and precut the mast holes in the keel, and then I glued a few spacer shims on, so when I glue in the blocks to support the bulkheads, it’ll leave a square for the mast to rest in.  I left the spacers extra long to give a little extra support.  This seemed like a relatively easy way to get the rake of the masts right, just put the framer right on the plans.
I also worked on smoothing up the ship’s boat and attached the keel and stem, applied some wood filler and sanded again.  Felt it needed another layer of filler in some spots, so at least one more sanding before I apply some primer.
22 hours ago, Louie da fly said:
Good to see it's arrived and you've got started, Jamie.
You certainly don't mess around, do you? Very good progress in a short time.
Works been a little quiet, and I’m working from home, so I’ll make a little progress here and there during coffee breaks.  Works out nice for letting glue cure between steps.
Outstanding!  Off to a fine start, Jamie.
I've been focusing on the ship's boat, and have completed it.
I used some artist's tape as a guide to shaping the hull, to give it a light dip midships.
Then laid in the framework, this was some fussy work, no real good way to clamp, so each one was just held in place until it dried enough to let go.  The the floor boards and a coat of paint.
Gratings, thwarts, cap rail, mast bracketry, splash rail and bowsprit support added next, followed by the winch (carved from a piece of square stock, not perfect, but definitely gives the impression of an octagon).
Lastly, the rudder (which is stored inside the boat until needed), oar locks, oars, a few coats of black and white on the hull.  So much more detail than the die cast boat from my last project, I'm really happy with the way this turned out.
It's wonderful following the process of transforming the boat from a simple shape to a beautiful, complex whole, complete with all the accessories. Lovely work, Jamie!
I’ve been working on deck items recently, and have a lot of them finished.  Hatches, steering wheel, binnacle, capstan, galley vent, and a good start on the pump.
One thing I did different than the instructions, I was having a bear of a time hollowing out a dowel for the pump “buckets?”, so I used a piece of brass tubing instead, and that worked wonderfully.
Need to finish the pump and hang the ship’s bell, then next up are the fife rail and other bitts.  Just taking my time on deck fittings, hobbyzone is supposed to be back to work in August, so my building slip should be here soon, if not I’ll next move onto the cannons and carronades.
Looking nice!  Love those detailed pieces!
  • 2 months later...
Well, it’s been a bit of a hiatus, my dishwasher sprung an undetected leak, and we’ve been dealing with reflooring the kitchen, and works picked up a bit as well.  But, I have finally laid in the bulkheads.  I did a bit of fairing just getting close to lines on the bulkheads, Fine tuning to come after it’s all blocked up and solid.  I found I could just fit the base of my small double square in between and use it as a clamping jig to keep the bulkheads square to the keel.
I also started to cut and fit blocking between the bulkheads.
A bit more done, framed out the cannon and sweep ports, still need to do a bit more work fairing them back to the bulkheads.
I used a piece of 1/2” plywood (which is really 15/32”) as a spacer to maker sure the cannon ports were sized right, worked out well to keep things parallel too.
Also planked the lower level.  I found if I used stain, but wiped it off immediately I got a nice color.  Ran a pencil line on one side of each joint, overall I think it’s a good look.  Not sure if it’ll matter in the end, but I also painted the below deck area black.
A bit more (lot more) sanding in my future, but moving onto the rear framing after.
Looks great, Jamie!  Coming along very nicely. The sanding never seems to stop, does it?  😃
2 hours ago, Overworked724 said:
Interesting building board!  Did you make it or was it manufactured?
I cheated and bought one.
https://www.hobbyzone.pl/en/boat-building-tools/105-small-building-slip.html
I got it through hobbyworld.  Stock situation wasn’t very good due to covid, and they were pretty poor at responding to emails, but in the end, one showed up, and it’s working pretty well.
So much sanding...
I've got to admit, I’ve been following along on your build and the sandpaper on a paint stir sized piece of wood has been the best tool for so much of the work.
I've been doing quite a bit of work without getting a chance to post updates, the kids have been monopolizing the computer for school (and world of warcraft :-)
Anyway, I've done quite a bit, starting with some pictures of the stern framing and the framing for the deck accessway (opted to work on this while the stern was drying, just to keep making progress).
Framed the port openings and installed and faired the stern filler pieces next.
And I installed the bow filler pieces as well, I'd put off doing this so I could get them faired a bit more true to the final shape of the exterior after I'd finished framing all the gun ports and truing them up.  You can see my interior side of the framing was left large, I'll clean all that up once the exterior is framed and gives it all a bit more structure.
I made a jig to pre-shape the planking, and it'll hold about 8 planks at once, so I can soak and let them dry overnight.  It ended up working very well, but as these were just plain steel nails, it did end up leaving a bit of a rust streak I'll have to sand out later.
I painted the ports and then laid down the first plank after laying it out with some battens and pins.  Continued to plank from the wales up.  Clothes pins were the clamp of choice here, but I did end up using rubber bands for the final bow planks, as the were high enough the rabbet wasn't holding it inboard.
Your Syren is looking good.  I like the red you are using.  Is this artist acrylic paint?
Ryland
               - Nautical Research Guild
Thank you.  The paint’s from model expo, it was part of the acrylic kit they sell for the Syren, there was black, red, white and a primer.  The red is their MS4835 Bright Red Trim.  I think it’s a nice deep red color without being too bright.
