Finally ready to do this build log . I attempt to keep it all short and to the point . Received HMs Beagle , opened up to check the contents and condition. Checked to see if there was any damage or anything had warped during the packaging , transport etc . All seemed ok
Started to plank the deck. This is where I made my first error . I chose the thicker lime wood , as opposed to the veneer that I was supposed to . I had already glued and clamped it all when  I realised the mistake . So I left it as is , I figured it would not affect anything in the grand  scheme of things
Looking good Peter...Moab
Completed Builds:
Virginia Armed Sloop...Model Shipways
Ranger...Corel
Louise Steam Launch...Constructo
Hansa Kogge...Dusek
Yankee Hero...BlueJacket
Spray...BlueJacket
26’ Long Boat...Model Shipways
Under Construction:
Emma C. Berry...Model Shipways
I've got this model on the shelf...will be next when I finish the Perseverance which is still on the workbench!
I'll follow along for the ride.
Cheers.............Fernando :cheers:
Current Builds - Colonial Brig Perseverance 1807 by Fernando E - Modellers Shipyard - 1:48 scale
Previous Builds -
S Lucia by Fernando E - Panart - Scale 1:30
Sloop Norfolk 1798 by Fernando E - Modellers Shipyard - Scale 1:36
Placed the bulkheads , lined and coated them with matt varnish. I attached the doors and windows to the relevant bulkheads . and finally got to attach the bow and stern decks , strapped them down to attach securely . Rubber bands work wonders on areas that are not always squared
Looks like you've made a great start to the build and are make fine progress.  I'm doing the same build but having a few issues along the way.  I don't find the instruction too helpful so I tend to just use them as a pointer.  I'm very interested to see how you progress so will keep a close eye on your build log.
Chimp
Current Build: HMS Granado - Caldercraft
Previous Builds: HMS Beagle - OcCre,   HM Schooner Ballahoo - Caldercraft
I have finished the first planking . I used a jig I made to bend the planks beforehand , so were ready for use when the time came . I attempted to follow the pattern as in the diagrams , but got lost in the detail I think . Bow turned out a bit messy , stern looks okay . I will attempt to repair the damage during the sanding process
Finished the repairing and sanding of the hull . I confess I used some woodfiller for the larger areas  before sanding , but guessed as this planking would be covered by another layer it would not be seen. I think it turned out ok . Ready to start the top layer of planking soon.
Chimp
You seem to be doing great on your build . I try and follow the instructions then see if the video is of assistance . Between the 2 options I try and work it out
Started the top layer of planking . Its a little different to what I had on the last build as this layer is really thin and needs to be handled carefully . once O got used to working with it , steady progress has been made . Just left with the "patching"
Sanding done . Had to repair a few places as some of the top layer wood is really brittle , and there seems to be a variety of finishing on the wood. some do not have as good an edge . I'm starting to fit the  ribbons on the outside . To make the bend I used the same template I made earlier that bent the bulwarks and the first planking . Left it in the winter sunshine to dry out before I used it
Finished the ribbons . Now the build is starting to look like something . Had a small issue when a part of the ribbon that was cut out at one of the aft portholes , fell inside . Took forever trying to locate it , lots of shaking etc. Eventually managed to blow it out using compressed air in a can .
20 hours ago, uncarina said:
Impressive work Pete! Just got this kit myself so I am really enjoying your progress.
Cheers,  Tom
Thanks
On 2/14/2021 at 5:40 PM, uncarina said:
Will you be adding copper plating as well?
Cheers,  Tom
No,  I'm just going to do the recommended painting scheme. My next build I may  select  a ship that has the copper plating
Here's the work in progress with the painting . Took a little longer than expected . Painting everything black then makes it really difficult to get the white going , takes extra coats.....maybe would have been more expedient to just paint them separately. It all worked out in the end
Hi Pete,
Looking great, just started on this kit myself.
What Matt Varnish are you using?
Edited by Krupi
