Great job Rob.
I remember making the *Hanks* for the sails for my Great Republic.  I made them by wrapping wire around a 2mm OD piece of stainless steal wire.  Then I cut them along one side...creating hundreds of tiny rings.
Like yourself I afixed them to the bolt ropes.
I, however, then thread the stay through the row of hanks and fixed it to the mast....holding the sail permanently on the stay.
Love your progress.....
Rob
Current build:
Finished build:
Current build(On hold):
Working from the inside out is faster and less obstructive.
Rob
Current build:
Finished build:
@rwiederrich - It truly is.
I had a good day yesterday working on Stefano - I've added the mast hoops to the Mizzen topmast - these 9 hoops were formed from brass wire and chemically blackened. Then they were put in place on the mast and thread tied to them ready to attach the sail. I added the running rigging holding this sail in place, and then went on to add the spanker sail.
Now that these fore and aft sails are in place, I can add the backstays. So far I've added the starboard foretopmast backstay.
Thanks for looking in, and for your kind words and encouragement. Getting to this stage is really spurring me on to complete Stefano, but there's still a fair bit to do. :)
Rob
Hi everyone,
Three weeks later, and I've had another good day to work on Stefano. I finally made and died some more .5mm rope for the standing rigging, which allowed me to complete the backstays. I've also got some more work done on the yards, adding eyelets, blocks, and bending the forecourse to the main yard on the foremast. Again, this has caused the model to take up significantly more space on my desk, but it feels like we're on the home straight now as we move towards running rigging. I counted, and I think I have 8 sails left to bend to yards / stunsail yards. There's a lot of tidying up to do with rope ends fixed with watered down PVA (a big advantage of making your own rope with DMC cordonnet thread, as it's natural, not synthetic), and trimmed to make them neat.
Thank you so much to all of you who've hung in there through what has proved to be a lengthy build :)
Here are a few shots of how she stands right now.
Happy building :)
Rob
Thanks, @BobG, @gak1965, @AJohnson, you're very kind. I feel surrounded by masters, here... but I'm pleased with how my bodging is coming along!
I managed to add the reef points to the fore upper-topsail, which is the last sail to need reefing points, so that was a nice milestone to reach.  Next is to add the eyelets and blocks to the fore upper-topsail yard ... am I the only one who finds drilling holes all over the yards a fiddly and frustrating job?
I think I've probably described the process of the reefing points before, but just in case, it's #100 DMC Cordonnet crochet thread, with a knot in it (one knot is plenty), then threaded through the sail with a needle. Once through, it's cut off with a couple of inches to spare. When all done, I place a metal ruler beneath it, and use watered down aliphatic glue (Carpenter's glue / yellow glue) to stiffen the thread, and line it up vertically. Once fairly dry, it's cut to length (the width of my wider 15cm steel rule) and another dab of watered down PVA fixes the end in the right position on the sail. The sail is then turned over, and the process repeated.
The finished article...
I am glad to have these done.
Thanks for all the support and encouragement :)
Rob
Edited by robdurant
making sure I say thank you :)
A very quick update, and an opportunity to say a big Happy Christmas to everyone :) Immanuel - God is with us.
I've completed the task of fitting out the yards, and bending the sails to them. And now, I've begun to add the running rigging, starting at the mizzen mast, and moving forward. Now that I'm well into it, I'm beginning to understand the plans. It's necessary to reference various different plans to see all of the runs and belaying points. This means the task is best down with a big table spare... The kitchen table works for me, but it does mean that it's not very easy to proceed when family are around for Christmas - a nice problem to have ! Here are some pictures of progress so far...
 20231230143606-73e8dd07-la.jpg.488fcd640f492d59f75419ce7ce7c8c6.jpg20231230143605-815bef0d-la.jpg.bf9b486d7230ac38acac33fc05340107.jpg20231230143605-5e87a365-la.jpg.1bc80c2a25f09826b4497415aeb49dd6.jpg20231230143604-b68f9c87-la.jpg.2e6b163e982b1d6cf9d1c852e3b60454.jpg20231230143603-aff8dae7-la.jpg.51e608f5ca84daa17447e05da6485997.jpg
She's a beauty!
Looking back on some of the posts of your build log I saw some discussion about a display case. I have built display cases for all my models and it's not as difficult as it might seem at first. Take it from somebody who is not particularly talented with adult tools as opposed to modelling tools. (Me)  I have discovered a site of building a display case whilst seaching for an improved method over mine and found it on modelshipcases.com by Wes Marden. It's a detailed build log of building a display case and except for a table saw, all the other tools used in its construction are pretty basic. It costs just $12US to download the instructions and I plan on using his method in building my next case.
For me, it's cringeworthy that a piece of finely constructed ship model be subjected to the elements such as years of dust accumulation and cats.... Especially cats.
Peter
Edited by petervisser
removed dated info
Build Log: Billing - Cutty Sark
In The Gallery: HMS Unicorn, HMAV Bounty, L'Etoile, Marie Jeanne, Lilla Dan, Zeeschouw "Irene"
A Toast: To a wind that blows, A ship that goes, And the lass that loved a sailor!
Thanks, Jason.
Progress is slow but encouraging. Hopefully I'll get back to a place where I can continue this model, but it's well beyond me at the moment :) until then, I walk past it every day and marvel that not so long ago, I did that! 😆
Great to see you making headway on your stunning Artois class.
Rob
  • 2 months later...
On 4/20/2024 at 8:45 AM, robdurant said:
Thanks, Jason.
Rob
Best wishes
