Hello
First build pob build here. Iv done a couple solid hull mamoli kits fairly easily but ready to move on
Now that iv opened the box I'm a bit overwhelmed but I'm committed lol
Any help and advice would be much appreciated
I will do my best to keep a detailed log
the bulkheads are very loose tho. Are they supposed to be that way?
my ceiling fan is moving them lol
Welcome aboard.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Welcome to Model Ship World Jake.  You did the right thing by starting a build log for your kit.  The bulkheads may be loose, but be sure that they are properly seated in the false keel and that they are at right angles to the keel.  This is a very important part of the build, so take it slow.  I would use a PVA glue (yellow glue) to set the bulkheads and make sure the glue has set on the bulkhead you are inserting before moving to the next bulkhead.  Good luck on your build and be sure to ask if you have any questions.  We are here to help you be successful with your first build.
Ryland
               - Nautical Research Guild
question
Normally this deck is not bent. Are you sure nothing is wrong.
Now you can still adjust this if necessary
20200928_180345.thumb.jpg.8563792e8c63fe4fdecd23c63369f7bf.jpg.b4c9458957f6cc9b0d840aebdbbfcd70.jpg
Greetings
Patrick
11 hours ago, Backer said:
question
Greetings
Patrick
Yes, I messed up there. Luckily I can still rectify it, its actually supposed to be 2 separate decks
Jake, Take a look at the planking tutorials in the following post:
The various links will take you to PDF articles on planking a hull.  These articles are a great resource for beginner ship modelers as they will explain the hows and whys of planking a ship model.  As VTHokiEE said, the planks needed to be tapered at the bow.  All of this is explained in the planking articles.
Good luck on this build.
Ryland
And probably at the stern as well. Unfortunately kit manufacturers often supply the planks the same width the whole length, when in fact their width varies right along their length to allow for the complexity of the shape of the hull. Adjusting the width is called spiling, and it needs to be done otherwise you end up with gaps between planks at some points and overlaps at others.
I'd suggest you have a good read through the planking primers - take your time, until you're happy you understand them (and even then it's possible to make mistakes - don't ask me how I know), and then have another go at your planking. Don't worry - it is possible to get it right!
The other thing is it looks like you haven't faired your frames - that is to bevel them at the edges to follow the smooth run of the planks, so the planks rest against a surface rather than just an edge. The edges of the frames shouldn't be at right angles to the frames themselves, they should be at the appropriate angle to let the planks rest smoothly against them. (I hope that makes sense).
Planking is probably the most difficult job you'll have in making your model. It's worth putting in the time and study to get it right. You'll be glad you did. And ask questions - lots of questions. Plenty of experienced people here to help you.
Jake, I really struggled with understanding the various documents, I find there to be an assumption that you know certain things and steps are skipped over or not visually explained in enough detail. I think this is one of the major issues with wooden ship building and why people don't stick around in the hobby.
However, I finally found a great build log, it was for the Model Shipways 18th Century Longboat by BobF.
This guy has a great visual way of explaining things, he really doesn't skip a step and comes back with further information if you found any of his steps difficult to understand.
I know no ships are the same but for some reason this one really hit home.
Current Builds
Mikasa by I Love Kit - 1:200 - Plastic
HMS Beagle by Occre - 1:48 - Wood
So I did fair the hull but it ended up being way to much as i thought it would be a good idea to use my dremel..
I'm gona stick with it and sand the ever living hell out of it as it is a single plank hull. May not look exactly as its supposed to but it's my first build and it's a learning experience
Ah I see the fairing now. I’m thinking that you’re at the beginning of the build and you may regret not pulling these planks off, ordering some new ones and try your hand at tapering (spiking) them. I think that it’s going to be tricky to fill though gaps on a single planked hull.
I read many documents on planking, watched some videos and then had a disaster on my first go through. I removed it (with great sadness and frustration, I had some sleepless nights thinking that I would never get it right) and tried again (you can see what happened to me in my build log if you’re interested). I’m glad that I took the time to redo though because I’m getting close to 10 months of work on my model and I would be disappointed with myself if I hadn’t.
If you are set on pushing forward I would heavily consider painting the hull as it can disguise and filler you end up needing.
  • 3 months later...
I like your spirit!
