Ok On the hood I got some paint on the  hull  just the hull red there still i lot more to do here some pic
That Anti - Fouling Red looks spot on.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
thanks old collingwood    airbrush i use really helps  its came out looking great
 just earlier tonight I added the black strip on  one side it came out extremely well i think here some pic
More work done to the hull it all painted now it came out looking great the black strip is spot on here are some.pic.for u all
Nice paint job, but I have a question regarding the waterline,
with the scale you are working with, the waterline seems very wide to me - is that a camera angle creating this illusion or is the waterline that wide in real?
Respectfully
Per,   the boot line in real life would have been about 8 feet wide on Battleships of that tonnage.
OC.
Current builds
Completed works.
16 hours ago, shipman said:
The 'Boot Topping' looks fine to me. The 'Read Lead' shade is also very convincing, though in real life it would look a bit redder when first applied but would oxidise to a shade like yours.
Its RN anti fouling Red  - its supposed to be  almost like a  mix between flat Red and Brick Red.
OC.
Current builds
Completed works.
The lower hull paint was a common industrial anti corrosion coating used on all sorts of architectural steel and ironwork. We in the UK called it 'Red Lead'. As the name implies, it was lead based; modern health and safety deems this to be toxic, so it isn't used these days. No doubt the lead content didn't encourage marine growth.
Thank you all  I used  Vallejo paint hull red for lower hull I thinned it a little more to get  The effect I wanted it came out vary well as for the water line it is right for ut scale i looked at a lot pic it came out looking great thank you  For all your comments so far as really help me out . What I have done now  I got the props painted in gold to create the color and the shafts are now install so this ship is looking great her are some pic
