Hi there. I’ve just joined the Group today. I’m a retired seafarer (38 years Service Royal Navy). I have been building POF ships since I was about 19. Six ships completed in between time away at sea. All builds have been from ‘in the market’ kits, but I am working myself up to take a leap of faith and semi scratch build HMS Prince from the Amati plans, which are on order. I just need to finish HMS Fly first; basic hull complete, main deck fitted and that’s it so far.
I do like WW2 ships, mainly 1/350 scale in plastic, with all the aftermarket bits and bobs. Recently finished a paper and card 1/200 HMS King George V.
Really looking forward to sharing stuff on this site.
Hello, Henry Wombat, welcome aboard MSW.
It sounds like your interests are spread across all the key subjects here, I am sure you will find a lot of interest if you decide to add a build log (or two or three...) especially as you are a 'proper sailor'.
Bruce
STAY SAFE
current builds:
Welcome aboard, Henry!
Ooh, that sounds like a Halinski product -- that's a real feat. We have a small cadre of card model enthusiasts within our ranks.
10 hours ago, Henry Wombat said:
HMS Prince
This inspired me to investigate my archives.  For a time, I explored building a model of HMS Prince 1670.
This was at a time when I was teaching myself some skills on the drawing board, so no wood was ever in danger.
My first step is to gather up as much information as I can find.
Long ago, I bought:
A set of 1:48 lines plans of the ship (model?), I think it is  from the Science Museum.  It is a really large photograph - on two sheets.
A set of 1:96  plans ID'ed with CM (Clive Millward?).
A folder of model plans 1:60  (POB - ugh) in Italian  Teconmodel .
I think I have a series of photos of the Science Museum model - probably from their museum shop.
At the time, I was working thru the design exercises in Deane's Doctrine.  This made me aware of "touch" as relates to keel and ship length.
Touch is what the dimensions in tables from the time list as the length of the ship.  It is ~20% shorter than the length on the gun deck.
I was corresponding with someone who was building a kit of HMS Prince. He was having trouble getting the deck gear placed.  It turns out that the designer of his kit confused touch with LBP. The hull was too short.  It could have been rescued early on by patching in an additional section of spine at the dead flat and duplicating or triplicating the midship mould.
For your kit plans, it would be prudent to verify that the length of the hull is correct.
A first rate 17th century floating palace is about as daunting a challenge as it gets for a ship model.  If you are determined to forge ahead, but wish your first scratch project to have sufficient documentation and plans,  ANCRE has a recent monograph of a French 17th first rate that is both elegant and magnificent.  It is St. Philippe.  But a really challenging aspect is that all of the frames are canted forward between 1 and 2 degrees.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Welcome to MSW, Henry - from Oz, the land of the wombats.
It would be good to see a build log of your HMS Fly, even if it started from your current stage of completion - though photos from earlier in the build would be even better. In case you haven't come across them so far, the instructions for starting a log are here:
It's a great way to get help and encouragement (and the rest of us get to see the progress of your build).
Good to have you on board.
Steven
Edited by Louie da fly
