On 8/8/2020 at 8:20 PM, kljang said:
Hi ASAT,
No, you didn’t miss it.  I didn’t list any shipping costs as it depends on how it was shipped.  Prior to the pandemic, my kit and other items I ordered from China came via China Post to Canada.  Now, Chinese prodecers are using courier services such as DHL to avoid sitting in the post office (in my case Canada Post) until cleared by customs.  The courier firms have their own brokerage which is faster but comes at a price.
I suggest you email Tom and ask.  The kits can be provided in parts so you can stretch out the costs.  This is why each box is a self contained unit of parts, plans, etc.  You can start with box 1, build away until you are ready for the next part.
cheers,
Kerry
Hi Kerry
Excelent review !!  Other excelent news is that we may order by box.  You have suggested to contact Tom.  Do you have his contact ?
A doubt: this kit was based on which set of plans, do you know ?
Alex
________________________
Alex
"By endurance we conquer"
Hi Alex,
You can contact Tom via the CAF Models website or with this email:  450449987@qq.com
The kit was based on plans from the National Maritime Museum which provided the lines.  All of the framing and what not was created by Tom using practices of model shipwrights of the time.  A Polish card model company also created a kit of Enterprize and published plans of the ship.  This was used as a reference for decoration etc. as they had done a lot of research to determine the style of frieze etc.
Cheers,
Kerry
2 hours ago, kljang said:
Hi Alex,
Cheers,
Kerry
Thanks Kerry !  I've alread sent the e-mail.
Regarding to the Polish company, is it the Shipyard ?  If so, that card kit was based in the same plans of the NMM ?
Alex
Hi Alex,
Yes, the Polish company was Shipyard.  I have their HMS Juno plans myself and are quite good.    I would think they used the NMM draughts to develop their card kits but I can’t say for sure if they do.
I know when Tom designs a kit he cross checks his work against other’s sources of information.  He tells me he finds contradictions in all plans, lines that don’t match up, And a lot of fun areas that are unclear.  When I met him last year he showed me on a Royal barge how lines, measurements and details from well known sources did not agree.  His CAD renderings show up these inconsistencies quite well, then he goes and researches which version might be correct or tried to reconcile them.  He says he finds errors all the time in published plan sets of a ship and spends a lot of time trying to sort out where the variances and correct them before he can create cutting files to guide a laser.  It’s really a case of The GIGO Principle - Garbage  In, Garbage Out so you just can’t copy a plan to make kit,  the drawings must be checked, checked and corrected.   I’m glad he’s good at it!
Cheers,
Kerry
Hi Kerry
Wow, this is an interesting history !  I didn't know that there were others published plans of the HMS Enterprise. I understood that Tom had to check the NMM plans against others plans to achieve an accurated plan in order to make his work. 'Course, may be the own NMM plans may be a bit incorrect because they were made by hands on.  Even they were very precises, a CAD is much more an can point out those inconsistencies.  Moreover, the paper may suffer variations due to factors like umity, the quality of the paper, etc.
That's ok, I thank you.
I'll wait for CAF Models answer.
Alex
Alex
An amazing kit, to be sure! They sure built a lot of ships to this plan.
One quick question. What is the thickness of your frames? Do they follow the scantlings and dimensions of the framing plan, or are they thinner, simplified frame pairs like Harold Hahn's?
Hello USS Frolick,
When built, the frames are 1/4” thick, made up of two slices of 1/8”.  The frames are slightly simplified.  What I mean is that each is constructed futtock by futtock, but the joins between futtock pieces are straight, and not scarphed as in true English framing practice.  There is no reason to show scarphed joints between futtock parts as they will not be seen as each frame face where they would be seen is hidden by the frame ahead and aft.  The joints between futtock that would be visible on the side all fall where they should and follow a sheer.
Hope this helps,
Kerry
Hi USS Frolick,
the kit has two types of square frames.  Thick and thin.  The thin ones are 1/4” thick when assembled, and station frames that are thicker at 3/8” assembled.  The space between frames is 1/4”, but for the frames at the stern and bow (not cant frames) the space is reduced to 1/8”.
Cheers,
Kerry
yipeeeee
mine is on;y 30 odd miles up the M5
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
  • 4 years later...
Hello,
please bear with me, maybe my question is answered elsewhere, I just did not find it:
What is/are the differences between both ships from CAF and from Drydock? Same name, scale, different length, which is easier on the builder, etc.
Any help would be much apreciated - it will be one for me, but which one?
One is manufactured by a legit Chinese mfg (CAF).  CAF does not pirate or copy designs for their kits.  The other mfg distributed through DD in Canada is ModelShipDockyard.  Also a Chinese company. MSD and DD sell and pirate intellectual property and often steal the work of other mfg’s for profit.  They are on our banned list of mfg’s.  So its an easy choice.
Chuck
Hi Chuck,
thank you for your fast response! Btw: I am still interested in Speedwell, have some questions regarding postage for all items (to get good wood where I live is very difficult). The books from Seawatch are exquisite and fire lust for more! Waiting your shop opens again.
Best regards,
Robert
16 minutes ago, kljang said:
I should add that Tom's products are pirated by other manufacturers!
He told me this happens a lot...
Cheers,
Kerry
I wonder how this actually happens, are they buying his kits and reverse engineering them or somehow getting into his design files?
I can’t imagine the quality and fit of a reverse engineered kit is worth anything unless it’s completely copied/redesigned with some software… otherwise it would take less time and effort for one to just design their own.
  • 6 months later...
Sorry Scrubbyj,  just saw your question.  The other manufacturers can steal his design by buying his kit and rescanning his drawings or even parts to create their own CAD files to cut wood themselves.  All the work he has done to reconcile any discrepancies between sources is in effect “stolen” by those copying his designs.  This practice is not new as in the early days of plastic model kits in the UK and USA, plastic model kit companies produced kits pantographed from another plastic model.  You know it when all the errors of the original are faithfully reproduced!
I will be in Shanghai next month and will visit Tom from CAF and check out all his new ideas.  I’m currently helping him with research for a new kit, but mum’s the word!
Cheers,
Kerry
